Sam P Posted September 24 Author Posted September 24 11 minutes ago, docc said: If I am reading this correctly, the odd charging light behavior started after the battery got cooked. And did not change with the new stator and regulator? Makes me think something also got cooked in the harness/connectors - seemingly in the circuit involving the instrument panel . . . My memory is unfortunately foggy one the chain of events, but I will try to reconstruct them here. After the first Odyssey showed signs of bubbling and bloating - with no alert from the charging lamp - I assumed to regulator was bad, and that the reg was overcharging the battery, hence the bloating. So I replaced the reg, along with my current "new" Odyssey battery. Next, I took the bike for a ride and the battery light lit up again, so I suspected the stator - sending too many AC volts to the regulator - which I then replaced. Installed the new stator, rode for 100 miles and the charging light never lit up. Like an idiot, I thought all my problems were solved, lol. The next ride, the lamp started to activate at 3-4K rpm, which is where we are now. (This was the title of this post, remember? Is the stator defective?' My memory is foggy on this, but I never recall the battery light OR the oil light EVER activating with key on, engine off. 1 1
audiomick Posted September 24 Posted September 24 32 minutes ago, docc said: ...Rather than the "tender" approach, I have grown fond of charging ...then terminate charge and let the battery gradually discharge. Repeat when the static charge reaches... 27 minutes ago, docc said: ... the odd charging light behaviour... Makes me think something also got cooked in the harness/connectors - seemingly in the circuit involving the instrument panel . . . 24 minutes ago, Sam P said: Not to derail my own thread on my charging issue, but it sounds like going forward I should stop using the Battery Tender and use your protocol quoted here, amirite? A few words on this... Basically, I'm of the same opinion as @docc here. Regarding batteries: modern Lithium-ion batteries are much better at not getting a "memory", living with lower charge states and what-have-you. As a sound engineer, I've spent the last 40-odd years dealing with things that run on batteries. Experience shows that it is better to regularly make sure they get charged properly, then let them cycle for a while as the manufacurer intended, then make sure they get a good charge, then let them cycle, and so on. The lead-acid variants that we find in our motorcycles belong to the category that this applies to. Cheap trickle chargers don't do the business. Docc has the right approach: proper charger, let it cycle, proper charger. And now, back to the topic in question: why is your charging system doing weird bollocks? 1 1
docc Posted September 24 Posted September 24 6 minutes ago, Sam P said: My memory is unfortunately foggy one the chain of events, but I will try to reconstruct them here. After the first Odyssey showed signs of bubbling and bloating - with no alert from the charging lamp - I assumed to regulator was bad, and that the reg was overcharging the battery, hence the bloating. So I replaced the reg, along with my current "new" Odyssey battery. Next, I took the bike for a ride and the battery light lit up again, so I suspected the stator - sending too many AC volts to the regulator - which I then replaced. Installed the new stator, rode for 100 miles and the charging light never lit up. Like an idiot, I thought all my problems were solved, lol. The next ride, the lamp started to activate at 3-4K rpm, which is where we are now. (This was the title of this post, remember? Is the stator defective?' My memory is foggy on this, but I never recall the battery light OR the oil light EVER activating with key on, engine off. 2 minutes ago, audiomick said: And now, back to the topic in question: why is your charging system doing weird bollocks? "Weird bollocks ", indeed! I have put mySport on the lift, removed the seat, pulled the regulator connector apart, probing with the DVOM, trying to fathom why @Sam P's Sport won't charge and how the strange warning light behavior might inform a solution . . . 1 1
audiomick Posted September 24 Posted September 24 5 minutes ago, Sam P said: ... the first Odyssey showed signs of bubbling and bloating - with no alert from the charging lamp - I assumed the regulator was bad, and that the reg was overcharging the battery,... Next, I took the bike for a ride and the battery light lit up again, so I suspected the stator - sending too many AC volts to the regulator - ... ...The next ride, the lamp started to activate at 3-4K rpm, which is where we are now. I reckon the first assumtion was good. Battery cooked = regulator is not doing it's stuff, too many Volts into the battery = dead battery. Been there, done that (more than once... ). In those cases, the battery light didn't come on. I don't know for sure that the battery light never shows overcharging, but I understand it to be that the light generally only comes on when the system is undercharging. In that context, I would question the second assumption. Given that I don't expect the warning light to show overcharging, I wouldn't expect it to come on if the stator is delivering too many volts. Apart from the warning light, the regulator should take care of too many volts. That is, after all, what it is there for. The alternator delivers a voltage that increases with revs. The regulator is supposed to keep that under control and make sure that never more than about 14V gets through to the charging system. Regarding the third point, I've already written that I suspect that there are two problems. From the information that you have provided, it seems that your charging system is currently not working, despite the new regulator and stator. Therefore the charge warning light should be lit up all the time. It isn't, so it is fair to assume that there is also a problem somewhere in the circuit that the warning lamp is in. I'd still like to know what the resistance (Ohm) measurement is between the connector for the warning lamp to the regulator (where the blue wire is connected) to ground. If the regulator is behaving correctly, that should be close to zero with the key on, engine off, "infinite" with the engine running and the charging system working properly, and close to zero if the charging system is not working properly. If that is not the case, the regulator might have a problem, or there might be bad connections somewhere else. If it is the case, the warning light circuit would seem to have a problem that is confusing the issue.
docc Posted September 24 Posted September 24 @Sam P, let's try to take the oil pressure light out of the equation. You reported the oil light illuminates when the connector to the switch is grounded. Connect your Ohm meter and measure resistance from the switch post to ground, key off. The switch should be closed/grounded with no oil pressure, resistance: near 0 [oil light on will come on KOEO]. If the switch is open with no oil pressure (engine off)/ resistance = > 1 < [no oil light KOEO], then the oil pressure switch has failed and has nothing to do with the odd behavior of the "battery/charging" light . . . 1
gstallons Posted September 24 Posted September 24 docc , off the top of my head , these switches : oil press. neut. , etc. are n.c. (normally closed) switches. Wiring diagrams should display n.c. or n.o. next to the switch for clarity and understanding of the circuit. MG does things "their way". 2
Sam P Posted September 24 Author Posted September 24 15 hours ago, docc said: @Sam P, let's try to take the oil pressure light out of the equation. You reported the oil light illuminates when the connector to the switch is grounded. Connect your Ohm meter and measure resistance from the switch post to ground, key off. The switch should be closed/grounded with no oil pressure, resistance: near 0 [oil light on will come on KOEO]. If the switch is open with no oil pressure (engine off)/ resistance = > 1 < [no oil light KOEO], then the oil pressure switch has failed and has nothing to do with the odd behavior of the "battery/charging" light . . . Ohms were, at various DMM settings. (I am stupid, ignorant, uneducated about which is the appropriate or meaningful setting): 70 @ 200 7 @ 2000 0 @ 20K
Sam P Posted September 24 Author Posted September 24 18 hours ago, docc said: Did you start it to see if it charges with the jumper wire to the black wire of the regulator? Next, I would jumper the other side of the connector (battery voltage to the white wire and the connector rotated to connect the black --> red/black. I don't think the light will come on at all in that configuration. Looking for the charging voltage to come up while running above idle. . . -Jumper wire to black wire to regulator: Battery light gradually came on at 3K rpm, and got brighter towards 4K. -Jumper to white wire to reg at idle and revved got no battery light.
docc Posted September 24 Posted September 24 48 minutes ago, Sam P said: Ohms were, at various DMM settings. (I am stupid, ignorant, uneducated about which is the appropriate or meaningful setting): 70 @ 200 7 @ 2000 0 @ 20K This looks, to me, like the switch "works" (at least it is closed when there is no oil pressure). Did you say the oil light came on when you grounded that wire while the key was on?
audiomick Posted September 24 Posted September 24 (edited) 3 hours ago, Sam P said: ... various DMM settings. (I am stupid, ignorant, uneducated about which is the appropriate or meaningful setting): 70 @ 200 7 @ 2000 0 @ 20K You're seeing the same reading there every time. It is 70 Ohm. It shows up as 70 in the 200 range (i.e. "up to 200") because that is the appropriate range. Appropriate because the actual value is in the same order of magnitude as the range. The 7 in the 2000 range is no doubt also 70 Ohm, but doesn't look like it because the decimal point is at a different place in the display. I was having trouble trying to explain this, so I measured a pair of headphones with the DMM in the workshop here. Set to the 200 range, I see 57.8 and off to the right in the display an Ω symbol. So the display can show 3 digits, and in that range it is showing Ohm. In the 2000 range, I see .058 and off to the right the symbol kΩ So in that range, the display is showing kiloohm to three decimal places, and the value is 58 thousendths of 1 kiloohm = 58 Ohm (rounded up from 57.8) And so it goes on, the device only has a couple of digits to work with, and moves the decimal point and the order of magnitude around to suit the range it is supposed to be measuring. The best way of measuring resistance, if you don't know what you are looking for, is to start at the big end (with the probes connected) and step down through the ranges until you get a sensible reading (a whole number of the unit rather than a couple of thousands of the unit a couple of orders of magnitude bigger). This method is even more important measuring volts: your DMM wont like being exposed to 12 V if it is set to read mV. If in doubt, start at the big end of the available ranges and step down until you get a sensible reading. Edited September 24 by audiomick 1
Sam P Posted September 24 Author Posted September 24 2 hours ago, docc said: Did you say the oil light came on when you grounded that wire while the key was on? Yes I did. 1
docc Posted September 24 Posted September 24 3 hours ago, Sam P said: Yes I did. I found my switch post corroded, as well (in spite of my added rubber boot). Did your cleaning that connection allow the oil light to illuminate. now, KOEO? 1
Sam P Posted September 24 Author Posted September 24 2 minutes ago, docc said: I found my switch post rusty, as well (in spite of my added rubber boot). Did your cleaning that connection allow the oil light to illuminate. now, KOEO? No it does not light up KOEO. 1
docc Posted September 24 Posted September 24 Just now, Sam P said: No it does not light up KOEO. Dang. So, the oil light is getting power, since it will light when the wire is grounded and the switch looks closed (no resistance from the switch post to ground), but no light . . . Did you completely remove the wire connector to the switch and test the resistance to ground with the switch post bare? 1
Sam P Posted September 24 Author Posted September 24 18 hours ago, audiomick said: I'd still like to know what the resistance (Ohm) measurement is between the connector for the warning lamp to the regulator (where the blue wire is connected) to ground. If the regulator is behaving correctly, that should be close to zero with the key on, engine off, "infinite" with the engine running and the charging system working properly, and close to zero if the charging system is not working properly. If that is not the case, the regulator might have a problem, or there might be bad connections somewhere else. If it is the case, the warning light circuit would seem to have a problem that is confusing the issue. This is what my DMM shows at all ohm settings between the blue wire and GND.
