dangerous Posted January 18, 2017 Share Posted January 18, 2017 hey you guys with air PODs and ECU's do you people have the air temp censer from the air box connected?just been trying to fine tune mine and have found it prefers NOT to have the censor connected, Im thinking as it is between the V that its just to hot and keeps leaning the fuel mix. I noted that the laptop was reading 46* when I conected the puter up less the sencer it read 18 and after a ride went to 23 much lower BUT WTF it shouldnt read anything if its not there weird as but no snuff outs at low revs so all good even tho the puter showe a a air sencor fault. Link to comment Share on other sites More sharing options...
bbolesaz Posted January 18, 2017 Share Posted January 18, 2017 ECU software probably computes a "nominal" value for air temp, just to keep the maps in the ballpark if the air temp sensor fails. Link to comment Share on other sites More sharing options...
MartyNZ Posted January 19, 2017 Share Posted January 19, 2017 Hi DD,If your sensor is feeling hot air off the engine, the ECU will lean the fuel more than it should. Here are a couple of comments about location of the intake air sensor with pod filters. Ed Rosso extended the sensor cable to put the sensor further back into intake air. http://www.v11lemans.com/forums/index.php?showtopic=18906&do=findComment&comment=203711Kiwi Roy moved the sensor up near the steering head.http://www.v11lemans.com/forums/index.php?showtopic=18960&do=findComment&comment=203548I can splice in extra length to your cable if you want to try one of these ideas. Link to comment Share on other sites More sharing options...
Chuck Posted January 19, 2017 Share Posted January 19, 2017 Apples and oranges, maybe.. but on the Aero engine, they mounted the sensor on the end of the pod. Link to comment Share on other sites More sharing options...
GuzziMoto Posted January 19, 2017 Share Posted January 19, 2017 I would put the sensor in as cool a location as possible. I also like giving it airflow. Avoid heat and anything that would trap heat. In the intake tract is a great spot for it. But I am an airbox guy for the most part, only my Daytona runs without an airbox (and that is because it is modified to far, the original air box don't fit anymore). Link to comment Share on other sites More sharing options...
swooshdave Posted May 20, 2017 Share Posted May 20, 2017 A typical mod on any EFI engine with an air temp sensor is to put it somewhere cool to richen the mixture. That was before the days when you could just remap. Link to comment Share on other sites More sharing options...
