Kapiti kiwi Posted August 23 Posted August 23 Hi guys so I have some staintune mufflers but sadly they are dented badly from prior storage I’m guessing I have a local motorcycle mufflers shop nearby ‘cycle works” I also have some other no name mufflers in black but they are very open or free flow with removable baffles my question is if they are to free flowing what do you have to do to correct fueling is it that CO trim I’ve heard about bike is has crossover pipe as well otherwise stock
Kapiti kiwi Posted August 23 Author Posted August 23 I’m in two minds,about getting staintune mufflers repaired ie re skinned or get cycle works to make new link pipes for these black mufflers as my bike is basically All Black now bar pork chops and bars for now
pete roper Posted August 23 Posted August 23 If you can get the ‘Toons repaired it will probably be worth it. A V11 with ‘Toons is one of the best sounding motorcycles ever built. As for getting it to run right? First a proper tune up, then remapif you feel it needs it. 3
Lucky Phil Posted August 23 Posted August 23 5 hours ago, Kapiti kiwi said: Hi guys so I have some staintune mufflers but sadly they are dented badly from prior storage I’m guessing I have a local motorcycle mufflers shop nearby ‘cycle works” I also have some other no name mufflers in black but they are very open or free flow with removable baffles my question is if they are to free flowing what do you have to do to correct fueling is it that CO trim I’ve heard about bike is has crossover pipe as well otherwise stock Fit the mufflers and ride it and see how it runs. Probably won't need to make any fuelling adjustments but if you do start familiarising yourself with Guzzidiag. It's free and awesome for tuning. Phil 2
Kapiti kiwi Posted August 24 Author Posted August 24 Cheers guys I have not been out on the bike with the toons yet I think I will get them fixed judging by these replies 1
Kapiti kiwi Posted Wednesday at 04:09 AM Author Posted Wednesday at 04:09 AM Hi guys I’m nearly there seat back tomorrow pipes done just finished up painting some touch ups now I have one question for a future tidy up my pork chops are faded on one side of the bike right so firstly if I undo them will anything bad happen secondly I’m in two minds about the finish to put back on th I’m leaning towards vapour blast then paint candy red or get them re anodized any input appreciated 1
Lucky Phil Posted Wednesday at 05:26 AM Posted Wednesday at 05:26 AM (edited) 1 hour ago, Kapiti kiwi said: Hi guys I’m nearly there seat back tomorrow pipes done just finished up painting some touch ups now I have one question for a future tidy up my pork chops are faded on one side of the bike right so firstly if I undo them will anything bad happen secondly I’m in two minds about the finish to put back on th I’m leaning towards vapour blast then paint candy red or get them re anodized any input appreciated The pork chops hold the bike together so act accordingly support wise. Not possible to anodise cast aluminium in Australia or I imagine in NZ either. Rub them back with wet and dry and green Scotchbrite then spray them with 2K paint like I did a few years ago. Phil Edited Wednesday at 05:27 AM by Lucky Phil 2 1
po18guy Posted Wednesday at 05:57 AM Posted Wednesday at 05:57 AM On 8/22/2025 at 11:09 PM, pete roper said: If you can get the ‘Toons repaired it will probably be worth it. A V11 with ‘Toons is one of the best sounding motorcycles ever built. As for getting it to run right? First a proper tune up, then remapif you feel it needs it. I was fortunate enough that the V11 I stumbled into already had Staintunes mounted. And there they'll stay. The dB killers might make suitable cigar holders. 1
