Tinus89 Posted May 6, 2021 Share Posted May 6, 2021 Hi all, I have a smallblock rear drive/bevel box which I want to repaint, as oxidation has caused the paint to flake. I can of course get a wire brush out on a drill and manually remove all old paint & oxidation prior to repainting it, but the best option really would be to have it sandblasted. Question: I have never disassembled a bevel box (I have with entire engines). Is disassembly and reassembly of one of these easy, or should I spend extensive time & effort in setting gear preload/interference? Link to comment Share on other sites More sharing options...
Chuck Posted May 6, 2021 Share Posted May 6, 2021 It depends on what you call easy. You'll need a puller to get the bearings out, and that small seal in the back is a booger. As long as you don't change anything, there's no need to mess with the gears. If it is a pre 87, there is a lube mod that needs to be done. Link to comment Share on other sites More sharing options...
Tinus89 Posted May 6, 2021 Author Share Posted May 6, 2021 It is early '90s. Hmmm. So no need to set preload/backlash if I dont change anything, but also not too straight forward. Since it is not leaking, I am leaning towards leaving it intact an painting as is... 1 Link to comment Share on other sites More sharing options...
Scud Posted May 6, 2021 Share Posted May 6, 2021 I've painted a few of them without disassembly. I was careful with the aircraft paint stripper, and used plastic scrapers and wet paper towels to remove the gunk. Didn't need any abrasives. 2 Link to comment Share on other sites More sharing options...
KINDOY2 Posted May 6, 2021 Share Posted May 6, 2021 Vapor blasting? Link to comment Share on other sites More sharing options...
Gmc28 Posted May 6, 2021 Share Posted May 6, 2021 +1 on the careful use of stripper. Small enough area that it’s not a pain.What will be the plan for the paint method? Tape&spray, or is it reasonable to powder coat with it still assembled? Link to comment Share on other sites More sharing options...
Chuck Posted May 6, 2021 Share Posted May 6, 2021 I'd pass on the 400F powder coat curing temp. When I did the AeroLario, I thoroughly cleaned it with purple power, went all over it with red scotch brite, wiped it down with thinner, masked and rattle canned it. Still looks good years later. 1 Link to comment Share on other sites More sharing options...
Scud Posted May 7, 2021 Share Posted May 7, 2021 You need all the grease off before powdercoating, so you'd need to remove the bearings - and the heat is not good for any rubber seals. I used canned spray paint as well. VHT Engine Case is good paint. 1 Link to comment Share on other sites More sharing options...
Tinus89 Posted May 11, 2021 Author Share Posted May 11, 2021 Thanks for all the responses! I've given it a whack yesterday with some paint stripper and a wire brush on a drill, which went remarkably well. Everything closed up/taped off obviously. Only need to go and find a smaller bit for the corrosion in the small holes, but should be fine. Plan is indeed to (quality) rattle can it, as the curing of the powdercoat will hurt any seals etc. 1 Link to comment Share on other sites More sharing options...
