Motormike Posted February 14, 2013 Share Posted February 14, 2013 Well, as I get to know my 2004 Coppa , I find more things that are not quite right about it. Always a risk when you buy a used bike. Just noticed that the PO or his mechanic must have broken off one of the plastic fuel tank elbows (the white one) and has also removed both quick release fittings on the fuel lines and just using common hose clamps. The missing white fitting has been replace with a brass elbow. Don't know how well it was fitted to the plate just yet, as the tank is full of gas, and will have to wait for a closer inspection. The red plastic fitting is still there, but appears to have a very slight leak (weep). I know the plastic elbows are not available as a separate part, and are a common part to break. I'll replace the hose clamps with Oetiker ear clamps, but what is the best way to deal with the leaking or broken plastic elbows? Link to comment Share on other sites More sharing options...
Motormike Posted February 17, 2013 Author Share Posted February 17, 2013 So, I'm the ony Guzzi owner thats ever had a broken plastic quick release fuel fitting? Anybody? Link to comment Share on other sites More sharing options...
luhbo Posted February 17, 2013 Share Posted February 17, 2013 Start here: http://www.v11lemans.com/forums/index.php?showtopic=15363 The search button might bring up more links. I remember one directly leading to Aprilia spares. At least I think it lead to something useful Hubert Link to comment Share on other sites More sharing options...
Motormike Posted February 17, 2013 Author Share Posted February 17, 2013 Thanks, lots of good photos there that show the problem. Not so much as to the best way to go about a repair. I found it interesting that in the photos of the fuel pump flange, there is only one fuel line fitting (fuel out) and no return line(?) I've never heard of a fuel injection system that does not have a return line to the tank. Funny how each one of these bike is a "one off." No two seem quite the -same. My research found that McMaster-Carr sells stainless steel elbows rated for gasoline. Might be the best way to go. Have to wait until I have a reason to pull the fuel pump. As I said, it's not leaking now, so I'll leave well enough alone until it's time to change the filter. Link to comment Share on other sites More sharing options...
pete roper Posted February 17, 2013 Share Posted February 17, 2013 Apparently the plastic elbow is available as a separate part fro the Pegasso. I'll try and find a part # when I have a spare moment. Pete Link to comment Share on other sites More sharing options...
Wits Posted February 17, 2013 Share Posted February 17, 2013 http://www.gutsibits.co.uk/pr/TheShop/index.php?f=e&Shnew=1&Model=2&ModelName=Breva 1100, 1200 Sport, Norge, Griso, Stelvio&Cat=FUA&CatName=Fuel and Carburettors&spPage=2#topbar Part number FUA30000 Gutzbits in the Uk sell the plastic spigot/elbow Wits Link to comment Share on other sites More sharing options...
luhbo Posted February 18, 2013 Share Posted February 18, 2013 try it this way: http://www.gutsibits.co.uk/pr/TheShop/index.php?f=e&Shnew=1&Model=2&ModelName=Breva 1100, 1200 Sport, Norge, Griso, Stelvio&Cat=FUA&CatName=Fuel and Carburettors&spPage=2#topbar Link to comment Share on other sites More sharing options...
HaydnR Posted February 18, 2013 Share Posted February 18, 2013 AP8104192 http://www.v11lemans.com/forums/index.php?showtopic=16766http://www.v11lemans.com/forums/index.php?showtopic=16766 http://www.motoguzziclub.co.uk/forum/forum_posts.asp?TID=16485&KW=fuel+fitting I have also found these made by pfe fittings in oz but yet to buy one to try: Link to comment Share on other sites More sharing options...
Splicer Posted February 18, 2013 Share Posted February 18, 2013 I took the fuel pump to a machinist and had it threaded for a brass nozzle after I broke mine. The threads need to be cut correctly (I forget what that was called, "pipe threads" perhaps?) like for any fitting that needs watertightness (or fuel-tightness.) Then a little plumber's silicone tape for good measure and I haven't had any leaking so far. http://splicer.com/2012/07/17/breaking-perfectly-good-fuel-pump Link to comment Share on other sites More sharing options...
gstallons Posted February 18, 2013 Share Posted February 18, 2013 Pipe thread has a taper thread that will tighten as it is screwed into the mating part. I use "Leak-Lock" or liquid pipe sealer instead of teflon tape. The fitting you are using has too many barbs on it. There are fittings with a single barb for repeated unhooking and use a fuel injection hose clamp that will not mar the fuel line. 2 Link to comment Share on other sites More sharing options...
Guzzirider Posted February 18, 2013 Share Posted February 18, 2013 The old plastic elbow can be a pain to remove from the pump assembly because it has a toothed washer holding it in place, so you may need to carefully drill it out. The new one will need to be delicately tapped in with a light mallet. Link to comment Share on other sites More sharing options...
luhbo Posted February 18, 2013 Share Posted February 18, 2013 I do like the banjo solution, in theory, especially for those that consider swapping the 'Quick'-Locks against an after market solution. Hubert Link to comment Share on other sites More sharing options...
Splicer Posted February 21, 2013 Share Posted February 21, 2013 Pipe thread has a taper thread that will tighten as it is screwed into the mating part. I use "Leak-Lock" or liquid pipe sealer instead of teflon tape. The fitting you are using has too many barbs on it. There are fittings with a single barb for repeated unhooking and use a fuel injection hose clamp that will not mar the fuel line. I hope there won't be a next time, but if there is I'll know better. Thanks! Link to comment Share on other sites More sharing options...
Motormike Posted February 23, 2013 Author Share Posted February 23, 2013 Found the OEM plastic elbow on Guzzibits. $31.50 US. Ouch! Link to comment Share on other sites More sharing options...
gstallons Posted February 28, 2013 Share Posted February 28, 2013 $31.50 is better than N/A ! Link to comment Share on other sites More sharing options...
