Dennis 4 Posted August 2, 2020 Report Share Posted August 2, 2020 Just started to change the oil on a 97 Centauro that I recently purchased. I'm new to Guzzies and was shocked that when I took off the oil filter cover, all of the oil drained out. I hadn't removed the drain plug first. I assumed the oil filter wasn't sealed or worse but I've been told that this is normal. If so, why is a spin-on oil filter immersed in the engine oil? 2 Quote Link to post Share on other sites
fotoguzzi 216 Posted August 2, 2020 Report Share Posted August 2, 2020 That's where the dirty oil is. 1 1 Quote Link to post Share on other sites
gstallons 767 Posted August 2, 2020 Report Share Posted August 2, 2020 # 1 the filter is located IN the oil pan because it is the best place to put it . Make sure you use a GREAT filter and get it tight . 1 Quote Link to post Share on other sites
Dennis 4 Posted August 2, 2020 Author Report Share Posted August 2, 2020 Ignoring the dirty oil answer and of course the oil filter has to be connected to the oil pan but there is no other car or motorcycle the has a spin-on filter in a chamber filled with oil. I don't get MG's thinking on this. Quote Link to post Share on other sites
paulnaz 37 Posted August 2, 2020 Report Share Posted August 2, 2020 Not that I can answer your question technically, however BMW has been doing that way since they introduced the K bikes back in the 80's. Paul B 1 Quote Link to post Share on other sites
Chuck 1,463 Posted August 2, 2020 Report Share Posted August 2, 2020 Quote I don't get MG's thinking on this. Yer new to Guzzi, ain't ya, boy? They started out with no filter at all. When they decided to use a filter, the least expensive change to the tooling was to put it inside the pan. It only needed to be changed once a year or 9000 miles, but people complained that it was too much work, even though it gives you a chance to have a peek up her skirt once a year and see if everything is ok, so they put the porthole in. I don't like the porthole in the Centauro.. it's fraught with danger..all too easy to cross thread.. Then, "You'd be in a heap of trouble, boy." So. To answer your question.. it's cost driven. Tooling changes are *expensive.* Guzzi was broke, as usual. Just the same, they produced some fine motorcycles during this period with very little money, and that is part of their allure to me. 1 Quote Link to post Share on other sites
gstallons 767 Posted August 2, 2020 Report Share Posted August 2, 2020 Also , back in the early 90s the GM 2.5l 4 cyl. had the filter in the pan . and a manhole cover to access it. Quote Link to post Share on other sites
Dennis 4 Posted August 2, 2020 Author Report Share Posted August 2, 2020 Thanks for the info guys. I have a 2000 BMW R1200C and they don't do it like the K's. Seems to defeat the purpose of having a spin-on filter. In any event, my filter is on so tight I can't loosen it and I don't want to take a chance of damaging the cover threads so it looks like I'm dropping the pan. Thanks again. Quote Link to post Share on other sites
Lucky Phil 1,906 Posted August 2, 2020 Report Share Posted August 2, 2020 1 hour ago, Dennis said: Ignoring the dirty oil answer and of course the oil filter has to be connected to the oil pan but there is no other car or motorcycle the has a spin-on filter in a chamber filled with oil. I don't get MG's thinking on this. There's your mistake right there imagining Guzzi had some form of rational engineering consideration here. It took them years to consider the fact that maybe people didn't want to have to remove the whole exhaust system and the sump assembly to simply replace the oil filter. Ever wondered why they decided to sink R&D money into hydraulic lifters on the worlds easiest to adjust valve clearance engine, or fitted the sports touring bikes with a sidecar lugging flywheel, or invented a shaft drive with a 15,000 klm factory recommended replacement interval, or DLC coated Griso tappets? Work out those questions and you will probably know why the made the filter internal. Ciao 3 3 Quote Link to post Share on other sites
Dennis 4 Posted August 3, 2020 Author Report Share Posted August 3, 2020 I guess one of the attractions to a Guzzi is the quirks. Quote Link to post Share on other sites
Chuck 1,463 Posted August 3, 2020 Report Share Posted August 3, 2020 1 hour ago, Dennis said: I guess one of the attractions to a Guzzi is the quirks. I'll be serious for a change. I've kept 17 Guzzis now.. I've tried all of the "modern" Guzzis from the V700 to the Norge. Big block, small block, 2V, 4V. It's the engine. I love the sound and feel of Guzzi engines. Maybe the sweetest was the Monza.. but the Aero engine has it's own character, too. Then there is the Mighty Scura which is not too subtle about what it's about. I also loved the Centauro engine. Like all Guzzi engines, it wants you to feel involved in it's care and feeding. Sweet runner, too.. after a bit of sorting. 2 1 Quote Link to post Share on other sites
PJPR01 60 Posted August 3, 2020 Report Share Posted August 3, 2020 Guzzis are like that famous country song refrain: Love me or hate me, but please don't ignore me! Quote Link to post Share on other sites
Lucky Phil 1,906 Posted August 3, 2020 Report Share Posted August 3, 2020 8 hours ago, Dennis said: I guess one of the attractions to a Guzzi is the quirks. Guzzis exist for engineers, or people that aspire to be engineers. Ciao Quote Link to post Share on other sites
gstallons 767 Posted August 4, 2020 Report Share Posted August 4, 2020 My 87 SE hits like a 50 cal. pistol w/every combustion stroke , twists to the right with a blip of the throttle and the rear rises under acceleration with a powerband above 5k you would feel once in a lifetime and I wouldn't have it any other way ! 1 Quote Link to post Share on other sites
po18guy 519 Posted August 4, 2020 Report Share Posted August 4, 2020 1 hour ago, Lucky Phil said: Guzzis exist for engineers, or people that aspire to be engineers. Ciao Or, from our Boeing experience, they exist for people who are constantly forced to correct engineers. 2 Quote Link to post Share on other sites
Join the conversation
