orangem2 Posted Friday at 09:32 PM Posted Friday at 09:32 PM i have a 2004 V11 cafe sport Odessey PC545 battery while bike is running at 1000 rpm idle 12.7- 12.8 volts when bike is at 2000 rpm and above 13.6 volts Went on a 40 mile ride with one stop... bike started no issue. when i got home i plugged my battery tender harness in and within 60 seconds the green light started flashing telling me battery was at least 90% charged, what voltages should i be reading at the battery at idle and at 2000 rpm and above? is my voltage regulator reading a bit low? Charging light NEVER comes on... is that normal? thnx
docc Posted Friday at 10:06 PM Posted Friday at 10:06 PM Your "battery tender" probably doesn't speak Hawker Odyssey fluently. A Hawker (EnerSys) approved charger is the ticket. Otherwise, 1000 rpm is rather low for a V11, IMO. Plus, anything above 2500 rpm or so should see 13.8-14.2 volts. Stand by for TMI . . . 1
orangem2 Posted Friday at 10:48 PM Author Posted Friday at 10:48 PM I read ALL of that already and then some LOL... just 2 questions: is my regulator rectifier borderline? should my charging light come on when the bike is NOT running, just the ignition switch to ON? 1
audiomick Posted Friday at 11:05 PM Posted Friday at 11:05 PM 9 minutes ago, orangem2 said: ... should my charging light come on when the bike is NOT running, just the ignition switch to ON? I believe it should. If I remember correctly, you should be able to check whether the light is working by pulling the light blue wire off the regulator and connecting it to battery minus. 1 hour ago, orangem2 said: while bike is running at 1000 rpm idle 12.7- 12.8 volts when bike is at 2000 rpm and above 13.6 volts 12.8 at Idle is, as far as I know, probably okay. If it never gets above 13.6V, that's a bit low. Before you decide that the regulator is not ok, go through the wiring loom and check and clean all of the connections that have even remotely something to do with the charging system. 1
orangem2 Posted yesterday at 03:22 PM Author Posted yesterday at 03:22 PM Anyone got a part number for the bolt used to secure the main ground on the back of the transmission case?
gstallons Posted yesterday at 06:13 PM Posted yesterday at 06:13 PM Uh.... can you look at one nearest to it ? Remove it and measure the length & diameter of the screw and get one . I am not sure if I am looking at the correct fastener in my parts catalog , so go the route of remove and check the bolt dimensions.
orangem2 Posted 9 hours ago Author Posted 9 hours ago (edited) So just to follow up... I reconditioned my PC545 twice. Standing voltage was within spec, BUT it only put out 80CCA... battery is toast. Full admission: i keep ALL my bikes on a Deltran Battery Tender, I got 6 years out of this battery. I checked my main ground on the transmission, and it definitely needed some cleaning and deoxit. Cleaned the yellow wires plug to the regulator with deoxit also. My regulator has a case ground wire that uses a ground on the frame. And my charging light does not come on with engine running or not. Plan is to replace the battery and see what the voltages are at idle and higher, then figure out the charging light... stay tuned!! Could the knackered PC545 battery be the reason for my lower-than-expected reading at the battery for regulator ou put? like loading it down? Deciding if a Motobatt is the way to go other than the higher cost PC545 if its more "needy" to keep charged when not riding. Edited 9 hours ago by orangem2 1
docc Posted 5 hours ago Posted 5 hours ago Good work, so far, @orangem2! A few questions at this point: What year is your V11? Oil pressure light illuminates KOEO? What are you using for relays?
Pressureangle Posted 4 hours ago Posted 4 hours ago Mine had marginal charge voltage for a long time, eventually started coming home discharged and eventually quit while riding. Long story short is my stator-to-regulator wires had poor connections under the gas tank, evidenced by heat browning. I secured the connection and charge voltage went from ~13.2 to 14.5 immediately. 1
gstallons Posted 3 hours ago Posted 3 hours ago I assume you used butt connectors to "hard wire" this connection ?
Pressureangle Posted 3 hours ago Posted 3 hours ago 36 minutes ago, gstallons said: I assume you used butt connectors to "hard wire" this connection ? No, soldered/shrink tubing. No room for wondering. On the Sport I can remove the stator and regulator as one piece. 1
orangem2 Posted 3 hours ago Author Posted 3 hours ago (edited) 3 hours ago, docc said: Good work, so far, @orangem2! A few questions at this point: What year is your V11? Oil pressure light illuminates KOEO? What are you using for relays? 2004 v11 Cafe Sport Oil pressure light ON with key ON, engine OFF GEI 20A/25A relays just ordered picker PC782-1C-12S-R-X replacement relays Edited 2 hours ago by orangem2
gstallons Posted 38 minutes ago Posted 38 minutes ago (edited) We all need to come up w/a procedure to troubleshoot these charging issues . This is not this hard. The biggest problem(s) are skill level and misunderstanding. You hate to work on this a week to find a ring terminal off when you are messing w/the battery. The only problem you will have in ownership of these bikes : you will become a master electrician of 12v DC , theory , wiring diagrams be able to explain resistance , capacitance , inductance RD time constant and a bunch of other stuff your wife will NEVER want mentioned in her presence . Edited 33 minutes ago by gstallons
