Hi
Do you know your V11?
See attached photo of bolt
Where does it go on your V11?
Question I really want answered is how do you tighten it when there is nothing on head to use a spanner etc on? Mine have come loose.
Otherwise I could replace with something else like a Button Head Cap Screw
Share this post
Link to post
A quiz! :nerd:
Share this post
Link to post
That is the anti tamper bolt that goes into the bottom of the Ignition switch or it's mount. Its meant to be not removable . They screw it in then snap the head off. It's not easy to remove but sometimes they loosen up and fall right out.. I once cut a groove in one to get it out with a screw driver.
  • Like 3
Share this post
Link to post
Yeah, I've dealt with those things. Just use a cap screw, and consider yourself lucky it fell out. :rasta:
  • Like 3
Share this post
Link to post
While you have the ignition switch out, it is a good time to clean and lube it's guts. I have some ignition switch grease you can use.
Share this post
Link to post
I’ve had a few fixings of various types rattle loose there.
What have you guys had success with?
is there a torque value or anyone using a threadlocker?
Share this post
Link to post
Uhhhh , this is kinda vague . what are you finding loose ? Some things get Loctite blue . Red if it is PERMANENT . Some get different kinds of washers . If you have a torque wrench and like using it , PRACTICE using it . Get a torque table and practice .
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
