kjrowe Posted March 2, 2020 Share Posted March 2, 2020 trying to find the size of my fork seals for the tenni ta Link to comment Share on other sites More sharing options...
LowRyter Posted March 2, 2020 Share Posted March 2, 2020 http://www.harpermoto.com/parts-lookup/2000-2009-moto-guzzis/v-11-le-mans-sport-naked-1100-2001-2002/front-fork-ii-en-2-3.html You might check here. Link to comment Share on other sites More sharing options...
pete roper Posted March 3, 2020 Share Posted March 3, 2020 40x52x9.5 Link to comment Share on other sites More sharing options...
gstallons Posted March 3, 2020 Share Posted March 3, 2020 17 hours ago, kjrowe said: trying to find the size of my fork seals for the tenni ta Ohlins or Marzocchi design #1 or design #2 ? Link to comment Share on other sites More sharing options...
pete roper Posted March 3, 2020 Share Posted March 3, 2020 If it's a LeMans I thought they all had Marzocchis? Link to comment Share on other sites More sharing options...
gstallons Posted March 3, 2020 Share Posted March 3, 2020 As long as they weren't swapped out . Link to comment Share on other sites More sharing options...
kjrowe Posted March 6, 2020 Author Share Posted March 6, 2020 Quote @gstallons: Marzocchi design #1 or design #2 ? they are marzocchis please explain the difference between the #1 and #2 I have found some seals with luck they are the correct size. will let you know once the job is done thanks Link to comment Share on other sites More sharing options...
gstallons Posted March 6, 2020 Share Posted March 6, 2020 I'm not near anything to dhow you the difference . the fork caps are visibly different . Hopefully someone will show pics . I found this out when I ordered seals , bushings , etc . for mine . The 2002/2003ish V11 Sport . I can't remember if the bare aluminum / black upper fork is a factor or not . Link to comment Share on other sites More sharing options...
docc Posted March 6, 2020 Share Posted March 6, 2020 18 minutes ago, gstallons said: I'm not near anything to dhow you the difference . the fork caps are visibly different . Hopefully someone will show pics . I found this out when I ordered seals , bushings , etc . for mine . The 2002/2003ish V11 Sport . I can't remember if the bare aluminum / black upper fork is a factor or not . Good point, here. Early V11 (1999-2002 + early-2003-carryovers) are smaller diameter forks than the later V11 Marzocchi . . . Is it 41 mm, then 43 mm? Either way, the 2002 Tenni should be the early V11 Marzocchi spec . . . , yes? Link to comment Share on other sites More sharing options...
nobleswood Posted March 6, 2020 Share Posted March 6, 2020 I'm going to digress slightly here; I'm searching for seals & dust caps for my Griso & rather than use OEM wanted to try SKF seals, which I've heard good things about. But I haven't found a source yet. Any pointers ? Link to comment Share on other sites More sharing options...
gstallons Posted March 7, 2020 Share Posted March 7, 2020 Whatever you do , make sure you do NOT damage the bore of the fork where the seal goes into the fork tube . When you install , lube everything liberally going back together . Use the be$t fluid and measure it exact when it goes together, use good towels & gloves to keep ANYTHING foreign away . Don't be upset if they leak . They will do this for about a month or two . 1 Link to comment Share on other sites More sharing options...
gstallons Posted March 7, 2020 Share Posted March 7, 2020 14 hours ago, nobleswood said: I'm going to digress slightly here; I'm searching for seals & dust caps for my Griso & rather than use OEM wanted to try SKF seals, which I've heard good things about. But I haven't found a source yet. Any pointers ? Mmmmm . If you can get #s , you can see about different brands . Check different vendors and see what they have to offer . Unless there is something super out there , I would go back w/OEM . Link to comment Share on other sites More sharing options...
