Everything posted by Baldini
Can anyone confirm how many pipes Guzzi fitted here? ASFAIK my 02 Scura only had the one pipe fitted, with one fitting left unconnected. Workshop manual only shows one pipe, but then it only appears to show one fitting also. Could be different markets, could be only used on US bikes w charcoal gubbins? What's yours got? Thanks, KB
Anyone got a picture of Bellagio rolling chassis or frame they could share? So why didn't Guzzi export Bellagio to USA? Seems to me there hasn't been Guzzi executive doing joined up thinking for years. KB
Why didn't Guzzi make more of the Bellagio? It had consistent good press, looked good, went well. They could've been on to something for once. That's first time I've seen Bellagio frame - it looks like a shrunken Tonti! Tonti frame is a much finer looking thing than that on Griso + Breva & lends the bike much better lines - style is a product of it's function, not a look imposed by a stylist's whim. Ducati stuck with a tubular trellis & it hasn't done them any harm. Guzzi are always throwing the baby out with the bathwater. They always turn away from their history, & when they do look back they usually come up with something that misses the point (V7 Classic/Cafe). Shame the Carc unit looks so heavy. Respect to the constructor of this, but if you dress a modern bike in classic bodywork that's what it'll look like - it doesn't turn into something new - a bunch of parts, even if it is pretty. Jobs like Guzzirider did on a modern Cali work cos there's a unity to it, design follows function & you end up with something timeless - a classic... (...he just needs to mill off those square fins ... )... KB
A splendid method! I forego the crate, simply adopting a squatting posture. This crateless method isn't recommended if you have any doubts about your stability. Always keep oil up to max on stick. Not a problem I've experienced but there have been odd cases of oil pick up being starved under hard acceleration - I suspect this may only be an issue if you let level drop. There's loads of stuff on that if you do a search.... They don't use much oil. KB
Thank you for that . I don't know. Family always doing something - it'll be last minute thing if I do, but I'd like to go over. KB
Antonio, I'm not being puberal, really I'm not. I see members who have more points than they could use in a lifetime & I know the likes of us will never match them - I only ask for what is rightfully mine. As for BFG, I'm sure he cares nothing for points, he has bigger eggs to scramble. KB
Aw come on lads, play the game, where's my point? KB
NO. KB
I have same thing happening. Can't see source. Not impressed. KB
NO
YES
The problem has shown up in a few Scuras. Out of 800 (?) produced, we have seen here less than 10 I think. So there's a lot of Scuras riding around on original clutch! The Scura clutch is a single plate unit with an alu flywheel. There have been a few instances of flywheel fracturing & in worst cases disintegrating in use, flying apart taking cases with it. Guzzi deny there's any problem although have fixed some bikes on warranty! My information is that the Scura unit is a basically a RAM part but with some components, inc flywheel, sourced elsewhere (cheaper most likely) & this is cause of problem. Some owners have replaced stock clutch off their own bat as a precaution. I put in a RAM single plate unit, others go with std V11 twin plate which is pretty bullet proof far as I know. I replaced mine cos of damage I had seen on this site & because I had personal knowledge of one of the bikes that failed. When I replaced it, at around 20k miles, my clutch was working great - it's a lovely clutch to use, light & positive. It showed no symptoms of failure. When I pulled it down my alu flywheel showed no obvious cracks or damage. The friction plate looked in very good condition. It may be that this potential problem exists in a very small number of Scuras, or it may be common to all. I don't know of any Scuras on high mileages - so don't know if clutch can last (not saying there aren't any original clutches on 100k - just I dn't know about them). I don't know of any common factor in the history, mileage or type of use of the bikes that failed, nor any precursor to failure. I know one of the bikes which failed (J O'S) & it did have an unusually noisy clutch (you could hear it clearly above the clutches of two other Scuras sat a standstill in neutral). It was not ridden particularly hard. If you search Scura clutch etc. there's plenty of stuff.... There's also plenty of discussion re Ohlins set up which you might find interesting. That's a great looking bike you have. IMO Scura is best looking of V11 series, & a lovely bike to ride. KB
Obscene! - why? Re-styling some bits of mass produced metal ? I think the motor in the pix looks good. You're comparing an aesthetic choice (well, apart from the negligable reduction in cooling) with change to technology/function/performance - although I guess if someone wanted to do that - that'd be fine too. It's their bike. Exposed flywheel anyone? KB
Oh joy. Dastardly & Muttley - together again... KB
You sure about that? KB
Yeh, I could do that... KB
Letting it go wouldn't bring any attention. But didn't you see the little yellow funnyface? Easy pickings here for a dedicated wind-up merchant. But my point is KEEP IT OUT OF THE TECH FORUM - sorry for shouting again John (try turning the hearing aid down a bit) - Tech area is a unique & valuable resource that's lately becoming an embarrassing sludge cos of the reams of repetitive, irrelevant, personal heckling. KB
ALMOST EVERY TECHNICAL DISCUSSION DESCENDS INTO JUVENILE BICKERING. MANY CAN'T BE ARSED WADING THRU THIS STUFF TO GET TO THE RELEVANT BITS & GIVE UP ON THE FORUM. IT'S QUIET HERE - & IMV THAT'S WHY. FORUM RULES SAY NO NAME CALLING. IF YOU CAN'T STICK TO THAT, GO PLAY SOMEWHERE ELSE. THANK YOU. THANKS JAAP FOR CONTINUING PROVIDING THE PLAYGROUND. HAPPY NEW YEAR. KB
Nothin to do with me mate. KB
Hmm... . . . Grasped the hairy man by the bald end again eh? . . . If you read my post you will note that I make no reference to specific dimensions, rakes or angles. How can you "lengthen", "indecrease" or "keep" any spec when it is not spec'd? As to paint colours . . . there is no mention in the original post that the "mate" is anything other than his original colour . . . which is . . . IMHO . . . highly unlikely to be RED. KB
Your mate obviously needs help. To check for stability try this simple test: Construct a ramp sloping down towards the shed door. Place your mate at the top of the ramp & release him with a slight push in the direction of the door. Check that he tracks straight & true. Curing this sort of instability could simply be changing to a different different pair of sandals, but sometimes the problem lies deeper & it is necessary to place the "mate" in a rehabilitation unit for evaluation. A good V11 with correctly adjusted suspension should be totally stable whilst firmly held vertical at a standstill. Obviously as speed increases stability may become an issue, but the problem is usually down to user input. I hope this helps. KB
Well I don't mind that stuff if it contains any wit, originality, imagination or even some weird perspective - the juvenile, repetetive, humourless drivel seemingly infecting every technical topic here recently just means I don't bother checking in so much - & I reckon I'm not the only one. Shame for me cos I always liked the global perspective this forum has & the odd mix of characters, weather & time zones. Bring back Captain Nemo - come on Jaap we know it was you all along.... KB
Leak does sound like timing cover gasket. This is common & I suspect due to poorly fitted gaskets on assembly. Mine did it - I think I just tightened up the case screws. Whatever, not a major issue. But...check for any evidence of crash damage - If the leak is near the front right motor mount bolt, vulnerable in a crash on the V11, you should check for casing damage around the boss. There have been a few who have broken cases here even in low speed mishaps - but most likely it is the gasket. Did vendor explain speedo replacement - got original? KB
