hammershaug Posted June 13, 2021 Share Posted June 13, 2021 I read somewhere about fuel level sensor resistance should be around 1 Kohm when covered in fuel. (cold) My sensor measures 6.4 Kohm when covered in fuel. Has anybody made the measurement? Is there hope - or is it fried? Link to comment Share on other sites More sharing options...
docc Posted June 13, 2021 Share Posted June 13, 2021 6.4kΩ will certainly keep the light out! The question is whether the resistance will drop enough to light the bulb when the sensor is uncovered by fuel and it warms up (?) I do see that Kiwi_Roy measured the cold resistance at around 1 kΩ : Link to comment Share on other sites More sharing options...
hammershaug Posted June 13, 2021 Author Share Posted June 13, 2021 Thanks, @docc Time will tell. I don't have the nerves to test it out for real, so have to drain the tank in the garage someday. I have a bad feeling about this sensor because the wires were cut when I bought the bike. 1 1 Link to comment Share on other sites More sharing options...
GuzziMoto Posted June 16, 2021 Share Posted June 16, 2021 As mentioned, the key to the fuel sensor is it has enough resistance when covered in fuel (kept cool) to prevent the low fuel light from lighting. As long as there is enough resistance, it really doesn't matter how much there is. When it is exposed, uncovered, its resistance goes down and it can flow enough electricity to light the low fuel light. It is a really simple circuit. Besides testing the resistance of the sensor you can confirm that applying 12 volts to the rest of the circuit will light the low fuel light. 2 Link to comment Share on other sites More sharing options...
