Sam P Posted 3 hours ago Author Posted 3 hours ago 17 minutes ago, docc said: Dang. So, the oil light is getting power, since it will light when the wire is grounded and the switch looks closed (no resistance from the switch post to ground), but no light . . . Did you completely remove the wire connector to the switch and test the resistance to ground with the switch post bare? I believe so. I clipped the ohm meter to the post at the red arrow in pic below.
docc Posted 2 hours ago Posted 2 hours ago 4 hours ago, Sam P said: Ohms were, at various DMM settings: 70 @ 200 38 minutes ago, Sam P said: I clipped the ohm meter to the post at the red arrow in pic below. Perhaps 70 Ohms is a bad switch. Near zero would be preferable. A simple Test Light, like @gstallons often recommends, would be a way to test the switch: connect test light to positive--> touch probe to bare switch post. Light? Switch good. No light? Bad switch. If we can get the oil light out of the equation by determining it has nothing to do with the charge light, perhaps the search narrows.
Sam P Posted 2 hours ago Author Posted 2 hours ago 6 minutes ago, docc said: Perhaps 70 Ohms is a bad switch. Near zero would be preferable. A simple Test Light, like @gstallons often recommends, would be a way to test the switch: connect test light to positive--> touch probe to bare switch post. Light? Switch good. No light? Bad switch. If we can get the oil light out of the equation by determining it has nothing to do with the charge light, perhaps the search narrows. Something like this? 2
audiomick Posted 1 hour ago Posted 1 hour ago 2 hours ago, Sam P said: This is what my DMM shows at all ohm settings between the blue wire and GND. That looks like an open circuit = no connection. But if that is between the wire itself and ground, that is to be expected. What I'm interested in is not the incoming wire to ground, but the connection that it plugs on to to ground. And under various conditions: key on, engine off. Engine running. Engine running at the revs where the light has been going on. Ideally: connect the DMM, see what it is showing, turn on the key, see what the DMM is showing, start the motor, see what the DMM is showing, slowly increase the revs and observe what the DMM shows during this. What I'm interested in is if the regulator is switching that contact to ground as it should, or at least under which conditions it is doing so.
docc Posted 1 hour ago Posted 1 hour ago Blue wire to ground, I get 34.6Ω. edit: with the oil switch unplugged, I get open circuit "1" from blue wire to ground. Another indication your oil switch is faulty, but not a clue on the charging issue(s). Oil switch post to ground, I get 1.6Ω. This makes me think your oil pressure switch is faulty and the lack of oil light, KOEO, is not related to the charging issue(s). 1
audiomick Posted 10 minutes ago Posted 10 minutes ago 51 minutes ago, docc said: ... ( I ) think ...the lack of oil light, KOEO, is not related to the charging issue(s). Yes, I think so too. I think it might possibly be related to the charge light not coming on KOEO, but I don't think that is the cause of the charging issue(s) either. I still suspect that there are more than one fault, and that this is confusing the issue(s) somewhat.
