4corsa
    13
Everything posted by 4corsa
  1. SOLD
  2. Two very different products. The 3m film is flat, ultra-clear, and less than 1mm thick. Stompgrip and Techspec are probably 3 or 4mm thick with intentionally uneven surfaces or "cleats" that are another 3mm long. The paint underneath will not be the same after a few years. Certainly won't be as bad as with a solid color, but you will see a difference from the surrounding paint.
  3. ...also depends on how many hours per year the bike is left in the sun, how often it's waxed, etc. Not to mention, even with clear tank grip, the paint will age differently under the grip pad than the surrounding paint that is exposed to the elements.
  4. From what I see on their website, they have two versions. Yours is the CF / Fiberglass composite. The purely CF version is $99. Let us know how the install and fit goes. Thinking of ordering one as well 😁
  5. TLM responded to my email that they are no longer making the V11 rear hugger, and are out of stock [emoji22] Let me know if anyone wants to part with theirs!
  6. Any idea if the Teo Lamers version is still available? Is it best to contact them at www.tlm.nl , or are there other distributors (anyone in the US)? Thanks!
  7. Awesome - thanks Docc. I will be unapologetically plagiarizing your labels!
  8. Guzzi no longer supplies the V11 Fuse Block. Luckily I found the OEM ATC & ATO block offered for $11 at Del City. I've also added this under the Forum's Encyclopedia of Compatible parts.
  9. OEM Part Name: Fuse Block Moto Guzzi Part Number: GU01743030 Replacement Part Brand or Source: ATC & ATO available at Del City (see attached photo) $11 Part number or other identifier: "ATC & ATO Block - 8 way" Comments:. This is the exact OEM fuse block that Guzzi used in my 03 Le Mans
  10. ...and if there are two available out there, I'll take the second one!
  11. My newly acquired '03 Le Mans arrived without a fuse box cover. Looking to buy a used one. Thanks!
  12. Ohlins are really worth it if you're an advanced track day rider (which I really wouldn't recommend with a V11).
  13. ...having owned a Scura with Ohlins, and now a Le Man's with Marzocchis, I can say they are both very good when properly set up. The Ohlins are maybe marginally more compliant over bumps while remaining firm under braking and cornering.
  14. There's a great video on YouTube that compares an Aprilia RS V-Twin to a Rosso Corsa "it's Monica Belluci vs Sophia Loren". Very funny and well done - one of the best quotes is "the Ohlins on the Guzzi is like paying for breast implants for your granny". That said, both guys picked the Guzzi over the Aprilia in the end!
  15. You are too kind docc, and you have awesome emojis! I have no excuse, I lived in Florence for 2 years where I contracted this terrible disease that makes me love everything Italian (Guzzis, Ducatis, Alfa Romeos, Sofia Loren, Prosecco...), and speak Italian reasonably well. I should cross-checked with the original Italian instructions 🤪 Anyway, filled it up to .850 and the good ol Redline is right in the middle of the glass. Glad the Pawl Spring job is done, and can't wait to ride her tomorrow!
  16. Thanks guys, .850 liters is what I thought I recalled from my old Scura. So here's where I got the info in the manual. On this page it says "transmission box" at 0.37 liters. Then I flipped to the previous page where it of course states "Rear transmission box". Doh!
  17. ...I rotated that plate fully counter-clockwise and re-assembled everything. Bike seems to shift well (at least 1st, neutral, and 2nd gear in the garage). Raining so will test ride tomorrow. One odd thing, I filled the gear oil with 0.37 liters as prescribed in the manual, and not showing up in the site glass (yes, drain plug in and bike vertical. I put in a little bit more, and still nothing, even after tilting the bike to the right of vertical. Will take it for a ride around the block and check the site glass tomorrow.
  18. I'm about to re-assmeble with new Scudd spring. Can anyone tell me if this rotating plate needs to be in a specific position? Could not see it during disassembly. Thanks.
  19. Yes, thanks Docc, that's what I'm planning to use unless there's an updated version. I also have a service manual for backup [emoji851] Thanks also for the link for the shift improvement.
  20. I spent a fair amount of time yesterday and today going through the 700-odd entries of this thread and now have a better understanding of the process and efforts that went into making this happen! So first, a sincere thank you to all who contributed, especially of course, Scud. I ordered and received my Scud spring a few weeks ago, and my "new" V11 Le Mans was delivered last week, so it's time to get to work. I'm assuming the instructions for the installation of the Pawl Spring located in the FAQ section from 15 years ago are still the best ones to follow - could someone please confirm that, or advise if elsewhere? Many thanks.
  21. I think they'll look great. I've put similar on a dozen bikes of different colors and I'm always pleasantly surprised with how good it looks. But more importantly, it gives you so much more stability on the bike, especially when stopping or hanging off.
  22. Yes, you remove the same way as installing, first warm it up good with a hair dryer, or heat gun on low setting. It comes off with no problems. For installation, you warm up the tank and pad ahead of time. Since the tank has some significant contours in that area, per the instructions you start in the middle and work your way to the perimeter. I cut out a 2.5" swath of the backing paper from top to bottom, aligned it and applied, kneeding from the center up and down. Then removed the other two pieces of backing paper one at a time, and again pressed from the middle to the perimeter. Mine came out perfectly with no bubbles.
  23. Yup - that's the one. Real carbon fiber.
  24. Did the Scura have the original exhaust or Mistrals? 8 lb potential savings right there.
