devonrider Posted September 28, 2015 Share Posted September 28, 2015 Hi All. Griso 1100 owner from the UK. I'm about to pull the trigger on a V11 which evidently has the single plate clutch. I'm reading some real horror stories about these. Can anyone put my mind at rest. Link to comment Share on other sites More sharing options...
footgoose Posted September 28, 2015 Share Posted September 28, 2015 I bought the Tenni new, so I wouldn't have known of the flywheel issue. I sold it and re- purchased it again and knew fully well what I was getting into. In my case, since I had sold it to a friend who treated it gently as I had, I felt comfortable enough to ride it (only had 11000 mi) for awhile till I could replace the clutch, which i have yet to do. Consensus here and other forums, I believe will indicate... 1. There is a good chance the alm flywheel will eventually break. and 2. The dual plate with steel flywheel is reliable. Conversions can and have been done, revealing both cracked, and undamaged alm flywheels. If the bike you're getting is "special" to you, and the price reflects the issue, AND you're willing to gamble and/or replace, then go for it. If not, there are plenty other sport/lemans out there with the dual plate clutch/steel flywheel. Keep in mind, the Alm flywheel is not guaranteed to break, but something you do not want to happen as you ride. My advice to a friend would be to replace the aluminum flywheel at some point. As far as I know the single plater is in the Tenni, Scura, and Rosso Mandello. Which one are you looking at? Miles, history, etc. Tell us more. Got a photo? Even the Griso?? welcome btw Link to comment Share on other sites More sharing options...
footgoose Posted September 28, 2015 Share Posted September 28, 2015 There's plenty here to read on the subject. search Tenni clutch or Scura clutch. here's one I had a link to http://www.v11lemans.com/forums/index.php?showtopic=19010&page=1 1 Link to comment Share on other sites More sharing options...
fotoguzzi Posted September 28, 2015 Share Posted September 28, 2015 Hum, mind at rest? I'll try that when I'm dead.. changing out the clutch is not hard just time consuming. my friend did 2 in 77,000 miles on his Scurra. Link to comment Share on other sites More sharing options...
footgoose Posted September 29, 2015 Share Posted September 29, 2015 Foto, did he change out the flywheel or worn clutch plates? 2 plate conversion? Link to comment Share on other sites More sharing options...
fotoguzzi Posted September 30, 2015 Share Posted September 30, 2015 yes he needed the flywheel replaced too it was cracked. Link to comment Share on other sites More sharing options...
