Everything posted by 4corsa
From the album: My 02 Scura
stopping for lunch in Andes, NY -
after installation of the Ghezzi Brian carbon fiber chin spoiler -
Thanks for your replies gents. I ordered my GEI Relays from Pyro Dan (Design Tech Engineering) last night - five for $16.50 including shipping. The GEI AR4-012-C11 number is correct and Dan confirmed it will work for all five plugs. I will report back if there are any issues with them
Dumb question - assuming I purchase a few of the GEI AR4-012-C11 Relays as suggested above, will it work for all 5 Relays on the bike? That's what seems to be implied, but I read on another thread where someone temporarily messed up their electrics because they inadvertently mixed up the order of their Relays when they removed and re-installed them. Thanks for the help.
Was just told by Yuasa not to use their battery since ours is installed horizontally. They said it must be a factory sealed battery, and their YTX15L for V11s is NOT.
Found this image on Pintrest - the owner calls his bike "Tokyo Short Trip". Love the fairing and want one for my Scura. Please let me know if you know where it can be bought - thanks!
Replacing rear brake caliper seals..........NOT!
4corsa replied to guzzijack's topic in Technical Topics
Just discovered this very helpful topic because my rear caliper blew a piston seal and leaked all over my rear tire while riding this morning. I removed the caliper (20k miles, always garaged) this afternoon and discovered it was full of crap as predicted above. Luckily MG Cycles has brand new replacement calipers including pads for $122 in stock, not too bad. So if you're reading this and your rear caliper hasn't yet crapped out, now is the time to remove it and fully clean and service it! -
Thanks for the input, and that Tank Off Maintenance Checklist is great!
I noticed a small puddle of oil under my '02 Scura after a 50 mile ride yesterday. Turns out the crank case breather hose split just above the lower connection point. It sure couldn't be any more buried behind everything else, but it looks like I might have a decent chance at accessing it with the gas tank (and possibly air box?) removed. Any suggestions from those who have already enjoyed this task would be greatly appreciated. Thank you.
Just received and installed a carbon fiber chin spoiler from Ghezzi Brian (Bruno) on my '02 Scura. See attached. Some nice projects and after market bits on his website - nice guy to do business with.
If your stock damper is an Ohlins like the one that came with my Scura, its the highest quality damper you can buy. If so, I recommend contacting Ohlins and sending to them for a rebuild. You're actually supposed to do this every year or two depending on use. If I recall correctly, it costs around $50.
Looking for a chin spoiler for my 02 Sport Scura. Please PM and send email to 749corsa@gmail.com if you have one available or have any leads where I might get one. Thanks, Greg
Ok thank you. So mine were obviously polished by the previous owner.
I've had my '02 Scura for 3 years now and is a bit overdue to re-polish the polished aluminum valve covers. I started in lightly with some ultra-fine steel wool (without much results), and was going to follow up with some Simichrome polish. This worked quite well with the aluminum valve cover on my old TVR 2500M. But it almost seems like the polished valve covers on the Scura may be clear coated, so I stopped before getting too far into it. Anyone know if they came from the factory with a clear coat?
Very cool! Would be so great if you photo documented the whole process and posted on the forum. Best of luck with the mod!
Ok so I get to mark two threads as "solved" in one weekend - that'll never happen again! So after installing the PC III and loading the map for Mistral Exhaust / stock air box, AND running through two tankful with Yamalube Engine Med Rx, I have no more pinging! I know I should have been more scientific and tried them separately, but I have no patience. The bike immediately ran better with the PC III, but still pinged a bit at the end of the first tank with the Engine Med Rx. But by mid way through the second tankfull, I couldn't get it to ping no matter how I opened the throttle or at what rpm. So to recap, I'm running Mistral Exhaust with K &N filter on the stock box, Power Commander III with map loaded for the Mistrals (richer map), and now using Engine Med Rx regularly (will probably use every 2nd or third tankfull moving forward), and my Scura has never run smoother or stronger - such a pleasure to ride now! Thank you for all the help!
ANSWERED Time for another transmission oil leak thread
4corsa replied to 4corsa's topic in Technical Topics
Will happily be able to hit the "mark solved" button. As a last resort I changed out the gear oil and used the Red Line Heavy Soundproof gear oil. I carefully only filled up to just slightly below the mid level dot in the check window. Went for a 100 mile ride and no leaks! Even when left on its side stand. I noticed that the Red Line product has more "clinging" power than normal gear oil. It didn't seem much thicker, but it clinched to my funnel, even after 5 minutes in vertical position, it didn't drain off the surface. Must be Red Line's secret weapon. -
Just checked the website map and not a single ethanol free station in NJ - thanks Gov. Kris Krispy! Hopefully a few tankfuls with Engine Med Rx will do the trick.
Thanks Skeeve for addressing both my questions!
Thanks Emry - I just read that Yamalube Engine Med Rx is the new version of their Ring Free that I used to use on my R6. Great stuff - I just ordered some.
