68C 226 Posted January 9 Report Share Posted January 9 Does anyone know the correct name for the black plastic covers over the Grisso 2V type valve covers. I want to fit the tidier valve covers, got the covers but cannot find the plastic parts. Do I need special HT leads? Quote Link to post Share on other sites
gstallons 696 Posted January 9 Report Share Posted January 9 You will (probably) have to go to a MG dealership or find an online catalog for these parts . Good luck 1 Quote Link to post Share on other sites
Lucky Phil 1,758 Posted January 9 Report Share Posted January 9 2 hours ago, 68C said: Does anyone know the correct name for the black plastic covers over the Grisso 2V type valve covers. I want to fit the tidier valve covers, got the covers but cannot find the plastic parts. Do I need special HT leads? I fitted Griso covers to my 2 Valve engine. Part number you need for the covers is 06941000 (2off) Std HT leads and caps fit. Ciao 1 1 Quote Link to post Share on other sites
Tom in Virginia 138 Posted January 9 Report Share Posted January 9 https://www.stein-dinse.biz/ I've had good luck with these guys on many different MG models. 1 Quote Link to post Share on other sites
68C 226 Posted January 9 Author Report Share Posted January 9 Many thanks, will start hunting for them. Lucky Phil, I think it was your bike that set me of down this trail. Quote Link to post Share on other sites
Lucky Phil 1,758 Posted January 9 Report Share Posted January 9 4 hours ago, 68C said: Many thanks, will start hunting for them. Lucky Phil, I think it was your bike that set me of down this trail. Like this Ciao 1 2 Quote Link to post Share on other sites
68C 226 Posted January 10 Author Report Share Posted January 10 Does the spark plug cover act as a protection for the silly fell over while manouvering bike type of damage? Quote Link to post Share on other sites
Lucky Phil 1,758 Posted January 10 Report Share Posted January 10 3 minutes ago, 68C said: Does the spark plug cover act as a protection for the silly fell over while manouvering bike type of damage? Yes, the cover and the black protector are different pieces. The protector is p/n 06023400 2off. Ciao Quote Link to post Share on other sites
docc 3,367 Posted January 10 Report Share Posted January 10 23 hours ago, 68C said: Many thanks, will start hunting for them. Lucky Phil, I think it was your bike that set me of down this trail. Careful just how far you try to follow the likes of Lucky Phil! 1 Quote Link to post Share on other sites
rosso corsa 36 Posted January 10 Report Share Posted January 10 Is there an advantage in these 1200 2v valve covers or is it just a matter of aesthetics? Quote Link to post Share on other sites
Lucky Phil 1,758 Posted January 10 Report Share Posted January 10 1 hour ago, rosso corsa said: Is there an advantage in these 1200 2v valve covers or is it just a matter of aesthetics? Aesthetics mainly but the integrated protectors are a nice thing to have. Ciao Quote Link to post Share on other sites
Lucky Phil 1,758 Posted January 10 Report Share Posted January 10 5 hours ago, docc said: Careful just how far you try to follow the likes of Lucky Phil! Yes docc, wise words indeed. Ciao 1 2 Quote Link to post Share on other sites
pete roper 463 Posted January 11 Report Share Posted January 11 One word of advice if you are using the later, final model, rocker covers, either Griso/Sport or Breva/Norge/Bellagio. Do not even bother trying to use the older type gaskets. For some reason, I have no idea why, these invariably split and get pushed out from between the cover and the head. While there doesn't seem to be any fathomable reason for this behaviour, the mating surfaces are identical, the fasteners are in the same place, it's just "One of those things"! Purchase a pair of the Valpollini *Metal* gaskets. They last pretty much forever and won't squeeze out. 1 1 Quote Link to post Share on other sites
docc 3,367 Posted January 11 Report Share Posted January 11 2 hours ago, pete roper said: One word of advice if you are using the later, final model, rocker covers, either Griso/Sport or Breva/Norge/Bellagio. Do not even bother trying to use the older type gaskets. For some reason, I have no idea why, these invariably split and get pushed out from between the cover and the head. While there doesn't seem to be any fathomable reason for this behaviour, the mating surfaces are identical, the fasteners are in the same place, it's just "One of those things"! Purchase a pair of the Valpollini *Metal* gaskets. They last pretty much forever and won't squeeze out. Truth and wisdom. Quote Link to post Share on other sites
Goofman 46 Posted January 11 Report Share Posted January 11 I can definitely bear witness to that fact! One ruined road boot, one hand cut gasket, several helping hands, a quart of oil, and 12 thousand (two-services) miles later, the Valpollini gaskets work. 1 Quote Link to post Share on other sites
Join the conversation
