The AC results are correct, reaching 80v. (I was stupid enough)
What Kiwi Roy said oktober 15- 2014.  Best way to avoid all the electric traps around is getting an RR  connected direct to the battery. Loose the bullet connectors. Have 4 V11 with direct RR to the battery, very happy. It's not a big job. Charging problems has left my head.
Cheers Tom.
Tomchri
Thanks for the reminder, let me reconsider this.
Posted (edited)
Cheers Tom.
RR ?
 Lagrasta , the temp gun was to check for heat buildup due to a poor connection. I have a couple of them and a FLIR camera to see any bad connections.  If the connector is the problem , you can use crimp connectors to make a permanent connection and when the time comes you can cut them with side cutters.
Edited by gstallons
more info
19 hours ago, gstallons said:
RR ?
Regulator-rectifier  :rasta:.
Cheers Tom.
If you have EVER used a thermal imaging camera , you know what heaven is.
  • Haha 2
Well it's working, but maybe only a band-aid, not actually corrected. @Tomchri I ran a direct wire from the RR to the battery, took it for a ride and it now has higher voltage at higher rpm, as it should. Thank you. (The RR I bought came with a long power wire just for this reason, but wanting to keep it OEM, I had originally chose not to use it.)
The problem now is this all started when my 30a fuse started to melt at the base (not blowing). I replaced it with a CB, but that hasn't helped other than allowing me to push the button rather than replacing a melted fuse.
As it is now I'm concerned that there is still a short in that main harness. A friend tells me the additional wire will help add resistance and may in effect make up for the fault.
To truly repair this, I believe I'll need to remove the tank and replace this power line. For now, I'll see how this fares.
Kiwi Roy rules.  The electrical system is on holiday, never mind the 30amp.  And the update is not really visible.
Cheers Tom.
Cheers Tom.
Posted (edited)
I am going to say your connection at the fuse holder has been the problem all along. The burnt leg of the fuse was an indicator of a poor connection .  I wish you had mentioned this , it would have saved a lot of thinking. Did you install a CB into the existing wiring harness ?
Is it made like Docc's CB ?
 Any time you have this burn from a poor connection the wire(s) have the same burn and the connection suffers and the resistance increases (not good) greatly.  I can't wrap my head around this bike and factory regulator running this gauge of wire for the charging . If you were aware of electrical systems it would be like hooking up a gen-set to your house with a cheap 2 wire 110v extension cord.
 Your friend can add resistance if he wants to but you don't need to. Less resistance is what you're after.
Edited by gstallons
Posted (edited)
Yes, I swapped to a CB, per Docc.
As for less vs more resistance. Less is now what the OEM line has due to the added resistance the new line. Make sense?
the OEM red/green wire also powers …fuel relay?
Edited by LaGrasta
I don't have my diagrams in front of me, but I would say "no." The fuel/ignition harness is entirely separate from the start-charge-lights harness.
The red/green wire should be charging power into your circuit breaker and the other leg of the CB should go directly to battery positive. Is this the case?
yes @docc, this is the case. However, I was going to disconnect the red/green altogether as I've now run a direct wire from the positive battery to the RR. However, when I did this, no electricity at the key. So I expect the red/green powers something else essential.
I did look at the schematic, but my eyes went goofy navigating the lines and colors. :rolleyes:
I just returned from about 25 miles. All seems well, voltage going up and down dependent on rpm, just as it should.
The V11 power never grows old. After riding my other bikes(V7, GL500, ZG1000) the last couple of months while this was being worked on, this V11 seems like a beast, so much more fun to twist the throttle. I breached the ton a few times today!
On a closed circuit, of course. None of us would ever do that on a public B road, would we?  :whistle: B)
  • Haha 3
