20 hours ago, docc said:
Let's talk batteries, @Sam P.
Did you replace the "destroyed Odyssey" with another Odyssey, or something else?
A voltage loss from 13.0 to 12.7 in an hour is not a good sign for an Odyssey. There are specific parameters to "condition" the Odyssey that may help contribute to a solution. "trickle chargers"/ "tender" are known to be damaging to the Odyssey battery unless the voltage is adequate, yet will not "charge" the Odyssey with sufficient amperage (at least 6 amps).
I replaced the blistered and bloated Odyssey last month with a new one, just before I started this thread.  I've skimmed through your Odyssey Battery Conditioning thread (20+ pages!) and have ordered what I believe is an appropriate charger.(Battery Minder 128CEC2, which I believe replaces the older 12248 model). Will condition my battery asap, but I assume I can continue to troubleshoot my charging issues in the meantime. I am still keeping the battery on my trickle charger, which keeps the volts at 13-13.4, and I hope this isn't hurting the battery.
Good call on getting the approved charger. :thumbsup:
Odyssey states that float voltage below 13.2v will shorten battery life. What is your trickle charger's voltage?
4 hours ago, docc said:
How about running a jumper wire from the battery positive to the black wire into the regulator  (turn the connector 90 degrees to leave the white->blue connected). KOEO: battery light on? Start up and normal charging at some rpm with no 4000 rpm light?
Did you start it to see if it charges with the jumper wire to the black wire of the regulator?
Next, I would jumper the other side of the connector (battery voltage to the white wire and the connector rotated to connect the black --> red/black.
I don't think the light will come on at all in that configuration. Looking for the charging voltage to come up while running above idle. . .
12v/1.25 Amp
Posted (edited)
Edited by Sam P
