mznyc Posted July 19, 2007 Share Posted July 19, 2007 Hi Guys, Doing first oil change.Which is the correct drain bolt.The owner's manual shows 2 diagrams and says remove oil drain bolt 'B" .In one diagram 'B' is smaller bolt on the rear of the pan between the feeder tube and the larger bolt.In the other diagram 'B' is the bolt on the front of the pan between the two feeder tubes.In the shop manual it says the remove the larger bolt on the rear of the pan ,to the right of the smaller bolt. :!: Thanks Michael Link to comment Share on other sites More sharing options...
docc Posted July 19, 2007 Share Posted July 19, 2007 Yeah, it's the lower, smaller one. Something must have been lost in the translation . . . Link to comment Share on other sites More sharing options...
pete roper Posted July 19, 2007 Share Posted July 19, 2007 The reason there are two plugs on the back of the sump plate is that the larger of the two on the right is simply a hangover from earlier models, (Sport i, Centauro, Daytona RS etc.) that had two oil return pipes from the spine which acts as a condensor for oil vapor expelled from the engine in service. V11's only use one so rather than modifying the casting they just put a plug in there. As Docc sez, the drain bolt is the central, lower one at the back. Use a new crush washer. For some reason broad sump drain plugs seem to like to come loose. I've never had one that's been on the point of falling out or heard of one doing it but I quite often find them less tight than I think ideal. Pete Link to comment Share on other sites More sharing options...
docc Posted July 22, 2007 Share Posted July 22, 2007 So, Pete, are you a 'sump puller' or can you be content to change the filter through the access hole? Link to comment Share on other sites More sharing options...
pete roper Posted July 22, 2007 Share Posted July 22, 2007 So, Pete, are you a 'sump puller' or can you be content to change the filter through the access hole? I pull the sump. I hate the 'Manhole' it sucks, even with the correct filter tool its hard to get the filter tight enough and given all the tales of filters loosening I do 'em up good and tight with a strap wrench! Pete Link to comment Share on other sites More sharing options...
