Miro Kacur Posted January 28 Report Share Posted January 28 19 minutes ago, docc said: I see no value for the lock nuts in the Workshop Manual on the torque value page nor the swingarm section ("Assemble in reverse order.") You are right. That means I might have to rely on my gut feeling in this case. That is unless someone will clarify his/her experience on this topic. 1 Link to comment Share on other sites More sharing options...
Scud Posted January 28 Report Share Posted January 28 I've done this job several times, simply relying on feel for that torque value. All you need is enough tension to stop the pin from backing out. 1 1 Link to comment Share on other sites More sharing options...
gstallons Posted January 29 Report Share Posted January 29 7 hours ago, Miro Kacur said: Anybody please know the torque setting for those big lock nuts that go onto the pivot bolts. You know, those lock nuts that tighten the pivot bolts to pork chops... Thanks a lot! "Snug" to "tight" . This is tight enugh to not come loose. 1 Link to comment Share on other sites More sharing options...
