sign216
    4
Everything posted by sign216
  1. I am confident that additives would get back into suspension, what with the natural movement of the motorcycle. At least with the hell-be-damned way I ride. Interesting topic. Glad Agip answered so quickly. Some corporations would have let it go unanswered.
  2. Bjor, I think with MyECU you get to make your own map for the ECU. This is a benefit if you have problems to solve, or want to maximize performance, but since your bike runs well it's up to you. My bike has a bad ECU, so it's an easier decision for me. My soldering skills are good, but I am daunted by having to make my own map. Turning a wrench is fine. Making a 3 dimensional computer map is a little different.
  3. Is MyECU from Cliff Jefferies still a viable replacement for a current factory unit? Their website MyECU is dated, with no new developments, and it can be hard for one man operation like his to stay on top of things. My 2009 V7C ECU has a ROM error preventing a TPS reset. Rather than throw money at it, I'm thinking of getting a MyECU kit from Cliff Jefferies for $260. The ability to set my own map would be great, but it wonder if MyECU has kept up with the Guzzi factory. Joe
  4. EXACTLY, you can't risk a flat battery I am amazed that the line will draw amps without even being connected to the GPS. The draw is small, but something to watch for. Thanks all.
  5. V11, you're right, I think I connected the neg lead first, in error. Still, I'm surprised there's a current draw in the power line, even when the GPS is unconnected. Kiwi, I would have connected the GPS directly to the 12v current too, but fortunately I checked some online forums first, and had previously disassembled a cigarette plug and seen the circuitry inside. Or I would have made that mistake too. It's all powered off a small after-market fuse panel, that's nice because it fits so well in the tight space that cycles have. Joe
  6. I did it via a small fuse block. I just slapped on the GPS line to go up to Laconia tomorrow, for a trip of a few days. I also got a micro-relay + fittings for a better setup, but that will have to wait until I get back. In the meantime, I'm curious about this drain, on what should be a dead line.
  7. I'm putting in a direct wire for my GPS. Goes from two raw leads at the battery, to a mini USB plug for the Garmin. Direct Wire Unit I was surprised when I attached the leads, to see a small spark at the positive connection. Nothing's attached to the line yet, just the wire, so there should be no current draw, right? Multimeter says a current draw of 0.5 volt and 0.003 amp (3 m Amp). Although the GPS isn't attached, is it possible that the voltage reduction circuit in the line is causing the parasitic drain? I think the black box in the line may reduce the voltage from 12 to approx 3 volt for the GPS. Is the 0.5 volt 0.003 amp drain significant? Is it normal?
  8. Doesn't that go along with living in the Bay Area anyway? Sorry your bike's been so much trouble...hopefully you get her sorted soon. c My transmission locked up after a mechanic applied the recall fix on my 2000 V11 sport. When He put it back together he didn't put a circlip on correctly, it broke. The shifter shaft feel out at about 70+ mph. It was very exciting when I downshifted. http://www.guzzitech...chuckshrap2.jpg http://www.guzzitech...chuckshrap1.jpg From www.guzzitech.com shrapnel page I had the tranny warranty work done to my 00 V11 sport. Replace a couple of pieces to prevent a transmission lockup. I had all the springs replaced while they were in there. When I got the bike back the neutral indicator light would come on randomly. Turns out a clip had broken that holds a shifter cam onto a pressed fit shaft on the cover. While I was riding out in western MA on Tuesday I noticed transmission oil leaking from the shaft, so I kept an eye on it and headed home, stopping 5-6 times to check it. On the Mass Pike at around 75 MPH the shaft fell out of the case onto the road. I happened to look in the mirror and see smoke billowing out the back. I knew I blew a seal or something and the rear tire would be soaked with oil. I slowly pulled into the breakdown lane. I used the front brake to slow down to about 50 and downshifted, not realizing the shifter cam had fallen into the tranny. BOOM and a nice controlled rear wheel lockup for about 150 ft... Tom, nice work. It's good that happened in the western part of the state. Imagine that in the east, say on 128? I give you credit for controlling the machine. Joe
