    1,188
  1. What's the manual say for gearbox oil change interval? Is it 6000 miles? Sounds like too long if shifting degrades before then. What do you think 3000 miles or at every engine oil change?
  2. docc
    Red Wheels!
    Rich, is that a 160/60 or 160/70?
  3. If your bike shifts down easier than up it sounds like you need to adjust the pawl engagement.
  4. docc
    Red Wheels!
    Now there's a plague to be wary of.
  5. docc
    Lemon Law?
    Carl, Are you talking about the Tekno semi-soft saddlebags? If so, where does the Loktite go? (Hey! You mean stuff falls off these bikes?!)
  6. It occurred to me you might want to bleed your clutch hydraulics as well. Looking for all the 'simple' maintenance and adjustment items for a simple solution. When my V11sport was shifting poorly the most common advice I received was, " romove boot, insert new more aggressive foot." Also, the idea that something inside the box was amiss (which does happen but let's hope. . . ). As it turned out, some careful fettling made a huge difference. Typical Guzzi , just wants to be fettled!
  7. docc
    Red Wheels!
    Rich, that looks so goog it hurts! now my silly silver wheels look so dull. I'll try to drink more and get over it. What did you cut your spring spacers from?
  8. docc
    Lemon Law?
    Buck, sorry to hear your trials with the leMans. I remember calling MGNA saying, "aren't you embarrassed this bike has been in the shop so long (3months), shouldn't you do something to show this is such an UNUSUAL situation? There was just silence on the phone. Now I find (from these forums) 3 months is pretty typical. It bites, really. I didn't know , when I got my new V11 sport, that I was getting a 'project bike.' Yet, after alll the fettling, tinkering and tampering this remains a challenging and interesting project. It is not unlike what I imagine Maserati ownership to be like. With those 3 BMW's you just have to decide how much energy it's worth to have such a splinter-fringe ride. Coming to the forums for encouragement, spinning your own tools and taking satisfaction in making the leMans right may be your solace in the process of having a relationship with your Guzzi. It's true, I own a Honda but I have a relationship with my coy, provocative Moto Guzzi.
  9. I complained to my dealer of this problem saying, ' let's replace an o-ring or the right injector.' He says 'no, the fix is to replace the whole rack ' (both throttle bobies, injectors, linkage and TPS). The 'rack' won't come out without lifting the frame off the drive line. Once refitted the right throttle body still dripped. I have to give MGNA and the dealer credit for trying to please me, replacing the whole rack. As it turns out the drip is aggravated by brief on-off modes. (Like cranking up to listen to the exhaust music or for some reason turning the key on without starting). In normal operation very little leak is apparent. It is important not to pressurize the FI system without a normal ride.
  10. Joe, how many miles on your sport? Could it be time to change the gear oil and adjust/grease the shift mechanism? Also, there is an adjustment by the shifter to center the pawl engagement. Rich had said that the return spring problems were an '02 phenomenon. Good luck, docc
  11. Jim, I just swapped oil in my sport yesterday. With the oil warm I refilled 3 quarts. I'll recheck it once it's stirred again to be sure it's on the mark. look well ahead, docc
  12. I've noticed several pictures of spine frames with a stand under the frame side plates. Are these conventional swingarm stands or.... Where can I find a good quality support for my V1s? Thanxx, docc
  13. It's funny: on some of the other boards it's the dreaded 'oil thread' that keeps resurfacing. Here on the V11 site we just can't get enough of suspension. After reading all the threads I could find on this I made some changes to my 00 V11s. I had followed the advice of an 1100i rider and gradually moved all my damping sttings to max. Recently I found some good info at guzzitech.com written by Ed. I set fr & rr rebound 75% and fr & rr compression 50%. The bike is so much nicer to ride. Much more compliant on the imperfect roads I ride. Now, I'm 160# plus gear and the sport's forks sag 45mm from full extension. "Too much," everyone says. Bottom line seems to be the bikes are sprung soft and overdamped. I'm planning to change fork oil to 5wt and add a 10mm spacer, drop the triple clamp 10-15mm. Suspension tuning on the cheap. For your weight most riders would recommend a spring upgrade (still pretty inexpensive). What year is you sport, which rear shock does it have and have you put many miles on it? Good riding! docc
  14. You're right about using the GPS. I'll have to enlist some help from the sport-tour guys . Beats averaging out those last three or four tickets. Those guys say their method of speed determination is rather accurate.
  15. Still, do you think that 6% translates to the odometer as well?
  16. Travelling I 65 the other day, leading a Lemans IV, I began counting seconds past mile markers(using my added dash clock with sweep second hand). For 4 or 5 trials , showing 80 on the speedo, I kept getting 48 or 49 second miles. That translates to 74.23 mph !! Is the speedo really that botched? My buddy said his LMIV was also showing 80. Next time on the slab I guess I'll crank up to 85 (a true 79?). Now my question for you , the gurus of Guzzi: If the speedo is off by 7%, is the odometer also off by 7%? If so I don't have 20,000 on the sport, only 18,600???
  17. I fried the rear brake side bearing on my 2000 sport at low miles (around 12000). It was replaced by warranty (OK, I replaced it but MGNA provided the part). This was during a time I was trail braking heavily with the rear brake to keep the driveline from unlocking while cornering. BAD IDEA! This technique ate the rear brake and cooked out the rear bearing grease. Now I 'trail brake' with the front(per Pridmore) with better results and (hopefully) no more bearing failures. Look well ahead! docc
  18. Rich, had a buddy experience night mares with wheelbearings after powdercoating some wheels from a Honda VFR. Apparently from the heat affecting the roundness of the seating surface for the bearing. Hopefully you'll have none of this but just keep an eye on those bearings. i'm jealous! Red wheels? What color is your sport and won't you please treat us to a picture when it is back on its tires? Look well ahead, docc
  19. docc
    v65 SP
    The Rider Course is such good advice! A great place for a new rider to 'get their sea legs'. Will there be Breva's in the US? Maybe an expensive beginner's bike but a nice addition to the shop, yes?
  20. Cliff, I had slowly increased my steering damping on my 00 V11sport to compensate for the wear in the front tire. After reading your post (and changing the front tire) I backed the damper all the way off. Felt like the bike lost 75 pounds! On the "some tires - some bikes" discussion: I remember the Pirelli Dragon Corsa that came on the sport. Very nervous tire. Just like Carl was describing, like it would not 'settle down' yet would turn in very sharply. That pirelli has the pronouced 'vee' shape of a roadrace tire. No doubt the V11s is much friendlier on the road with a rounder profile. Look well ahead, docc
  21. While refitting a Merkur (Ford Sierra) i read the opinion that the vast majority of electrical problems can be traced to connections and conductivity. I've found this to be largely true (on the Ford and on an older bike I spent 4 years unravelling). Sure, you could have component failure, but it's worth your time to clean and inspect the harness and connections first. Good hunting and keep us posted! docc
  22. My sales brochure for the 2000 V11 sport says the clip-ons are "adjustable in both width and height." I thought the 'security pins' were for shipping. And, anyway, they're quite secure in that bag with my security reflectors, security off-road plaques and security vapor cannisters. As long as the clip-on pinch bolts are properly torqued to the forks and there are no clearance or binding issues you should be able to position them where you like. The fully adjustable controls are one of the terrific, little noted, features of these bikes. Ride well, docc
  23. I like the 'committed' riding posture of the v11 sport. With the Stucchi fly screen wind lift is reasonable at freeway speeds (70-90). Rather than change the clip-ons, I rotated mine all the way back after losing the little locator bolts that offer only three positions. It brings the torso a little more upright, shortens the reach, without any extensive changes. Without the 'locator bolts' you can lower the clip-ons as well. Handlbars must really change the whole feel of the bike. I'm sure it would enhance the comfort for us "medium-old" guys!
  24. I dunno. 60% of 170 is 102mm and 70% of160 is 112 mm making the 160/70 a taller tire , therefor more circumference. yet if you could figure actual tire size this way ( I'm not convinced the real measure comes out like this) the 160/70 would be 20mm (3/4") taller! It just seems incredible. Using the same questionable method makes a 160/60 12mm (1/2") shorter. Still there's got to be enough difference in the circumference to skew the gas mileage computation from speedo error. Yet:taller tire= taller gear=more fuel economy. Damn, now I'm dizzy again !
  25. My theory on tires for bikes has always been, "try something new. If you don't like it , it'll be worn out pretty soon anyway." It sounds like the concensus is 160/60-17. I'm hearing Bridgestone but isn't there a good handling decent mileage alternative? Ride well, docc
