guzzigary Posted August 1, 2019 Share Posted August 1, 2019 Genyoowine C-LP shift extender in all its zinc chromate glory. Never installed. $50 merican plus shipping 1 Link to comment Share on other sites More sharing options...
guzzigary Posted August 5, 2019 Author Share Posted August 5, 2019 SOLD! Link to comment Share on other sites More sharing options...
gstallons Posted August 6, 2019 Share Posted August 6, 2019 When you go to install this , remove the shift lever bolt 8mm dia. I think . the nut at the inside is a jam nut so loosen it 1 turn and unscrew the pivot bolt . Remove and grease everything . 1 Link to comment Share on other sites More sharing options...
docc Posted August 6, 2019 Share Posted August 6, 2019 18 minutes ago, gstallons said: When you go to install this , remove the shift lever bolt 8mm dia. I think . the nut at the inside is a jam nut so loosen it 1 turn and unscrew the pivot bolt . Remove and grease everything . Truly! In fact: clean, service, shim, and align the entire Rube Goldberg shift mechanism! Make sure the foot lever does not strike the FrameSidePlate in any gear on the downstroke. Link to comment Share on other sites More sharing options...
gstallons Posted August 6, 2019 Share Posted August 6, 2019 Also , make sure the shifter does not bang / rub on the pork chop after reassembly . Link to comment Share on other sites More sharing options...
docc Posted August 6, 2019 Share Posted August 6, 2019 1 minute ago, gstallons said: Also , make sure the shifter does not bang / rub on the pork chop after reassembly . Yeah, the "Frame Side Plate" . . . you can actually see a little nick in mine in the image above. Seems the lever doesn't move the same throw in all downdshifts, so check through the range. Link to comment Share on other sites More sharing options...
