docc Posted March 16 Posted March 16 "I'll see your weedy Cherry Bomb and raise you a Staintune full system" . . . 1 2
Pressureangle Posted March 17 Author Posted March 17 Well, just confirmed I won't be getting Mike Rich cylinder heads. Drat. <increases motivation> 1
gstallons Posted March 17 Posted March 17 (edited) Mmmmm. your auditor came in while you were looking at motorcycle porn ? Get it runnin' first ! Edited March 17 by gstallons spelling error 2
docc Posted March 17 Posted March 17 1 hour ago, Pressureangle said: Well, just confirmed I won't be getting Mike Rich cylinder heads. Drat. <increases motivation> Is Mike Rich doing anything Moto Guzzi, now? Still sells his valves for the V11?
Pressureangle Posted March 17 Author Posted March 17 2 minutes ago, docc said: Is Mike Rich doing anything Moto Guzzi, now? Still sells his valves for the V11? He's 10-12 months out so not taking any work. Says OEM parts are getting hard to come by, like lifters but everything for the heads is available aftermarket. I have some very competent cylinder head machinists locally, and with stock cam/valve sizes 80% of the power increase of porting is probably in the valve head and valve seat anyway, so with Mike's input (hopefully) I'll do it myself and locally. 3
Pressureangle Posted March 18 Author Posted March 18 Is it just me, or is there no master cylinder rebuild available? MG, Harper's, Bevel Heaven...nobody seems to got.
Pressureangle Posted March 18 Author Posted March 18 2 hours ago, gstallons said: Which master cylinder are you referring to? The front, though looking at what came out of it I'll be doing the rear and all the calipers as well.
PhillipLarsen Posted March 18 Posted March 18 I bought rebuild kits for all master cylinders and callipers for my 2004 Ballabio last year from Powerhouse Automotive in UK. You can find them on ebay and their own website. If you don’t see what you need just ask them. They had it all for me and service was fast to Canada. 3
gstallons Posted March 18 Posted March 18 (edited) 2 hours ago, Pressureangle said: The front, though looking at what came out of it I'll be doing the rear and all the calipers as well. All these brake parts on these bikes are Brembo. You should be able to find a Brembo dealer/vendor that can hook you up w/all the rebuild kits you will need to do this. I would do everything so you will be finished and not have any worries. I am not sure about the hydraulic clutch master/slave parts. Also, Ducati (along w/most Italian brands) use Brembo on their bikes, maybe you can get some help there. This is the first day, so maybe someone will come through w/a good lead. When you go back together use Raybestos brake assy. lube and ALWAYS use new DOT4 fluid. Brake fluid is extremely hygroscopic so always use new fluid. Purchase small bottles so you can dump the rest in your car , truck or whatever donor you have . Edited March 18 by gstallons spelling error 2
gstallons Posted March 18 Posted March 18 6 hours ago, Pressureangle said: Is it just me, or is there no master cylinder rebuild available? MG, Harper's, Bevel Heaven...nobody seems to got. On Harper's , go to brakes and the scroll down , they show front & rear kits but no caliper kits. Rear m/cyl. kit 17659350 for $39.44 and the front kit 17659352 is $29.95 .
Pressureangle Posted March 18 Author Posted March 18 22 minutes ago, gstallons said: On Harper's , go to brakes and the scroll down , they show front & rear kits but no caliper kits. Rear m/cyl. kit 17659350 for $39.44 and the front kit 17659352 is $29.95 . Those are for the older round reservoir integrated masters. I do like to see all the parts myself, but some bits like the handlebar master cylinders are less expensive than expected so I may just buy new ones. 1
docc Posted March 18 Posted March 18 U.S. Brembo supplier: https://www.oppracing.com/ V11 caliper rebuild kits listed in @Scud's Encyclopedia of Compatible Parts . . . 2
gstallons Posted March 19 Posted March 19 I would think MG Cycle would have/offer all these parts. I would patronize them (personal preference) first and see what they stock . The fr. brake master cyl is a 12mm bore and the rear brake is a 15mm bore. I THINK all the calipers are 32mm fr. & rr.. 1
Pressureangle Posted March 19 Author Posted March 19 4 hours ago, gstallons said: I would think MG Cycle would have/offer all these parts. I would patronize them (personal preference) first and see what they stock . The fr. brake master cyl is a 12mm bore and the rear brake is a 15mm bore. I THINK all the calipers are 32mm fr. & rr.. My front MC piston measures 15.85mm. hm. Powerhouse Automotive says they have caliper kits if I can confirm piston diameter, but they do not have master cylinder bits. <shrug>
