Mike Stewart Posted March 20, 2005 Share Posted March 20, 2005 Hi all, My odometer knob broke last year and the screw is missing. I am thinking of machining a new knob out of aluminum, anyone know what size screw I need and what the thread pitch is for a 2003 bike? Thanks, Mike Link to comment Share on other sites More sharing options...
dlaing Posted March 20, 2005 Share Posted March 20, 2005 I don't know the thread size. A wild guess is 2.5mm. But for sure, it is reverse threaded. Did you ever notice the Luigi emoticon is left handed? Link to comment Share on other sites More sharing options...
Mike Stewart Posted March 20, 2005 Author Share Posted March 20, 2005 David, The pre 03 models have the new gauges along with new problems. The knob is plastic and broke at the end that meets the speedo. There is a little tiny screw that is missing, I guess I can go to my local Guzzi dealer to pick one up , but I wonder how long it will take to get one . Mike Link to comment Share on other sites More sharing options...
Guest Nogbad Posted March 20, 2005 Share Posted March 20, 2005 It's a tiny part so postage wouldn't be more than a letter. I bought a new one for my V11 from The Motor Works. It was expensive though at £13. Motor Works Link to comment Share on other sites More sharing options...
TX REDNECK (R.I.P.) Posted March 20, 2005 Share Posted March 20, 2005 MPH has the knob in stock,as far the threaded stud goes I'm not sure, but it's worth an e-mail to ask. Link to comment Share on other sites More sharing options...
leafman60 Posted March 23, 2005 Share Posted March 23, 2005 Ok boys, I have some experience about this little screw . 03 and afterwards, Guzzi abandoned Veglia, the nice white faced gauges, and went to the, apparently cheaper, ITI (?) gauges with black faces. This changed the speedo drive mechanism and eliminated the separating-prone angle drive that attached the speedo cable to the trans. Okkkkkkkk, the screw. The odo reset knob is a little plastic deal which has a small screw that attaches the knob to a little brass insert that then screws on the odo threaded reset shaft. On all the models Ive seen, the brass insert is too large for the odo threaded shaft. The plastic knob will attach to the female-threaded insert but the insert is too big to thread onto the odo shaft. Well, guess what? They just glued the insert on the threaded shaft. The only fix apparently is to do the same. Screw your plastic knob to the brass insert and then put a dob of epoxy etc on the insert threads and carefully slip it onto the threaded odo shaft. Too soft a glue wont work. It'll twist out. Later, if you need to remove the speedo, you remove the little screw inside the plastic knob that attaches it to the brass insert which is glued to the odometer shaft. Nowwwwww, this thread question perhaps is only about the little knob screw. If the brass insert is still on the odo shaft, you only need the itsy bitsy black screw to attach your knob to the, hopefully, glued insert. I would check a dealer. Jim at Ned's is hard to beat. I gotta go take a nap after all this screw talk. bye Link to comment Share on other sites More sharing options...
Mike Stewart Posted March 24, 2005 Author Share Posted March 24, 2005 Thanks for the input Leafman The upper knob is the stock one that cracks at the end, the lower one is the one I machined up this weekend. The brass piece in the speedo head is a D shape and making a D shape into the knob was a bitch. Anyway, I am still looking for the screw size, I think it is about an 1.8mm or slightly smaller. The new knob fits really tight, a drop of loctite may be the solution. Mike Link to comment Share on other sites More sharing options...
al_roethlisberger Posted March 24, 2005 Share Posted March 24, 2005 Very cool, you should mass manufacture and sell these. I'm sure a lot of folks with ITI gauged bikes will need one eventually Link to comment Share on other sites More sharing options...
Guest h8chains Posted August 12, 2007 Share Posted August 12, 2007 The odo reset knob on my 04 LM with 4K broke off this morning after I put in gas and tried to reset it. The plastic knob just crumbled at the point where it broke off, identical to Mike S. Anyone came up with a fix? I don't really want to buy a replacement piece which eventually will have the same fate. Link to comment Share on other sites More sharing options...
grossohc Posted August 12, 2007 Share Posted August 12, 2007 My reset knob came already broken with the bike , If i was to fix it i would use something aftermarket. But i probably wont bother, what you have never had you dont miss. Gary Link to comment Share on other sites More sharing options...
Wick Posted August 12, 2007 Share Posted August 12, 2007 My Nero Corsa reset knob was broken on delivery, too. The Cafe Sport's knob still works. I have the new knob for the Nero, but the plastic piece came off leaving the brass insert still stuck to the shaft. Plan to get it fixed next trip to Houston. Wick Link to comment Share on other sites More sharing options...
WitchCityBallabio Posted August 12, 2007 Share Posted August 12, 2007 The break on my trip odometer knob is exactly the same as Mike Stewarts. I am also looking for a more permanent fix than just replacing it with another breakable piece. Link to comment Share on other sites More sharing options...
Guest h8chains Posted August 13, 2007 Share Posted August 13, 2007 Time for someone to mass produce this part and make it out of aluminum. I'll look into it and come back with a design and price. Link to comment Share on other sites More sharing options...
JoeV11 Posted August 13, 2007 Share Posted August 13, 2007 I'd buy one, the knob came off last gas stop, at about 3800 miles. I jammed it back and reset the odometer, but I'm sure it won't last much longer. Joe Link to comment Share on other sites More sharing options...
Guest h8chains Posted August 20, 2007 Share Posted August 20, 2007 I would like to take some measurements. Anyone has open up the odometer? Suggestions? This piece is easy to make and I will be able to get a bunch made. Link to comment Share on other sites More sharing options...
