Stumble_t Posted August 24, 2017 Share Posted August 24, 2017 Hello all, I'm looking to convert a riser bar equipped Cafe' Sport to a clip-on set up. Please let me know what you might have. I am located in the San Francisco Bay Area Link to comment Share on other sites More sharing options...
footgoose Posted August 27, 2017 Share Posted August 27, 2017 Do you have to swap upper clamp to use clip-ons? No doubt you want to plug the holes. I wonder how much extra cabling you might have. I have never ridden a "handlebar" Sport, but the clip-ons are really nicely positioned. I had MPH risers ordered for so long (waiting on mfg) that by the time I got them, I had changed my mind on using them. Link to comment Share on other sites More sharing options...
Stumble_t Posted August 28, 2017 Author Share Posted August 28, 2017 Thanks for the reply footgoose Do you have to swap upper clamp to use clip-ons? Not Necessarily, But when using the OE clip-ons there is a tapped thread in the upper TC for use with the locator screw. This screw also may prevent the bars from swiveling away from their located position and of course, looks stock. I have read that considering the OE clip-ons only use one clamp bolt, it might not be a bad idea to use that screw as well to insure they stay put. I had MPH risers ordered for so long (waiting on mfg) that by the time I got them, I had changed my mind on using them. The MPH risers allow you to raise the OE bars, What I'm trying to do here is replace the riser bar setup that was fitted from the factory with the other models stock clip-ons so they won't be much use to me, sorry if that was unclear. If this search doesn't pan out, I'll probably go with a set of Tommaselli's or Woodcrafts, but I want to see whats out there first. BUMP! Link to comment Share on other sites More sharing options...
coreytrevor Posted August 28, 2017 Share Posted August 28, 2017 I've been running the stock clip-ons without the 6mm bolt for a while, to be able to change the bar angle. They are very solid as long as the pinch bolt is tight. I think the bolt is just there as a locator so the bars end up where the factory wanted them. Link to comment Share on other sites More sharing options...
footgoose Posted August 28, 2017 Share Posted August 28, 2017 Thanks for the reply footgoose Do you have to swap upper clamp to use clip-ons? Not Necessarily, But when using the OE clip-ons there is a tapped thread in the upper TC for use with the locator screw. This screw also may prevent the bars from swiveling away from their located position and of course, looks stock. I have read that considering the OE clip-ons only use one clamp bolt, it might not be a bad idea to use that screw as well to insure they stay put. I had MPH risers ordered for so long (waiting on mfg) that by the time I got them, I had changed my mind on using them. The MPH risers allow you to raise the OE bars, What I'm trying to do here is replace the riser bar setup that was fitted from the factory with the other models stock clip-ons so they won't be much use to me, sorry if that was unclear. If this search doesn't pan out, I'll probably go with a set of Tommaselli's or Woodcrafts, but I want to see whats out there first. BUMP! yeah, I'm trackin' what you want to do. just sayin you'll like the oem clip on riding position on the spine frame. The stockers have a nice anti-vibe design inside the bars too. hope you can find that setup. Link to comment Share on other sites More sharing options...
Stumble_t Posted August 29, 2017 Author Share Posted August 29, 2017 I've been running the stock clip-ons without the 6mm bolt for a while, to be able to change the bar angle. They are very solid as long as the pinch bolt is tight. I think the bolt is just there as a locator so the bars end up where the factory wanted them. Thanks coreytrevor, that gives me some peace of mind. yeah, I'm trackin' what you want to do. just sayin you'll like the oem clip on riding position on the spine frame. The stockers have a nice anti-vibe design inside the bars too. hope you can find that setup. Thats a good point footgoose. I've gotten used to that feature on my Falco's so that would be a welcome addition on the V11. Link to comment Share on other sites More sharing options...
coreytrevor Posted August 29, 2017 Share Posted August 29, 2017 I've been running the stock clip-ons without the 6mm bolt for a while, to be able to change the bar angle. They are very solid as long as the pinch bolt is tight. Not only that, but I had the MPH risers mounted, still without the 6mm bolt and they still stayed put even with the extra leverage. Link to comment Share on other sites More sharing options...
