Steering damper
Guest Squashed Nose
Guest Squashed Nose
The steering damper on my bike lost its fluid several months ago (I have been waiting nearly three months for my dealer to come up with a replacement under warranty. I could have walked to Italy and back in less time!) Anyway, if I hadn't found the oil all over the inside of my fairing, there is no way I would have noticed any difference.
The steering geometry may be radical by MG standards but it is hardly ground breaking. What on earth is the steering damper doing on the bike in the first place? I haul the bike over far enough to grind the kickstand (and that's after cutting away half the rubber stop) and have never experienced anything nasty from the front end.
Is it merely a fashion accessory?
Being an Italian bike, it IS a fashion accessory! :lol:
But I see them as good to have also. If you are leaned way over and smack a set of railroad tracks in the middle of the curve, you will be glad to have it. (If it has been set properly.) We have a road like that locally. I use that corner to test suspension setups. With the damper set lowest on my V11S, it'll wobble once before recovering. I have found that the case on many of my bikes. With the damper adjusted so that some light resistance is felt side to side when the front wheel is off the ground, the same corner/tracks doesn't upset it at all.
Mine did weep fluid shortly after it was new. Guzzi refused to warranty it since most of them leak, it is considered normal. :wacko:
I took the end cap off of mine, drained the fuild (I measured it! But right now can't remember what it held. :huh: ), and refilled it with Power Steering Fluid with seal swell in it. The stuff is made to stop weeps in hydraulic steering systems. It took some time to take effect, but it worked. Now it weeps just a tiny bit. Just enough to gather some dirt over time. But I no longer find droplets running back along the tank after a hard freeway run!
I'd say they are necessary. It was worth my time to repair mine and keep using it.
Guest Ragin' Pit Bull
I like having the steering damper. On smooth corners it isn't necessary, but corners aren't always smooth. And since I'll be using my Le Mans at the racetrack next year, I may even upgrade to the Ohlins unit found on the Scura and Rosso Corsa.
I had a couple of nasty head shakes on my rosso while riding aggressivly on rough roads, the steering damper was set on full soft. I have crashed twice in 30 years of riding because of headshakes and I was lucky not to crash as the shake was quite violent. I turned up the setting to approx. half way and on the same road all seems good. Around town I turn the damper to full soft but when you get silly and start to ride hard turn it up a notch. I think it would be a mistake to remove the damper.
I had the good fortune of watching Moto Guzzi's return to this year's Isle of Man TT races. Their Tenni had a noticeable wobble at the Rhen Cullen section where, bikes wheelie at well over 100 mph. I later found out that the brace that supports the steering dampner had snapped. Granted, most of us don't do the ton at the I.O.M. (maybe in our dreams) but, I'd wager that the steering dampner does do a bit of good.
If you find that you need the steering damper cranked up to get a stable ride, then it is possible that you need to do some suspension tuning. A steering damper can certainly compliment a well set up bike, but a damper can also mask serioius suspension problems.
I found that after I adjusted my suspension settings, I was able to back the steering damper all the way off and still have a very stable ride.
__Jason
00 M900Dark
00 V11 Sport
__Jason
00 M900Dark
00 V11 Sport
That's a very good point especially since the preload on our bikes are hard to get to with the stock airbox.
All you need to do is take a gas tank off and a sctewdriver and small hammer does an easy job.
Do not forget dabble some oil between the ring/spring as per Shop Manual. The factory wrench is totally useless.
  • 10 months later...
I add a reply to this old thread instead of starting a new,
Previously I have mentioned that I removed the stock Bitubo steering damper
and found the bike much "lighter" to handle with no loss of stability.
But there is always the danger of tank slap when running without one.
Late in this season I mounted a Öhlins damper on my V11
and I can only say it is great. With loose to medium setting
it is not noticeble, it is just like running without.
This is what we want added safety and no ill effects.
Pricey, yes. Luckily I found a 2nd hand damper at a resonable price.
Do you recall the dimensions or cross-reference(which ones from other bikes fit the V11) for the Ohlins you used?
Knowing this would be helpful for those that may need to replace a defective Bitubo unit, and can find a nice used Ohlins on eBay from another bike.
thx!
al
I have had damper on my Scura set to lowest setting since new & was thinking of removing it.The bike hasn't shaken it's head & I'm interested to see. On my LM11 I removed the damper & sawed off the bracket too :rolleyes: ! It regularly shakes it's head quite dramatically light over crests but settles down after 3 or 4 oscillations. I like to feel what's going on...The V11 feels pretty stable. I dunno - but I feel a damper just masks other problems. Suspension set up like Jason says.
Gythni - did you actually get any headshakes when you were running V11 without a damper?
Rich - The earlier V11's had steeper head I think, less stable.
Apparently only the 2000 an 2001 had the nervous geometry.
I find the damper helpful as the tire wears and cups. With a new front tire I go back to the zero setting on the damper. With a new tire and no damping the bike feels 150 pounds lighter! :bike::bike:
al:
I use an universal damper, partno SD 100
it has 120 mm stroke, but since the bitubo
only has 80 mm stroke it points out a bit (no biggie)
I think an univeral Öhlins with 90 mm stroke should
be the ultimate choice, partno SD 110
baldini:
no head shake, but friends of mine have had sudden
scary experiences on otherwise stable bike.
Better save then sorry, and since the unit from Öhlins
does not restrict me at all I feels like a good investment.
I put the 2003 Öhlins catalog
on my site for your pleasure :luigi: . Warning! Not suitable for sensible persons,
this is hard core bike porn :D
I have an '01 sport and it's stable like a rock- I backed the steering damper off in the first week I had the bike. I've just never needed it. The handling did improve marginally when I softened the front and rear suspension (from stock).
Cheers,
Jason
