dbarb3 Posted September 22, 2021 Share Posted September 22, 2021 I am a little confused, will Guzzi Diag reset the TPS on the 15M Link to comment Share on other sites More sharing options...
docc Posted September 22, 2021 Share Posted September 22, 2021 46 minutes ago, dbarb3 said: I am a little confused, will Guzzi Diag reset the TPS on the 15M No, Sir. The TPS is set with a quality voltmeter to 157 mV with the throttle plate completely closed (linkage released, high idle cam released, right idle stop screw backed all the way off, clean bore and plate edge, and perhaps even lightly zip tied closed). This effectively indexes the map to the throttle angle. It is a fiddly operation as the TPS is so very sensitive. You will get a feel for how much it changes with the tightening of the fasteners and take this into account until repeated attempts finally produce the desired value. Changing the fasteners from the factory Torx/star to hex drive and obtaining a Casper's Breakout Harness (or equivalent) are helpful. 2 Link to comment Share on other sites More sharing options...
dbarb3 Posted September 22, 2021 Author Share Posted September 22, 2021 So any map changes and it has to be reset Link to comment Share on other sites More sharing options...
docc Posted September 22, 2021 Share Posted September 22, 2021 Hmm, I don’t know about that. Seems like the map would still index to the start point? 4 Link to comment Share on other sites More sharing options...
po18guy Posted September 22, 2021 Share Posted September 22, 2021 It strikes me that throttle plate position/TPS setting are the one constant in the process. All other alterations to fuel flow relate to the position of the throttle plates and consequent airflow. Unless... 2 Link to comment Share on other sites More sharing options...
MartyNZ Posted September 22, 2021 Share Posted September 22, 2021 4 hours ago, dbarb3 said: So any map changes and it has to be reset Nope, the TPS provides a voltage to the ECU that depends on throttle position. The ECU interprets that voltage as throttle open angle, no matter what map you use. If you have a later model, eg Griso, things are different 1 1 Link to comment Share on other sites More sharing options...
dbarb3 Posted September 22, 2021 Author Share Posted September 22, 2021 So if Todd reflashes the ECU on 2002 Lemans will TPS have to be reset manually Im learning but Im used to doing everything electronically Link to comment Share on other sites More sharing options...
Lucky Phil Posted September 22, 2021 Share Posted September 22, 2021 12 minutes ago, dbarb3 said: So if Todd reflashes the ECU on 2002 Lemans will TPS have to be reset manually Im learning but Im used to doing everything electronically No, and why are you getting the ECU "reflashed" when Guzzidiag is available. Ciao 1 Link to comment Share on other sites More sharing options...
dbarb3 Posted September 22, 2021 Author Share Posted September 22, 2021 So if Todd reflashes the ECU on 2002 Lemans will TPS have to be reset Link to comment Share on other sites More sharing options...
dbarb3 Posted September 22, 2021 Author Share Posted September 22, 2021 I need to spend some time on that one I guess Link to comment Share on other sites More sharing options...
docc Posted September 22, 2021 Share Posted September 22, 2021 26 minutes ago, dbarb3 said: So if Todd reflashes the ECU on 2002 Lemans will TPS have to be reset 24 minutes ago, dbarb3 said: I need to spend some time on that one I guess The TPS baseline is part of a "Decent Tune-up." Personally. I would go this route before having someone alter the map: Link to comment Share on other sites More sharing options...
Lucky Phil Posted September 23, 2021 Share Posted September 23, 2021 5 hours ago, dbarb3 said: So if Todd reflashes the ECU on 2002 Lemans will TPS have to be reset I've answered this already. Ciao Link to comment Share on other sites More sharing options...
dbarb3 Posted September 23, 2021 Author Share Posted September 23, 2021 Did the 3 hour deep dive on Guzzi Diag Who is actually using the 93 map Link to comment Share on other sites More sharing options...
docc Posted September 23, 2021 Share Posted September 23, 2021 2 hours ago, dbarb3 said: Did the 3 hour deep dive on Guzzi Diag Who is actually using the 93 map I recall @MartyNZ is running a Meinolf map; not sure if it is v.93 . . . Link to comment Share on other sites More sharing options...
MartyNZ Posted September 23, 2021 Share Posted September 23, 2021 2 hours ago, docc said: I recall @MartyNZ is running a Meinolf map; not sure if it is v.93 . . . Yes, I'm running Meinolf's v93, and I'm very happy with it. https://www.v11lemans.com/forums/index.php?/topic/22024-meinolfs-v11-bin/&tab=comments#comment-253138 @dbarb3if you use the search function on this site you can find lots of information to help you. 1 Link to comment Share on other sites More sharing options...
