Onibaka Posted May 26, 2014 Author Share Posted May 26, 2014 Roy, I have a link to the "Maxi" fuse. I delivered to myself "Superseal Fuse-Holder", contact piece seems dense and good, but it didn't help. strange. Well, I will deliver to MAXI holder. 1 Link to comment Share on other sites More sharing options...
Onibaka Posted April 18, 2015 Author Share Posted April 18, 2015 Hello!!! I have a question The oil started to leak from the generator cover. When I dismantled the motor, I replaced the oil seal which stands in front of a generator, and put a new one instead. What could have caused to oil leak? Will it be possible replace it without removing the front cover of the motor frame? And how critical is that, since I'm planning to do this sometime before the winter ... Link to comment Share on other sites More sharing options...
Kiwi_Roy Posted April 24, 2015 Share Posted April 24, 2015 I think you may have to remove the timing cover. If it's not leaking too bad I wouldn't worry. Over full perhaps. Sent from my shoe phone! Link to comment Share on other sites More sharing options...
callison Posted April 24, 2015 Share Posted April 24, 2015 Under the front left side of the fuel tank there are two bullet connectors (yellow wires) that run from the alternator to the main wiring loom. You should probably take them apart (they're AC so polarity isn't an issue), clean them, tighten the female connectors by squeezing them with pliers just a tad and then re-assembling them with dielectric grease. Link to comment Share on other sites More sharing options...
Onibaka Posted October 24, 2015 Author Share Posted October 24, 2015 Hello Again . I have a small question . How to remove this cover ? Lever than anything? Link to comment Share on other sites More sharing options...
Scud Posted October 24, 2015 Share Posted October 24, 2015 The small center "nipple" is a plastic cap. Pop it out with a small flat-blade screw-driver. Under the cap, you'll see that you can use an allen-wrench to unscrew the metal part. Link to comment Share on other sites More sharing options...
Onibaka Posted October 24, 2015 Author Share Posted October 24, 2015 Thank you,I got it,but I have this small center "nipple" metallic.Do I remove it the same way,please? Link to comment Share on other sites More sharing options...
Scud Posted October 24, 2015 Share Posted October 24, 2015 Here is a picture with the part off the bike, and showing how the tool fits to remove it. Once you pry off the center cap, you'll see what to do. I was puzzled for long time too - I kept trying to pry off the big part - but you only need to pop out the small centerpiece. The part in the picture has threads on the other side. Link to comment Share on other sites More sharing options...
Onibaka Posted October 24, 2015 Author Share Posted October 24, 2015 Oh,it's clear now,thanks much!!! Link to comment Share on other sites More sharing options...
Onibaka Posted June 14, 2016 Author Share Posted June 14, 2016 Hi everyone! I have a problem. At the end of last year I had a fall, I dropped the bike on the side on the road (~ 120 km / h). After that, during the winter I put a new steering damper, put a new front tire (Shinko 016), shot Pork chops for painting while on the rear shock absorber factory settings have been established. This year, I have found that after 150 km / h motorcycle begins to weave ( https://youtu.be/z3OQTU-kE2s?t=3m59s ) even on a completely flat road. Maybe you have any suggestions on what should be checked in the first place? Steering bearing, suspension tuning, or perhaps after the fall the frame geometry has been damaged. Thank you in advance. Link to comment Share on other sites More sharing options...
thumper Posted June 14, 2016 Share Posted June 14, 2016 Sounds like wheel bearings. Grab the wheels one at a time and try to wiggle them, any movement may be the bearings. Link to comment Share on other sites More sharing options...
docc Posted June 14, 2016 Share Posted June 14, 2016 Also, loosen the setting on the steering damper to the softest position. Link to comment Share on other sites More sharing options...
Onibaka Posted June 14, 2016 Author Share Posted June 14, 2016 Похоже, подшипники колес. Захватите колес по одному за раз и попытаться покачать их, любое движение может быть подшипники. Подшипники задних колес были недавно изменены. Я проверил передних когда я отложили колеса, они были в полном порядке. Мне советовали, что, вероятно, из-за падения фиксированных вилы повернуты в тройном локона. Будет ли check его, когда это возможно. Кроме того, ослабить установку на демпфер рулевого управления в мягчайшим положение. Именно в лузового один, но это Shyndy плотнее, чем оригинальный bitubo Link to comment Share on other sites More sharing options...
Kiwi_Roy Posted June 14, 2016 Share Posted June 14, 2016 That's just what I was thinking 1 Link to comment Share on other sites More sharing options...
czakky Posted June 14, 2016 Share Posted June 14, 2016 I see shyndy and bitubo... Link to comment Share on other sites More sharing options...
