Let me know if it's there now. I have shrunk it slightly.
Maybe 'image scale' doesn't always do what it promises?
67497[/snapback]
Nope. Still flatlining.
  • Replies 68
  • Created
  • Last Reply
Top Posters In This Topic
AAaaaaaaargh! :lol:
It should be hung in the Trophy Cabinet, along with JRT and what's 'is name from the Lesser Attilles
might as well dig it out, give Martin something to do, let's see, here we go,
67503[/snapback]
WHAT!!
Has the pruning begun?
F*** me- mine has disappeared too! Just a line.
67553[/snapback]
I tell you, the Scura section has reached critical mass and everyone's avatar will eventually be sucked over the Scura black hole event horizon distorting into an infinite line of zero thickness as it goes.
The only cure is to disband the gang hut.
67553[/snapback]
Your Wallace and Gromit was working last night. Did you change it again? or are you just joining in the fun?
67567[/snapback]
I tried to change it several times this morning- it kept saying files were too large even though I had used them as avatars on this site before.
Then it accepted one- but just shows a line.
Guy :helmet:
Can I also add to the flatliners Dkgross and Slug.
Did either of you change your your avatars recently or is it working it's way in to the system?
67731[/snapback]
I think Slug has a new avatar now. Is it a new, new one, or the new one that you couldn't see? Are all new avatars going south or what can you see on your 'puter screen now? Do I need to change?
67950[/snapback]
Your flat line has has gone but still no avatar. Slug is still flat lining :huh2:
And Goren aswell.
Don't know what's going on, but I have no problems with avatars. (FireFox on XP) I have uploaded a new avatar - not resized by me, but by the forumsoftware, Let me know what you see. I also uploaded it:
67981[/snapback]
Couldn't halp noticing that your Avatar had grown to GIANT size.
It's a giant size YOU. Is it meant to be the bolts picture that is in your post? If so, looks like the same problem that I've had before: old avatar changes to size of new avatar but doesn't show the new picture.
EDIT
No, it's ok. I did a refresh and the Giant You has now changed to the new bolts/screws picture.
I can see all the avatars, btw.
Jaap you're flatlining :(
I use Windows XP sp2 and IE
work has a Windows NT and IE
It seems that every reposted avatar comes up as a flat line
edit - just seen BFG's post :( still doesn't work for me
I altered a setting in the avatar upload section.
Could you try again? When uploading you can set it to your own dimensions. Just fill in the width (max 150 px) and the height will adjust automatically.
Dunno if this helps, but it's worth a try.
67995[/snapback]
Stll the same for me :(
