    1,190
  1. docc
    MotoLights
    The power for the tail light also powers the instrument lights and the small 'city light' in the headlamp shell. Current flows through Fuse 6 ( 5 amp) and the ignition switch. Certainly a good idea to keep an eye on the fuse. The bulbs on the stock circuit are 11.4 watts so only pull less than an amp but the 70 watts of auxiliary light pull 5.8 amps. Just for the peace of mind of the ignition switch, a dedicated hot to the relay would be good medicine. Check out the junction blocks: Relay failures ( junction blocks) Great looking lights!
  2. That original thread isRelay Failures. Here is a photo of the relays with the stick on letters. The turn signal flasher was relocated to this spot to make room for the junction block. There is nothing intuitive about the wiring to the relays. A careful review of the wiring diagram is vital to understand how the current flows. S - starter L - lights N - neutral ( side stand) C - ECU F - injectors/ pump/ coils
  3. I would think there are many, many of us whose gearboxes will soon be apart where the springs will be easily accessible. This is coming at a perfect time to upgrade the reliability of the shift mechanism. Any word from the supplier on the nature and quality of the original springs relative to the aftermarket units?
  4. There is room inside the clip-on above the stock weight insert for about an ounce (28 grams) of shot. Definately makes a difference along with Superbike grips and bar-end mirrors.
  5. docc
    anodizing
    Ah! Chemicals, universities and experimenting . . .life at its best !
  6. jason, I'm pretty impressed you've gone all the way back to November to catch up on posts! Says something about winter in Iowa. All the bird shot is in the # 6 - #9 range. The largest is 'BB' which are .177". Teh #3 an #4 is buckshot and the balls are about 1/4".
  7. Thanks, Emry.
  8. First problem on the Sport ( leaky front gearbox seal munted the clutch) came at 4000 miles / 6400 km. Your LeMans is ,as yet, young and virginal. John, with that beautiful cafe round-fin of yours can you say that the LeMans is that much more fun to ride? How so?
  9. Yes, bummer, sounds like the return spring. I know we were all hoping this went away with the early '02. (Any news on our 'custom set'. T.P.?)
  10. "72", Not unlikely that it will all just 'loosen up' with the miles. Does the the shift lever stay down as well?
  11. Like many , I switched to the 160/60-17 on the Sport (from 170/60-17). Next tire I think I'll go to the 160/70 just to get a little more weight to the front. Sure interested in how many miles you guys are gettinr out of the Diablos. And , like the Pirelli Dragon, are there "corse" as well as other cmpounds of Diablo?
  12. Er, what's "PDI?"
  13. The rear Sport 1100 carb size: 160/70-17? or 160/60-17?? (I thought "michelin" was French for 'yer-arse -on the-street'.) docc (allergic to Pilot Roads)
  14. Andy york in Nashville just fitted one to his LeMans. Send him a pm through the board and see what he says about it.
  15. S100 or Simple Green work pretty well. Remember the cases are painted so too much solvent may strip the paint. The manual calls for "petrol" but I bet their New York lawyers didn't see that line. Hot water and detergent worked with a parts cleaning brush is effective as well.
  16. Al, Didn't Gio do some heat shielding at the same time the pump was moved? One or the other or maybe both methods fxed his trouble. Guzzi science.
  17. Oh, it's not so bad when the gearbox gremlin shows up like this: It's when it shows up like this:
  18. I'm rather shocked that your post actually says "B" "M" "W".
  19. '02 LeMans ought to have a manual petcock. But it sure sounds like a fuel starvation. Not the dreaded 'vapor lock' in January?
  20. Threads like this appear to be uniquely a winter past-time. Notice none of the New Zealand crowd participates. Of course they can go for a ride while the rest of us drink too much and have nightmares about toads on bikes.
  21. docc
    Dipstick
    i ordered one but don't have a price yet. I was thinking that not only is the fluted plastic stick awkward to read, you can't see the color or condition of the oil. I'm looking forward to the new stick.
  22. There's no chance you moved the adjusting nut just in front of the splined shaft? Or that the pawl is fowling on that?
  23. I think the Candy Wrapper scheme is the Coppa Italia which I heard is Italian for "Gettin' Some" (I'm looking forward to seeing one of those up close. They look 'festive' to me.) The Nero Corse looks to be a fabulous package. But 'reliability' is kind of a relative term. It not only implies how much might break but also how long it may take to fix. By all appearances parts availability and service turn around are improving but probably still not on par with the Japanese. So, Mario, will you keep the Z-rex and add the LeMans? That way a little down time for sorting and fettling will be no disaster as you have another ride to enjoy.
  24. Both sides of my tank have the play at the front. And I did find the hose 'crimp' from some entrapment on that left side. But I thought I had caused that as I had shortened the line for the smaller (Nissan) filter. When i switched to the longer (Isuzu) filter, I cut a new longer line to be sure there's no pinch at that left tank mount point.
  25. It's that olive oil based glue. Seriously, i remember a thread on this. Something about using, er, Bavarian parts.
