bulkbiker Posted May 2, 2016 Share Posted May 2, 2016 Hi All Just got the V11 Scura home to find that the rubber plug that covers the timing cover hole has come out during the ride back and covered my boot and the rear tyre in oil.. nice.. Wondered why it handled like a pig! Has anyone had this happen to them before ?i .e. should I try and get two new plugs so I have a spare to hand in case it happens again? Thanks Mark Link to comment Share on other sites More sharing options...
czakky Posted May 2, 2016 Share Posted May 2, 2016 If there is actually oil coming from there I wouldn't be worried about the plug. There shouldn't be any oil on the flywheel. Take a look at your crankcase vent hose. Or just use a cork for a plug... Link to comment Share on other sites More sharing options...
footgoose Posted May 3, 2016 Share Posted May 3, 2016 when I bought the Tenni new. The first oil change was done at the dealer. They over filled it and it blew oil out. It's been so long I cant remember where it came out. If you just had it serviced, I would follow that up. Shouldn't be any oil in there, and I'm not sure why the plug would come out, unless it wasn't put in correctly. Link to comment Share on other sites More sharing options...
moto fugazzi Posted May 3, 2016 Share Posted May 3, 2016 The rubber plug can be purchased from a dealer or MGcycle. http://www.mgcycle.com/index.php?main_page=product_info&cPath=55&products_id=1467 Ken Agreed, there shouldn't be oil coming out of that hole! Link to comment Share on other sites More sharing options...
bulkbiker Posted May 3, 2016 Author Share Posted May 3, 2016 Hi Guys Thanks for all the input.. when you guys say it its obvious there shouldn't be oil coming out.. The bike hasn't been ridden since it was serviced and had a new clutch over a year ago so will have a good hunt around to see where the oil came from. I'm guessing the plug wasn't put back in properly.. also lost one of the plugs on the seat where the single seat cover screws in... have looked on the microfiche but can't see a part number for that.. does anyone know if they are available? Cheers and thanks all Mark Link to comment Share on other sites More sharing options...
rossi46 Posted May 3, 2016 Share Posted May 3, 2016 Hi mate I see your in the UK-try motomecca-gutsibits or stein dinse (germany) part number 7 below? http://www.stein-dinse.biz/eliste/index.php as others have said no oil from there, give it a good clean up ,check oil level try and see where its from- could be something simple Link to comment Share on other sites More sharing options...
bulkbiker Posted May 3, 2016 Author Share Posted May 3, 2016 Hi mate I see your in the UK-try motomecca-gutsibits or stein dinse (germany) part number 7 below? http://www.stein-dinse.biz/eliste/index.php as others have said no oil from there, give it a good clean up ,check oil level try and see where its from- could be something simple Yep thanks for that called Motomecca this morning and new bung on the way.. ordered 2 just in case.. needs a damn good clean anyway as it's been sitting around for a while..will be investigating oil levels etc later on today. Thanks again M Link to comment Share on other sites More sharing options...
docc Posted May 5, 2016 Share Posted May 5, 2016 More than one way to skin a cat! Courtesy of czakky: 1 Link to comment Share on other sites More sharing options...
victor Posted May 5, 2016 Share Posted May 5, 2016 jajaja superb. :grin: Link to comment Share on other sites More sharing options...
vuzzi Posted May 6, 2016 Share Posted May 6, 2016 If there is oil coming from that hole, my guess is the seal ring between crank shaft and fly wheel leaks and puts oil air pressure in fly wheel compartment. The air pressure made the plug pop out. Link to comment Share on other sites More sharing options...
Stick Posted May 6, 2016 Share Posted May 6, 2016 More than one way to skin a cat! Courtesy of czakky: Ahhh, I like mine aged at least 15 years.... Link to comment Share on other sites More sharing options...
docc Posted May 6, 2016 Share Posted May 6, 2016 More than one way to skin a cat! Courtesy of czakky: Ahhh, I like mine aged at least 15 years.... uuh, the Girls & Guzzis thread is in another subforum. 1 Link to comment Share on other sites More sharing options...
bulkbiker Posted May 8, 2016 Author Share Posted May 8, 2016 ok got a new plug and realised that the oil is coming out from somewhere at the top of the engine then dripping down... big clean up today to try and find the source.. the bike hadn't been ridden for about 7 years although had a lot of work done in 2015..including single plate clutch replacement with a twin. Any further idea of where its coming from.. new to these so any input much appreciated. Thanks again Mark Link to comment Share on other sites More sharing options...
Steve S Posted May 8, 2016 Share Posted May 8, 2016 Mark, just had the same thing happened to my old Greenie, the oil was everywhere, turned out to be the big breather hose that goes from the top of the crankcase to the spine frame at the steering head, it had split at the top end, £11 from Gutsibits. Link to comment Share on other sites More sharing options...
bulkbiker Posted May 8, 2016 Author Share Posted May 8, 2016 Hi Steve Many thanks for that will try and take a look when its clean! Rgds M Link to comment Share on other sites More sharing options...
