- Past hour
The derived protocol takes more attention and involvement, but improves the outcome. Is it worth it? I can say, with certainty, mySport's performance (and reliability) is significantly better with optimal charging and battery strength. YMMV
Good news. Just got an email from batterystuff.com with a UPS tracking # and the charger is scheduled for delivery this Friday. Not to derail my own thread on my charging issue, but it sounds like going forward I should stop using the Battery Tender and use your protocol quoted here, amirite?
If I am reading this correctly, the odd charging light behavior started after the battery got cooked. And did not change with the new stator and regulator? Makes me think something also got cooked in the harness/connectors - seemingly in the circuit involving the instrument panel . . .
- Yesterday
Exactly. Over time, that low float voltage (below Odyssey's 13.2 minimum threshold) will "shorten battery life". How much? Unknown. But undesirable. Your new charger is likely configured to address this. Rather than the "tender" approach, I have grown fond of charging the Odyssey with at least 6 amps up to 15.0 volts, then float charge at 13.56v (what my EnerSys charger will float) for maybe 24 hours, then terminate charge and let the battery gradually discharge. Repeat when the static charge reaches 12.65v. _____________________________________________________________________________________ > LESS voltage on trickle/float is NOT okay. Odyssey states that floating under 13.2 damages the battery: "Note, however, that the charge voltage should not be dropped below 13.2V as that will cause the battery grids to corrode faster, thereby shortening the battery life."
Just went out to the garage - the DMM reads 13.12v with the Battery Tender attached. Close but no cigar?
Thanks Phil...very good and educational explanation...I'll try experimenting at the next oil changes on the Norge/Griso/Scura with a viscosity spread of 30...if I can perceive any improvement in performance, "feeling" and / or mileage that would be a bonus.
12v/1.25 Amp
