    1,188
  1. Tonight i re-adjusted the 'pawl ' engagement. Technically referred to as the adjustment of the hook effect of the preselector. I had observed upshifts passed a gear and downshifts fell short. upon checking the adjuster I find that it had 'migrated ' off center. After resetting it to center missed shifts have *almost* disappeared! The adjustment is very sensitive as the shaft only rotates about 60 degrees moving the foot lever perhaps 5-6 mm. As Rich says, "This bike loves to have everything 'just so'."
  2. Gio, Thanks for taking the time to give us a procedure on this. I would expect about a full turn of the thumbwheel to move the mercury 2 cm. Holding the throttle steady "off idle" should stabilize the columns. This is 1500-2000 RPM and up to perhaps 3000 rpm. Use caution releasing the throttle as the vacuum will increase and you don't want the motor to ingest the mercury! Do the Hg columns still jump around at a steady, off-idle throttle?
  3. I've read long debates on what might spring seal leaks. The jury is still out. I put some moly in my gearbox last change hoping to improve shifting. It didn't. It just made it harder to evaluate the condition of the fluid upon changing the next time. Back to Bel-Ray. NOTE: The rear drive does hold 370 ml(cc) of which 20 cc is moly. The Guzzi stuff is good (shake well!), part number K660032. Now this: When my box miisses a gear I have observed it goes completely past it , into neutral before the next gear. This has been occurring now on the downshift as well. It has taken some time to confirm this observation. I find that if the box misses I shift BACK the other way to find the intended gear. This occurs more in hard acceleration (deceleration) and aggressive shifting. All other Guzzisti are saying, "You must shift very hard and with a long throw." While this may be true for the 5-speed I am now questioning this logic for the 6-speed. After studying enlargments from the manual detailing the 'preselector' mechanism, I reduced the leverage at the foot lever (lower hole) and at the splined shaft (rotated the input lever back so as to reduce its leverage while shortening the rod to its minimum length). I then took a ride purposefully minimizing inputs to the shift lever. The (tentative) result: many less missed shifts. It appears the preselector can be kicked into overtravel fairly easily. Under warraanty I will be disassembling my side cover (preselector cover) to better examine the workings. As always I will let you know what is found. I am confident we can make this mechanism shift more reliably. Now, my question to you: when your gearbox misses shifts, does it fall short of the next gear, or 'pass' it?
  4. docc
    WP
    Paoli?? My Ducati friends say "pay-o-la." Do you think they're really any better than the Marzocchis?
  5. Al, I'd need one of those nifty digicams to do it up right. Plus, I feel like the "How - To" threads otta be penned by someone more qualified than just tinkerin' me. One of the things that complicates it is how much we've each changed our bikes. Lot's of different exhaust, air filters and then there are Power Commanders. It's a case of what works for me may not work for you.Further, some of us are hacking into the ECU with a voltmeter and others are using software and a PC. How would we proceed with a task like that? Gio, yes, the 'idle screw' would be the horizontal stop screw which determines the minimum opening of the throttle at idle. The manual calls it the "adjustment screw." It is also careful to say not to use it to adjust the idle ! The idle is a balancing act between the CO level, TPS setting, air bypass and synchronization. BTW, what is "LHS?"
  6. Check out the "spitting and Popping "thread. This requires a digital voltmeter, synchronizing tool and , I prefer, sinlgle malt scotch .
  7. The manual says to : Set the TPS Adjust the idle (best done with the left idle screw, defeating the right completely) Balance with the air bypass closed Reset the idle Warm up and check the CO Reset the idle and check the balance The manual actually says more than this, as you know. Every time you change one setting it affects the others, like a cat chasing its tail. As Dave Richardson says in "Guzziology" going over and over the procedure brings you closer and closer to the optimum. You can "back probe" the ECU connector but straight pins work better than paper clips. Black/violet is positive and violet is negative. I have found 525 mV (3.6 degrees open) at idle to be rather rich. This is why opening the air screws a bit more will often smooth out the unstable idle. All of this , of course, IMHO after fussing, fiddling and fettling 24,000 miles.
  8. Gio, No question you are out of synch if the cylinders vary over 0.5 cm Hg. It is best to bring the cylinders into synch 'off idle' and see that that they remain so as rpm rises. This is dine eith the idle air bypass screws closed. It is recommended to add a 'jam nut' to the thumb wheel to keep the linkage from changing. Being certain the TPS is correct, then set idle at 1050+/- 50 and back out the idle screws 1/2 turn. Frankly, I find the motor to idle more reliably at 3/4 turn and 1100+/-50rpm. Gio, I could not understand your TPS measurement. I have seen millivolts (525 mV) and degrees opening (3.6 degrees). I am thinking the 'vent tubes' Jason mentions are the hoses for the US spec vapor cannisters.
  9. I found my dealer's extent of tuning went something like, " it starts, it runs, don't touch it." A little extra time with the synchronizing has worked wonders. Those electronic synchronizers ( I use mercury) are probably worth their weight. Fettling the TPS and idle settings will bring you ever closer to that Zen state of Guzzi idle. Learning to do it yourself is easy and very satisfying.
  10. So, now that we know Lindeman has the experience to rework our marzocchis reliably, who can rework this Sachs unit? Tell me it's not a throw away! At 160 pounds the rear is not too bad (bad, but not TOO bad ) Until I loaded the Tekno bags for the mountains. The racks carry them BEHIND the axle and really lift the front. "Boing" is not a performance term!
  11. Turning the key on and off a few times should purge the fuel delivery system without having to run the bike. Also, Gio, is the tank pulling a vacuum? Check this by being sure the cap will open without suction.
  12. I figured extra fittings would translate to extra places to leak. At that pressure the stuff could atomize through a small leak and form an external combustion engine between your knees! David, did you still have to lengthen the fuel line for the IsuZu filter? If so, how much, just an inch?
  13. Just returned from the local parts haus,sitting on a case of Pennzoil reding the Prolator application charts. I gotta getta life! The welded filter is, as you say, for IsuZu. All '01 and '02 as well as Trooper '92 to '02. It is a very stout looking device , about an inch shorter than the Weber but longer than the Nissan application which is crimped onto a plastic end. The welded filter appeals to me as I have observed any number of vibration related failures on the Sport. I'd rather not see one with fuel pressure behind it! At $7US I think I can afford to change it every 6000 miles. With the filter piggy-backed to the frame the straight connectios look to be the way to go.
  14. Interesting. I've just played this same filter game. After finding the threaded connectors were not for the V11LM/S I fitted the Nissan application and began to research. I found extremely helpful technical assistance from a fellow (motorcyclist) at Pureoil (Purolator filters). He was very patient with my series of e-mails and provided me with dimensioned diagrams and the following technical specifications: The filters do all, generally, filter 7-11 microns (Guzzi calls for 10 microns) and are tested at 4 bar (58 psi). Guzzi FI runs 3 bar +/- 0.2 (41 - 46 psi). So, filtration and pressure should be covered. This brings us to the issues of surface area and flow rate. The "Nissan" filter ( Purolator F43178) has 630cm2 surface area and flows 24 gallons per hour (the OEM Weber has 1200 cm2 and probably flows more like 45 gph). Remember that the closed loop FI flows unused fuel back to the tank through the pressure adjuster on the right side of the tank so that the majority of fuel flowed is not injected but returned. If you fit the "Nissan" filter it is much shorter and requires a longer fuel line from the pump. In searching for a longer filter for increased flow and surface area I found the following alternatives (again, Purolator numbers): F54718 used on Dodge Dakota V6/V8 is longer and has a bracket to be removed. More expensive due to the bracket ($11US) F67221 is LAZER welded to hold 300 psi, flows 45 gph and has 580 cm2 surface area. It is 5 3/4 inches long and should be the closest in overall dimension to the Weber. I'm not sure what its application is but I will check and post back. (Around $8 compared to the Weber from Guzzi at $33US). The F67221 is a better choice than the"Nissan" (F43178) due to its strength and dimension (may still require a longer fuel line). They'll probably both work just fine. Realize that less surface area means shorter service interval. Guzzi says 12000miles so a 6000 mile interval is extremely conservative for the smaller filter. If you made it this far on this post, congatulations, you are now a 'certifiable' techno-head!
  15. The ongoing saga of the "11 speed" Guzzi box: returning from an agressive 640 mile ride I must find a dealer to inspect the function of the gearbox. So many times the box 'passes ' a gear upshifting. Especially in the higher RPM when trying to keep acceleration. Now. on this ride, I discover the same malady downshifting. Very dangerous approaching a decreasing radius switchback in the mountains with other riders behind to downshift out of gear not knowing what gear the box will engage once coaxed into any availabe cog. I have tried all techniques of preloading, aggressive shifting, linkage adjustments, pawl engagment adjustment, oil change, moly additive, clutch service, RPM matching. I say it 'passes' a gear because I have found it to engage the next gear( down or up ) by going 'back' for it. Forcing the the shift further 'skips' a gear. Something is allowing the mechanism to 'overtravel' and miss the next gear in the sequence. This is a hard concept to express in words. Try this: if your box hits false neutral, shift back the opposite way and see if it engages the gear you were intending. A couple of questions: first, is there any possibillity the return spring is causing this? Second, have the part numbers for the return spring changed over the four year production of the 6-speed gearbox? Your help is ever appreciated. I must do something to solve this as the failure to shift reliably threatened the safety of myself and other riders.
  16. After this weekend ride my BT 020 front will be ready for the ashcan. What do you guys think of running this new Michelin ST with the 160/60 BT 020 rear?
  17. I'm running 020's front and rear. What's the advantage of the 010 up front?
  18. I made a few posts on ST.N. Face it, if you want to talk Guzzi you're in the right place right here. Al won't even talk to me over there. And you know how he "chats" . . . Seriously, I did get some good feedback on current road conditions in the North Carolina and Georgia mountains where I'm taking the sport in a few days. So, thanks , Al!
  19. With my sport's tps set to spec the bike runs a bit rich and behaves at idle as you describe.(Worse when hot in hot weather). At 23,000 miles I found that it was much more stable idling with the air bypass at 1 full turn. I'm trying 3/4 turn now to see how it will behave.
  20. 'Zat make it a 'hand' stand?
  21. Apparently, the early spine frames had the stand mounted even FURTHER forward. It was moved back on the 1100i.
  22. In Greg Field's book"Moto Guzzi Big Twins" John Wittner talks about getting the "polar moment of inertia" of the motor aligned with that of the bike's polar moment in a lean. On the race bikes he acheived this through very high spring rates untenable for the street. The real advantage and impetus for the six-speed was to lower the output shaft so the motor could be rotated down to better align the polar moments. Adding the sixth cog was probably more for marketing IMO. While Wittner is no engineer either, he had the chance to work this out on the track then join the design team at MG to develop and refine what we're riding. I, for one, am eternally grateful. docc feeling all in the groove with my polar moments all aligned
  23. Honestly, I've only touched down a few times. I'm of the opinion that touching down hard parts is an indication you've screwed up and blown your entry speed or line. I still can't see any other way that bolt could have bent. Haven't touched anything down since this last suspension revision. Headed to the north Georgia mountains next weekend and may find the limits there . . . There's this road called "War Woman Road" . . .
  24. I got my aluminum cup wrench from my Guzzi dealer to the tune of 50 or 60 dollars. It really is a nicely machined piece. But when it arrived it lacks the hex drive to remove the cover. I found that the axle nut can be used to remove the cover.
  25. Many of us have learned the side stand is first to ground in deep lefthanders. It has a springy, forgiving zing much like a spring loaded foot peg without the vibration to the boot. I found the stock LaFranconi to ground in right handers but haven't touched anything down on the right since changing to the round Mitsrals. Going over the bike carefully for a trip to the mountains I found a bent bolt that activates the side stand switch. Apparently it touched down in deep left cornering. Failing to activate the switch, the system thinks the stand is always up. Not a good thing if the bugger is down waiting to trip you up in that first lefthander. So, give it a look and be sure your side stand switch is telling the truth
