HRC_V4 Posted Saturday at 10:54 PM Author Posted Saturday at 10:54 PM I wish I could find the picture of when I pulled the clutch off my Quota, super simple, had it done in an afternoon. Not in a big hurry on this project, I still have not order parts yet, so just working on it when time permits. Spent an hour or so on it today, pulled the starter, front wheel and fender, clutch cable and then strapped the engine to the stand. Only three major steps next, front crash bar, center stand and transmission top plate. 2
HRC_V4 Posted Monday at 05:04 PM Author Posted Monday at 05:04 PM The California II has been crabbed! Not a bad job, it is giving me a reason to address a few things, I'm going to go ahead and replace the throttle cables, clean up some surface rust, deep clean a few hard to get places. I have the clutch upgrade kit on the way, the clutch job transmission seal kit, rear main engine seal and a couple of other things. 1
HRC_V4 Posted Monday at 05:04 PM Author Posted Monday at 05:04 PM Looks like I am missing the output shaft seal.... 1
HRC_V4 Posted Monday at 05:07 PM Author Posted Monday at 05:07 PM Does anyone have instructions on the swingarm install? I measured mine before I took it off, they were not equal side to side, which I thought was the way to do it, but with the missing seal, someone might have been in here before.
Pressureangle Posted Monday at 05:15 PM Posted Monday at 05:15 PM 5 minutes ago, HRC_V4 said: Does anyone have instructions on the swingarm install? I measured mine before I took it off, they were not equal side to side, which I thought was the way to do it, but with the missing seal, someone might have been in here before. Just center it up and you're good. Run it up and down just to be sure something won't snag, but I don't think there's enough latitude for adjustment to cause any trouble. 2
HRC_V4 Posted Monday at 06:07 PM Author Posted Monday at 06:07 PM The two clutch discs are stuck to the intermediate plate. I have not tried to separate them, but a fair amount of rust. I'm sure it will all clean up. 1
motortouring Posted Monday at 07:29 PM Posted Monday at 07:29 PM (edited) 15 hours ago, HRC_V4 said: Does anyone have instructions on the swingarm install? I measured mine before I took it off, they were not equal side to side, which I thought was the way to do it, but with the missing seal, someone might have been in here before. The formal method is to use an axle through the support bearing in the swingarm that has a ring to centre on the outgoing axle of the gearbox. Horizontal adjustment is with the swingarm bearing bolts and vertical is by fixing the bolts of the underframe and the battery plate. In practice centering the swingarm axle bolts (on the side) is the way to go. With many thanks to JCK from NL Edited 18 hours ago by motortouring 4
