loosening tappit
dangerous
Ummmm, Im thinking not so good what do you guys reckon?
V11 cafe sport was brought with new cam amongest other things... the exhaust valves recently burnt out and were replaced
1000k on and a exhaust tappit clearance went from .015 to 3mm
re adjusted it and is now after 400km loose as hell again...
What do you think the corse could be???
starts with C ends with M and has a A in the middle?
So it went from .015mm which is way to tight to 3.0mm,is that right?
Any valve that picks up nearly 3mm of clearance in 1000klms has obviously got major issues most likely a wiped out lifter and cam lobe.
Why on earth would you even bother to adjust it. it needs the head pulled off and the lifters inspected for damage.
.015 my be in not mm then either way .015 is the correct gap, iirc some us specs recomend larger.
this is not my bike... adjusted it because the bike needed to be moved and as the valves had just been replaced it 'may' have been a settle in thing be it somewhat excisive... the bike was brought with having the cam just replaced so you would think it was not a issue.
Thinking the 1st cam went due to oil feed failer, could this have happened again?
Thinking perhaps bad luck and this bike has had two failed cams due to failed hardening?
Cause of cam failure was found & rectified?
IME the followers will give up before the cam, but whatever... as said above, someone will have to look & see. Followers live under the barrels & should lift out.
No issue with rocker assembly, pushrod, valve?
Any metal in sump?
Check the tappets. As mentioned before somewhere, there is no lubrication failure to be expected 'cause the lobes and followers are splash lubed. Otherwise you'll find major damage on other parts, too.
BTW, ccheck the pushrod first. Sometimes you can have lucky days, too, on a Guzzi :)
2.edit: Baldini was first I see just now ...
