GuzziMoto
    48
  1. If you have stainless exhaust pipes, which modern Guzzi's do, then wrapping them should not cause any issues with corrosion or heat damage. Mild steel exhaust pipes will get destroyed if you wrap them, but stainless is generally fine. While the science of keeping the heat in the exhaust gases to improve performance is sound, as mentioned there is not likely to be any performance advantage to wrapping the pipes on a Guzzi. It becomes a style/personal taste thing. As long as you have stainless pipes you should not suffer any damage from doing the wrapping and there are a few people who have wrapped the pipes on their Guzzi's to prove that. But I don't think anyone here has any illusions about power gains from the practice. It will help prevent you from burning yourself on the exhaust pipes, but that is about the only "advantage" other then the look.
  2. Once the initial issue occurred and the lifter wore thru the surface the rest of the wear was inevitable. Meaning once the wear started it was not going to stop. The amount of wear beyond the initial failure is a function of how long the motor was run after the failure occurred. If the lifter was not hardened properly the failure was just a matter of time. If the failure was oil related then it may only be a matter of time before another lifter does the same thing. I would replace all four lifters and the cam as it seems like a small price to pay to be sure the the issue is fully repaired.
  3. Well, I would agree. Guzzi is having some design issues lately. I own a Griso and that is a great looking bike (that is why I bought it, but I really wanted the prototype with the 4 valve motor). But the other bikes either do not appeal to me (the Stelvio, it is okay looking for what it is but I have no use for a two wheeled SUV), are down right unattractive (Breva, Norge, and 1200 Sport(?)), or are too slow (V7 variants ). Of course that is just my opinion. Guzzi do sell more motorcycles now then they used to, so what do I know. But while I would have bought a street legal version of the MGS01, I have not seen anything in their current lineup other then the Griso that appeals to me. I do wish I had a 4 valve motor in my Griso but I am not buying another just for that. My Griso share it's home with the wife's V11 and V65 Lario as well as my '93 Daytona. I wish Guzzi would build something new that is exciting. Maybe the new water cooled motor will be that opportunity. That could be something. Maybe they will use the new motor as a chance to redesign some things. Shortening up the total length of the motor and trans, maybe by integrating them, plus finally building a motor with modern power output would be nice Put that in a shorter version of the MGS01 or a Griso and I would buy a new Guzzi. But I am pretty sure that will not happen. I wonder when, if ever, Guzzi will build another bike that appeals to me.
  4. Where is it understeering in the corners, on the way in, mid-corner, or on the gas coming out? I think most of the surprise here is because most of us have found the V11 to be a well handling bike. Based on my own experiences I could see someone not being happy with a red frame bike but not for the reasons you quoted, I have found it to be very lively and communicative from the front almost to the point where some might think it is too much. But to hear someone say it is "vague" makes me wonder.... It could be an issue of communication between us, I may not understand what you mean by "vague". But it does make me question if there was not an issue like a bad steering dampener or something that was causing this. It just does not seem like a common complaint. I meant no harm. In fact, a guy willing to cut the front end off and then weld it back at a different angle has my respect. It is just that I would have welded it back on with a steeper rake given the option, not a shallower one. At least a few people have done that with Daytona's. But red frame V11's have good rake and trail number from the factory in my opinion. Again, no disrespect meant. Instead, much respect for having the ability to do what you did. I just hope it does what you expect. PS.... The entire GSXR front end was about $600. All it took to fit was different head bearings. I did upgrade to a modern Brembo radial master cylinder as well. That was another $350. All in all well worth the money.
  5. Well, to each their own. I'm not sure about the wisdom of what you have done (adding trail but also decreasing rake and taking weight off the front wheel) but if it makes the bike more of what you want.... There are easier ways of adding trail and/or decreasing the rake like offset bearings, triples with different offsets, even sliding the forks down in the triples (could require tube extensions to get the kind of changes you went for) that would be un-doable if you ever wanted to return the handling back to stock. By the way, stock the V11 is right there with the other bikes you mentioned, maybe a little more conservative if anything. There is nothing overly aggressive about the geometry of a V11. The funny thing is the early red frame bikes have a slightly steeper rake and a slightly more aggressive feel, you could have just swapped over to a later black frame bike to get at least part of the change you went for. Some of us actually prefer the red frame bikes for their quicker steering and more precise handling. The wife's red frame V11 (a 2000 model) had handling issues that went away when we removed the steering dampener (it was binding). Things improved more when I modified the forks so they actually had compression dampening (stock that fork only has adjustable hydraulic bump stops). Also tire choice and tire pressure have a large part to play. And for the on/off throttle transitions making sure the throttle cables have the minimum amount of slack possible helps a lot, as does proper injection set up. Riding technique may play a part as well, but from what I have seen people I have watched hop on a Guzzi have not had an issue adapting. But you do use the clutch a little more then you might on some other bikes to smooth the throttle transitions out. My Daytona I upgraded to GSXR forks, they work much better and the triples have less offset for more trail but they are slightly shorter so the rake is slightly steeper with a hair more weight on the front wheel, all good things. I have another set for the wifes V11 but have not mounted them yet, all it takes is different steering head bearings so maybe this winter. They are cheap and readily available front ends. I use the forks, wheels, brakes, etc. Upgrade the whole package. The wife's V11 also has a Penske shock but that was because the stock shock suffered the common shock eye cracking issue. But it does work better with the Penske. Did you ask anyone about your handling issues before you cut it? Seems like they would have been fixable. Well, I hope it is welded back on straight and safe. Best of luck with it.
  6. Yes, Pete. I would be interested in one for the wife's V11. Michael
  7. The wife's V11 is an early red frame version. It's forks are likely different then later versions. I closed off some of the open port that allows oil to freely flow during most of the forks travel. As built the valving was only in the last part of travel, more like an adjustable bump stop. Closing off the free flow of oil forced oil through the valve stack. It now has dampening. My Daytona (same basic frame, even worse front forks) I upgraded the entire front end. I bought a used GSXR 1000 front end, forks, wheel, and calipers, cheap. I sent the forks to PPS in NC (out west Lindemann Engineering is a good substitute) and had him custom build them. All totaled was under a grand. I got perfect suspension action, better braking (yes BETTER, more power AND better control and feel) and the lighter front wheel improves handling. The forks are slightly shorter the stock. This steepens the rake much like all those people who say drop the front forks a little to improve handling. But, unlike that approach, the GSXR triple clamps also have less offset which adds back in the trail that steepening the rake takes away. I have another set of GSXR forks that I will likely use to do the same to the wifes V11, but since the valving change it works pretty well. And that takes away the hurry, I'll get to it someday.
  8. I am a big fan of Ohlins equipped bikes, V11 or otherwise. Whether you will push it hard enough to feel the difference I don't know. You may or may not appreciate how well they work (they do work well). But do you need Ohlins on your V11 for it to handle well or be a enjoyable ride? No, in fact the wife's V11 has the older Zook's in front (modified to actually provide dampening) and a Penske out back (money well spent). You can send the stock forks out to have them improved and the rear shock has many options for an upgrade. You can even switch to a GSXR front end with a lighter wheel and better brakes. The Ohlins suspension can be a bit higher in maintenance, they use low stiction seals that are not as durable. In the end it comes down to whether you find a bike at the right price and whether it has Ohlins or not. I would pay extra for the Ohlins but not more then a grand or so. But that is my own limit. While it would cost you atleast 2 grand to upgrade a V11 to Ohlins you could make the suspension as good or better then that (including better brakes) for about $1600.
  9. Generally I would agree, but I don't think this is being done for our old V11s. I would bet money they are just listing this for any Fuel injected bike that it could remotely be made to work on. This is not a model specific widget. If you like cheap solutions I am pretty sure there are cheaper ones. If you want better solutions I know there are better ones. But I have no doubt that there are people for who this is just the right balance. Just don't try to suggest to them that all they are doing is tricking the ecu into adding more fuel by altering the sensor reading it is basing its fueling on.
  10. ??????? The pictures only shows a mid pipe/collector and tailpipe/muffler. I did not see anything to indicate the length of the header pipes. As for the diameter of the muffler, a two into one muffler does not need to be significantly larger (if at all) then a two into two muffler on a twin. Only one cylinder is exhaling at a time. The pipe/muffler diameter is sized mainly by cylinder displacement not total displacement. And a well designed two into one(I have no idea how well that two into one system is designed)will out perform a two into two system. I have seen that time and time again.
  11. The wife and I have not ridden in about a month, ever since we got back from the Indy MotoGP. The weather has been cr@p. We found some incredible roads in eastern Ohio and can't wait to return. Maybe in Oct.
  12. That is an issue that plagues modern CARC Guzzi's. While you might have a similar problem the electrics on both bikes are pretty different. The CARC bikes have an ECU that checks for voltage at the moment of starting and if it does not see enough it does not allow starting. When this happens all you get is a quiet "click". The motor does not turn over or anything else, just that click.
  13. Did you get the stem out of the Bearing? I remove the fork tubes from the lower clamp. Their weight can cause issues trying to slide the stem out of the steering head. Then use one of the various "block of wood and a hammer" tricks.
  14. Sorry, I was just trying to answer your question and thought I would throw in a little info on where I am coming from and how I came to my position. I do accept that ethanol may be the reason for fuel tank issues, but as I pointed out the fuel tanks in question were supposed to be compatible with the ethanol and if they are not it seems stupid to blame the ethanol. I also offer up the idea that some people, including myself, have used gas containing up to 10% ethanol for a long time with out suffering these fuel tank issues. There are a lot of additives in gasoline and they vary from location to location and from one time of year to another. The cause of the issues could be any combination of those additives, ethanol may or may not play a part. I did not feel the need to say that there may be an issue as several people had already said that. Therefore I simply was trying to point out that some of us use fuel with ethanol in it and have no issues.
  15. Around here ethanol has been an option since the '70's, common since around 2000 (as I recall), and required since about 2005. And it is the primary fuel in Brazil. Do they sell Guzzi's or Ducati's there? I do read, and I keep an open but skeptical mind when I do so. Because someone on the internet says something happened to them and this is why, I don't automatically believe them. Especially when my own experience says otherwise. As mentioned, I have been running my bikes on a gas ethanol blend for a while. I do not know what part, if any, ethanol plays in the fuel tank issue. But it does seem stupid to blame the ethanol when most if not all of the bikes affected were supposed to be able to run on up to 10% ethanol. Even if it was the ethanol eating the tanks the fault would seem to be with the tank, not the ethanol. I don't see what political views has to do with this either. My bikes are all non voters. They have no political affiliations.
  16. Thanks. Very useful. Of course the Daytona could be considered a litte more "exotic" too. Would you consider touring on it? In its original form I could not tour on the Daytona. When I was younger, maybe. I am not that old (45) but it has been hard with some broken bones and what not. But I have removed the front fairing, switched to handlebars, and swapped to a V11 seat. I have no issues touring on it now, but it is a very different bike now. The V11 is a great bike. I would have bought one of those and been very happy. But instead I bought a Griso, a great bike in its own right but it lacks the raw sporty feel of the V11 to me. I still have it (the Griso) but a buddy of mine needed to thin his stable out and he sold me the Daytona I went with him to buy way back when. That was the first Guzzi I had ever ridden the day he bought the Daytona and told him if he ever sells it I want it.
  17. When your 2004 V11 was sold in the US it was supposed to be required to be able to run on up to 10% ethanol. Can it? Well, my wifes 2000 V11 has been running just fine for over 50,000 miles on fuels that typically have contained up to 10% ethanol. There does seem to be an issue with the plastic of the fuel tanks but I have not seen any real proof that it is ethanol causing it (just a lot of assumptions and speculations) and since ethanol has been a standard for ages it is stupid to blame it if there is a problem with a component that is supposed to be compatible. Or you can get up on a soap box and start yelling.
  18. I have a Daytona and my wife has a V11. The Daytona is a five speed and the V11 has six. The Daytona has a more relaxed, long-legged feel (taller gearing) as well as feeling a little more raw and unrefined. I call it a hot-rod tractor feel. The V11 is a better bike from a technical perspective but I do love the Daytona. It has a lot of character. The Daytona is too uncomfortable for me stock, however. I modified mine to run handlebars and a V11 seat.
  19. I looked into that option, but 1) I don't have an O2 sensor and 2)this page discouraged me. Especially the fragility part. http://jefferies-au.org/MyECU/Is_My16M_for_you.html The quote about Fragility was referring to the stock Guzzi ECU, not MyECU. The fragility of the stock ECU is a reason for switching to Cliffs MyECU, not a reason to not switch. He does not claim his is less likely to go up in smoke but if it does it is easier/cheaper to fix. Reasons to not go with Cliffs MyECU would be things like complexity of setup and if you build yours from kit that is another. It is not the plug and play simplicity of a Power Commander (I currently have two of those) but it is more advanced and can do things the PC can't. But they are not for everybody.
  20. I bought a couple of kits from Cliff recently (but have not had time to build them, hopefully over the winter). He seems very on top of things and it seems that it is more of a case of the Factory trying to catch up to him. His ECU seems better then the factory units in that they are more adjustable. I have never heard negative stuff about cliff and his product.
  21. I mounted an Acewell tach/speedo combo gauge on my Daytona. It is not perfect but it does work well. I like that it is small and compact, replacing two large gauges with one small one. It also has temp sensors and a clock. If you are in the US the best place to get one, though, is from the UK. No one in the US stocks the right version for the Guzzi and it is cheaper from the UK anyway.
  22. I did not hear Ducati running V4's in anything other then the Desmosedeci, which while they did/do sell a couple it is not a real production Ducati. Aprilia have moved to a V4 and it sounds cool. I would be happy if Guzzi built a sideways V4 with water cooling and 4vpc. But if they rebadge an Aprilia as a Guzzi I think that would be the beginning of the end.
  23. This is a slippery subject in the USA. But here are a couple observations.... Years ago I used Shell Fuel in my dirt bike and a friend used another brand in his (same bike). Mine would always start (kick start) and his was hard to start. I told him to try Shell, he did and with Shell fuel his would start just as easily as mine. While the base stock of gasoline in this country does not really vary from brand to brand (fungible) the additive blend can and does vary. It can vary from brand to brand, summer to winter, and area to area (sometimes those areas are very close to each other). Also, fresh fuel from a station that goes through a lot of gas is better then old fuel from a station that does not. And sometimes there is water or other contaminants in a stations fuel tank. That can cause issues. Water is even more of an issue when there is ethanol in the fuel. The issue of alcohol is often misunderstood, both in relation to percentage as well as energy in versus energy out. I do not expect to change the view of others but I do encourage people to read about it from reputable sources (i.e., not FOX). And while you can legitimately call an increase from 10% to 15% a 50% increase it is also known as a 5% increase. It comes down to point of view.
  24. Mike Himmelsbach is a great guy (and a racer). He took great care of me when I bought a shock for the wifes V11.
  25. There is a full range of shocks available from economy to Penske. If the shock breaks bad things happen. The stock Sachs shock is not worth the money to repair.
