Gottagetone Posted December 4, 2015 Share Posted December 4, 2015 Not sure if this is tech or not but it certainly could end up that way... I found this sheared off bolt in the plastic cuff that the cables run through on the right side just in front of the gas tank. I have searched and can't find an empty hole or the other part of the sheared off piece. Link to comment Share on other sites More sharing options...
Camn Posted December 4, 2015 Share Posted December 4, 2015 Could it be one of the special screws ("cuts off" when tightened) which fasten the ignition switch ? Link to comment Share on other sites More sharing options...
gstallons Posted December 4, 2015 Share Posted December 4, 2015 I would say that is what is . 1 Link to comment Share on other sites More sharing options...
Scud Posted December 4, 2015 Share Posted December 4, 2015 I agree. In addition, I think the same type of screws are used to attach the seat lock bracket. Maybe somebody (aka Luigi) just dropped one during assembly and didn't fish it out - until you found it just now. Link to comment Share on other sites More sharing options...
guzzi323 Posted December 5, 2015 Share Posted December 5, 2015 II agree it looks like one of the ignition switch screws. I'd recommend taking a look at the underside of the switch as on my bike both bolts fell out (not at the same time). Tthen the switch slid down and got jammed between the headstock and the forks, severly limiting turning to one side. For me, it slid down while I was parking so it wasn't so bad. If it happened on the road, I don't think I could have avoided a crash. johnk Link to comment Share on other sites More sharing options...
GuzziMoto Posted December 5, 2015 Share Posted December 5, 2015 The bolt does not shear the head off until installed, so that bolt used to be doing something. As said, check your ignition switch and seat lock. It is possible that it has already been replaced, but that bolt fell out and those are the two places I can think of that use that style bolt. Link to comment Share on other sites More sharing options...
Scud Posted December 5, 2015 Share Posted December 5, 2015 ...and if you do find a vacancy where the bolt should be, you can re-use that bolt by filing it flat and cutting a groove into the head - then reinstall it with a flat-blade screwdriver. Link to comment Share on other sites More sharing options...
gstallons Posted December 5, 2015 Share Posted December 5, 2015 Measure the thread pitch and substitute a capscrew that has a head on it you can tighten and loosen . Those things are used as a theft deterrent or tamper proof screws. In this case it is for the ignition switch . Link to comment Share on other sites More sharing options...
Kiwi_Roy Posted December 5, 2015 Share Posted December 5, 2015 I don't see the point of the security bolt when you can drop the contact block off with a Philips scewdriver Sent from my shoe phone! Link to comment Share on other sites More sharing options...
Gottagetone Posted December 7, 2015 Author Share Posted December 7, 2015 Thanks Gents, I have had the ignition out and can't find any problems. Since I found it near the head stock I don't think it is part of the seat lock. Ill double check the ignition switch just to be sure. Update, I just looked and you guys were right, there was a hole underneath the ignition that was empty. Blue thread locker and some needle nose and its good to go...Cheers! Link to comment Share on other sites More sharing options...
