LowRyter Posted April 24, 2018 Share Posted April 24, 2018 Docc, Headlight was working. The first sign was the dead neutral light. The #2 (from front) relay clicked. No neutral light, no fuel pump, no starter motor. Link to comment Share on other sites More sharing options...
docc Posted April 24, 2018 Share Posted April 24, 2018 The Sidestand Switch completely bypasses the Neutral Switch (in the gearbox) and center relay (Relay#3). Does it act any differently with the sidestand up, clutch lever pulled in? 1 Link to comment Share on other sites More sharing options...
LowRyter Posted April 24, 2018 Share Posted April 24, 2018 Neither side stand, nor clutch lever, in and out of gear made any difference- tried all combinations. Turned the key on, headlight came on, oil pressure light, nothing else. Heard a click on the relay. Link to comment Share on other sites More sharing options...
docc Posted April 24, 2018 Share Posted April 24, 2018 Try rotating the bars lock-to-lock while holding the Start Button in and see if she "catches." 1 Link to comment Share on other sites More sharing options...
LowRyter Posted April 24, 2018 Share Posted April 24, 2018 docc, are you meaning that it is a bad connection or problem with ignition switch? BTW- I did move the bars and shake all the controls, kill switches, every combination I could think of. Link to comment Share on other sites More sharing options...
docc Posted April 24, 2018 Share Posted April 24, 2018 Can you put a voltmeter to the battery? 1 Link to comment Share on other sites More sharing options...
LowRyter Posted April 24, 2018 Share Posted April 24, 2018 Docc- I'll give it a shot whenever I see the bike again. But I did consider a bad battery. I rode it for 25 miles with one restart before I was stranded. Link to comment Share on other sites More sharing options...
LowRyter Posted April 24, 2018 Share Posted April 24, 2018 reading this, it seems to place the start is the neutral switch in the transmission. Found it on MG site. Maybe should check connection and clean it. Link to comment Share on other sites More sharing options...
Chuck Posted April 24, 2018 Share Posted April 24, 2018 A quicky trouble shooting thing. No neutral light-look for sticking neutral switch. Won't run in neutral-look for stuck neutral switch..or.. middle relay. Won't run in gear-side stand switch. That don't work? It's cursed. I'll give you a hunnerd dollars for it. 1 Link to comment Share on other sites More sharing options...
LowRyter Posted April 24, 2018 Share Posted April 24, 2018 Seems reasonable Chuck but, Since the bike should start in gear (with the side stand up), why would the neutral switch kill the fuel pump and starter? If it's the sidestand switch, why would that affect the neutral light? Link to comment Share on other sites More sharing options...
Chuck Posted April 24, 2018 Share Posted April 24, 2018 Seems reasonable Chuck but, Since the bike should start in gear (with the side stand up), why would the neutral switch kill the fuel pump and starter? If it's the sidestand switch, why would that affect the neutral light? Ok, in that case, it sounds like the ignition switch to me. I'd check for power to the sidestand switch and fuse F6. 1 Link to comment Share on other sites More sharing options...
stewgnu Posted April 24, 2018 Share Posted April 24, 2018 Are your connections to tye starter motor good? 1 Link to comment Share on other sites More sharing options...
LowRyter Posted April 25, 2018 Share Posted April 25, 2018 Stew, for sure need to check connections. Not only didn't it crank, but no fuel pump and dead neutral light. Link to comment Share on other sites More sharing options...
JRD Posted April 25, 2018 Share Posted April 25, 2018 I had taken my tank off to change the fuel filter out. After re-installing the tank I tried to start the bike and nothing. Removed the tank and discovered the two wires from the clutch lever switch had disconnected. If memory serves me they were in the bundle near the ignition coil on the left side of the bike. Plugged them back in and the bike fired right up. Hope this helps 1 Link to comment Share on other sites More sharing options...
Chuck Posted April 25, 2018 Share Posted April 25, 2018 Stew, for sure need to check connections. Not only didn't it crank, but no fuel pump and dead neutral light. x posted from WG I found a schematic (I'm certainly no electrician) and the ringer here to me is the fuel pump isn't running. If I'm reading this correctly, fuse F1 powers the ECU relay, which triggers the INJ relay, powered by fuse F2, which powers the coils, injection, andfuel pump. You *have* checked for power at fuse F1, and F2, right? Kiwi Roy was right (of course) the headlight being on rules out the ignition switch. There is an Amp connector 35 from the ignition switch that I'd suspect. This deals with the kill switch, sidestand switch, yada yada. 1 Link to comment Share on other sites More sharing options...
