gstallons Posted September 2, 2018 Share Posted September 2, 2018 Is the LED or regular bulb in the charge light display? Link to comment Share on other sites More sharing options...
fed Posted September 2, 2018 Author Share Posted September 2, 2018 LED but all is fine for first 10 to 15 miles .... my guess is defiantly heat related The new regulator was shipped and in N.J. Last nite so I should see it by tues or wed Link to comment Share on other sites More sharing options...
swooshdave Posted September 3, 2018 Share Posted September 3, 2018 Oh, i thought the original models, the griso 1100, had the 1064cc unit? You are totally right. Link to comment Share on other sites More sharing options...
fed Posted September 5, 2018 Author Share Posted September 5, 2018 Sophia is fixed. upon replacing the regulator i found the the bullet connectors had scorched the rubber coating. I cut the rubber off and the wires where they contacted the terminal were green/corroded. replaced them at the same time cleaned the other connectors and buttoned it up. went out for a short run this morning about 50 miles and no lite....Woo Hoo. i'd like to thank all the guys who on this and previous posts about how to check and handle this situation. 3 Link to comment Share on other sites More sharing options...
gstallons Posted September 6, 2018 Share Posted September 6, 2018 If this is accessable , check these connectors again in two weeks to sww if they are snug and look good . 1 Link to comment Share on other sites More sharing options...
