Kiwi_Roy Posted July 10 Posted July 10 (edited) On 5/26/2025 at 7:27 AM, Drahchir said: Was just wondering. If I swap the ht leads over would the misfire happen on the other cylinder? Proving that one of the coils is at fault? You could swap the coils over but you have to swap the primary wires also If you measure the resistance from the plug cap to chassis it should be the same on both sides about 7000 Ohms from memory might be less if there's no suppressor resistor in line. Edited July 10 by Kiwi_Roy spelling 3
