LowRyter Posted June 9, 2023 Share Posted June 9, 2023 I've done a search and read over the FAQs. I thought there was a diagram that indicates which relay matched to circuit. Specifically looking for the relay controlling the ignition circuit. Thanks. Link to comment Share on other sites More sharing options...
docc Posted June 9, 2023 Share Posted June 9, 2023 No relay for the ignition switch, IIRC. Link to comment Share on other sites More sharing options...
Tomchri Posted June 9, 2023 Share Posted June 9, 2023 There is some good circuit prints around here, CRW. Cheers Tom. Link to comment Share on other sites More sharing options...
LowRyter Posted June 9, 2023 Author Share Posted June 9, 2023 57 minutes ago, docc said: No relay for the ignition switch, IIRC. sorry, I meant spark plug circuit. Link to comment Share on other sites More sharing options...
MartyNZ Posted June 10, 2023 Share Posted June 10, 2023 Relays front to back: 1. START (5 Pin Relay) 2. LIGHTS (4 Pin Relay. 5 Pin OK) 3. NEUTRAL/SIDESTAND (4 Pin Relay. 5 Pin OK) 4. ECU (4 Pin Relay. 5 Pin OK) 5. FUEL/COIL/INJECTION (4 Pin Relay. 5 Pin OK) 2 Link to comment Share on other sites More sharing options...
LowRyter Posted June 10, 2023 Author Share Posted June 10, 2023 Then #5 if you're not getting spark or fuel. That one seems to be most trouble prone for me. Link to comment Share on other sites More sharing options...
