docc Posted Friday at 11:59 PM Posted Friday at 11:59 PM What is it? And can I use silicone lubricant as a substitute?
audiomick Posted Saturday at 12:46 AM Posted Saturday at 12:46 AM (edited) Would that be this, perhaps? https://www.schmierstoff-datenbank.de/uploads/aeroshell grease 22 pdb.pdf If it is, going by that data sheet, I reckon you'd need a very robust silicone to do what the product itself is designed for. PS: the way that reads, that stuff would be ok for the drive shaft on the V11, I reckon. Edited Saturday at 12:48 AM by audiomick 1
docc Posted Saturday at 12:55 AM Author Posted Saturday at 12:55 AM Looks like some amazing stuff. I'm a knuckle dragger to be looking for a substitute that I might have on hand . . . 1
audiomick Posted Saturday at 01:16 AM Posted Saturday at 01:16 AM 21 minutes ago, docc said: ...looking for a substitute that I might have on hand . . . What is the application that raises the question?
Speedfrog Posted Saturday at 01:20 AM Posted Saturday at 01:20 AM Good info about Aeroshell 22 here ==> Linky 1
Speedfrog Posted Saturday at 01:26 AM Posted Saturday at 01:26 AM From the same source: Shell Aviation offers a range of aviation greases designed to fill almost every lubrication need of the aviation community. AeroShell Grease 5 Mineral Grease for Aircraft Wheel bearing and engine accessory grease Microgel thickened, mineral oil base Meets MIL-G-3545C P/N 08-05455 Combines high load-carrying ability with excellent resistance to water and high temperatures. It inhibited against corrosion and oxidation, and has a useful temperature range of -23°C to + 177°C. Used primarily in aircraft wheel bearings and engine accessories operating at high speeds and relatively high temperatures. AeroShell Grease 6 General Purpose Airframe Grease Microgel thickened, mineral oil base Approved MIL-PRF-24139A P/N 08-05460 Inhibited against corrosion and oxidation, it features outstanding low temperature torque properties and resistance to water. Useful temperature range of -40°C to +121°C. Used primarily in plain and anti-friction bearings on general aviation aircraft. AeroShell Grease 7 Synthetic Grease for Aircraft Advanced multipurpose airframe grease Microgel thickened, synthetic diester oil base Approved MIL-PRF-23827C P/N 08-05475 Corrosion inhibited and fortified to resist oxidation, it combines excellent load-carrying capacity with a useful temperature range of -73°C to + 149°C. Recommended for highly loaded gears and actuator screw mechanisms, as well as for instrument and general airframe lubrication. AeroShell Grease 14 Mineral Grease for Helicopters Leading multipurpose helicopter grease Calcium soap thickened, mineral oil base Meets MIL-G-25537C P/N 08-05480 Inhibited against corrosion and oxidation, it is compounded with special anti-rust additives, and gives outstanding protection against fretting and moisture corrosion. Useful temperature range is -54°C to +93°C. Approved by all leading helicopter manufacturers. Recommended for most helicopter main and tail rotor bearings; widely used as a general purpose helicopter grease. AeroShell Grease 22 Synthetic Grease for Aircraft Versatile multipurpose grease Microgel thickened, synthetic hydrocarbon oil base Approved MIL-PRF-81322G P/N 08-05490 Corrosion inhibited and fortified against oxidation, it has excellent anti-wear properties, load-carrying capacity and water resistance, plus a wide useful temperature range of -65°C to +240°C. Recommended for aircraft wheel bearings, engine accessories and airframe lubrication, and for anti-friction bearings operating at high speeds and at high or low temperatures. AeroShell Grease 33 Synthetic Lithium Complex Grease for Aircraft Universal airframe grease Lithium complex thickened, synthetic hydrocarbon/ester oil base Approved MIL-PRF-23827C Type 1 P/N 08-00825 Developed with the purpose of satisfying almost all airframe lubrication requirements with a single grease. Its enhanced corrosion resistance and load-carrying capacity reduces wear and tear and can lead to extension of re-greasing intervals and reduction in maintenance costs. Replacing several greases with a single grease avoids the risk of misapplication and also reduces stock inventory, again providing cost savings. Useful temperature range is -73°C to +121°C. AeroShell Grease 64 Synthetic Grease for Aircraft Containing Molybdenum Disulfide An extreme pressure (EP) grease Meets MIL-G-21164D P/N 08-00824 Extreme-Pressure Airframe Grease AeroShell Grease 64 is an EP airframe grease based on the proven lithium thickener technology of AeroShell Grease 33. It can help to extend component life through its exceptional load-carrying and EP properties from fortification using 5% molybdenum disulphide and its excellent wear and corrosion protection. It also helps to reduce the risk of product misapplication by being fully compatible with AeroShell Grease 33. Together, these greases are perfect partners, thereby helping to reduce costs by protecting over 98% of the grease application points on a typical airliner. Benefits at a glance Longer component life through exceptional load-carrying and extreme pressure properties from its formulation with 5% molybdenum disulphide, and excellent wear and corrosion protection1 Longer grease life from excellent mechanical stability and controlled oil separation1 Reduced costs through excellent protection and longer grease life1 Reduced product misapplication risk through complete compatibility with AeroShell Grease 33 Peace of mind through the use of proven lithium compound thickener technology. 1 2
Speedfrog Posted Saturday at 01:32 AM Posted Saturday at 01:32 AM Personally, that is my go to for spline grease — MG Cycle 1
docc Posted Saturday at 01:33 AM Author Posted Saturday at 01:33 AM 13 minutes ago, audiomick said: What is the application that raises the question? A mechanical, dial actuated, combination lock. I am rather surprised at the "high speed, load carrying, and water resistance" characteristics for this application. 1
docc Posted Saturday at 01:35 AM Author Posted Saturday at 01:35 AM 1 minute ago, Speedfrog said: Personally, that is my go to for spline grease — MG Cycle For our V11 splines and hub drive, I have long been devoted to Klüber Staburags. Absolutely nothing wrong with a WURTH product depicting a track hoe! 1
Speedfrog Posted Saturday at 01:47 AM Posted Saturday at 01:47 AM 2 minutes ago, docc said: Absolutely nothing wrong with a WURTH product depicting a track hoe! Kluber Staburags is not so easy to find! Doesn’t roll off the tongue as easily either 1
audiomick Posted Saturday at 01:49 AM Posted Saturday at 01:49 AM Just now, docc said: Absolutely nothing wrong with a WURTH product depicting a track hoe! Firstly, if you haven't got an "Ü" on your keyboard, it's WUERTH. Secondly, Würth products are indeed typically very good. On top of that, Reinhold Würth, son of the founder of the company, is somewhat of a philanthropist. https://en.wikipedia.org/wiki/Reinhold_Würth Amongst other things, he had this built https://kunstkultur.wuerth.com/artsculture/venues/kunsthalle-wuerth/overview.php and he maintains an orchestra https://www.wuerth-philharmoniker.de/de/philharmoniker/orchester/orchester.php So I'm fine with buying Würth products.
audiomick Posted Saturday at 01:51 AM Posted Saturday at 01:51 AM 2 minutes ago, Speedfrog said: Kluber Staburags There's those dots again. Or, more to the point, there they aren't. Klüber, or if your keyboard doesn't have the Umlaut, Klueber. 1
Speedfrog Posted Saturday at 01:55 AM Posted Saturday at 01:55 AM (edited) 23 minutes ago, docc said: A mechanical, dial actuated, combination lock. I think a good all purpose grease should be sufficient for that. I’ve been using Super Lube Synthetic Grease lately and I like it a lot. Edited Saturday at 01:57 AM by Speedfrog 3
Speedfrog Posted Saturday at 01:59 AM Posted Saturday at 01:59 AM 7 minutes ago, audiomick said: There's those dots again …………………………………………… 1
audiomick Posted Saturday at 02:17 AM Posted Saturday at 02:17 AM 16 minutes ago, Speedfrog said: …………………………………………… You forgot this bloke 1
