Kiwi_Roy Posted July 20, 2016 Posted July 20, 2016 I suggest you use your other thread about Scura Electrical Issues Cheers Roy
plexiform Posted July 21, 2016 Posted July 21, 2016 I suggest you use your other thread about Scura Electrical Issues Cheers Roy thanks. will do
Shepflylow Posted November 9, 2024 Posted November 9, 2024 Wow @Kiwi_Roy —the diagram saved me a lot of headache. My V11 wouldn’t start. I have a few bikes, all are older than this one. I had not ridden the V11 for a couple of months. It wouldn’t start. I suspected a fuse and this diagram was a big help. But embarrassingly enough I noticed “clutch switch” and problem was solved! User error! 2
gstallons Posted November 10, 2024 Posted November 10, 2024 You need to print these diagrams (multiple) and study them . I have mine in a folder near where iI sit along with w/11x20 exploded wiring diagrams . 2
audiomick Posted November 10, 2024 Posted November 10, 2024 A good exercise for me was to "extract" the starter circuit myself. Helped me understand what is happening there a lot. 1
Kiwi_Roy Posted August 5 Posted August 5 The Starter solenoid draws a lot of current 40 - 50 Amps so it will blow a 15 Amp fuse after a few seconds. Actually on most Guzzi's the solenoid current is limited by bad joints dirty contacts and wimpy wires. 2
Pressureangle Posted August 5 Posted August 5 5 hours ago, Kiwi_Roy said: The Starter solenoid draws a lot of current 40 - 50 Amps so it will blow a 15 Amp fuse after a few seconds. Actually on most Guzzi's the solenoid current is limited by bad joints dirty contacts and wimpy wires. The solenoid itself draws that much? iirc the starter itself draws ~80A in good condition. 1
Kiwi_Roy Posted yesterday at 05:12 AM Posted yesterday at 05:12 AM (edited) Connect a small 12 Volt lamp between the starter solenoid trigger terminal and chassis, Does it turn on when you press Start? With the key turned On does the headlight turn On, it should then go Off when you press Start Edited yesterday at 05:13 AM by Kiwi_Roy 2
