sp838 Posted April 22, 2019 Share Posted April 22, 2019 Hello all! Long long time no chat, I hope everyone and their Guzzi are well! So I stumbled on this the other day while surfing the 'tubes: https://hmb-guzzi.de/RAM-single-disc-clutch I've been kicking myself for not getting a RAM clutch for my bike years ago, was wondering if this one would work in my 2001 V11 Sport Naked. Credit card is burning a hole in my pocket... Thanks for any insights! Cheers Link to comment Share on other sites More sharing options...
Lucky Phil Posted April 22, 2019 Share Posted April 22, 2019 37 minutes ago, sp838 said: Hello all! Long long time no chat, I hope everyone and their Guzzi are well! So I stumbled on this the other day while surfing the 'tubes: https://hmb-guzzi.de/RAM-single-disc-clutch I've been kicking myself for not getting a RAM clutch for my bike years ago, was wondering if this one would work in my 2001 V11 Sport Naked. Credit card is burning a hole in my pocket... Thanks for any insights! Cheers It will but the gearbox input drive spline won't fit the 6 speed gearbox and the clutch pushrod MAY need to be modified. You can still buy the 6 speed input drive spline separately. ciao 1 Link to comment Share on other sites More sharing options...
sp838 Posted April 23, 2019 Author Share Posted April 23, 2019 Thanks for the reply... Not sure I fully understand which part you mean by input drive spline. Is this an OEM part? Wouldn't I be able to use the input drive spline already in my bike? If not, is it an aftermarket part of some sort? Grazie! Link to comment Share on other sites More sharing options...
Lucky Phil Posted April 23, 2019 Share Posted April 23, 2019 5 hours ago, sp838 said: Thanks for the reply... Not sure I fully understand which part you mean by input drive spline. Is this an OEM part? Wouldn't I be able to use the input drive spline already in my bike? If not, is it an aftermarket part of some sort? Grazie! The kit comes with the gearbox input spline for the 5 speed box which won't fit your 6 speeder but you can use your original one if its not badly worn. Seems a shame though to fit a whole new clutch and flywheel and use an already worn gearbox input drive. ciao Link to comment Share on other sites More sharing options...
sp838 Posted April 23, 2019 Author Share Posted April 23, 2019 3 hours ago, Lucky Phil said: you can use your original one if its not badly worn. Ok so it's an OEM part then. Still trying to decipher which one you mean. I found this on MG Cycle, is this it? Harpers also has it for a little less but this page has a photo: http://www.mgcycle.com/index.php?main_page=product_info&cPath=193&products_id=5222&zenid=d343c0c5bc66a5898d4ef0d0ab532f67 Link to comment Share on other sites More sharing options...
Lucky Phil Posted April 23, 2019 Share Posted April 23, 2019 2 hours ago, sp838 said: Ok so it's an OEM part then. Still trying to decipher which one you mean. I found this on MG Cycle, is this it? Harpers also has it for a little less but this page has a photo: http://www.mgcycle.com/index.php?main_page=product_info&cPath=193&products_id=5222&zenid=d343c0c5bc66a5898d4ef0d0ab532f67 That's it ciao Link to comment Share on other sites More sharing options...
sp838 Posted April 23, 2019 Author Share Posted April 23, 2019 Grazie mille! Link to comment Share on other sites More sharing options...
bbolesaz Posted April 24, 2019 Share Posted April 24, 2019 I've never heard a good answer on the clutch pushrod issue associated with using this clutch on a 6-speed. Link to comment Share on other sites More sharing options...
sp838 Posted April 24, 2019 Author Share Posted April 24, 2019 That's the last piece of the puzzle, but should be the least difficult part to sort out... *famous last words* Link to comment Share on other sites More sharing options...
Lucky Phil Posted April 24, 2019 Share Posted April 24, 2019 4 hours ago, sp838 said: That's the last piece of the puzzle, but should be the least difficult part to sort out... *famous last words* From my dodgy memory the clutch pushrod needs to be machined down slightly on the OD at the pressure plate end to fit the ram pressure plate actuating button unless you can source a std single disk pushrod. Ill find out soon as I'll be fitting a 6 speed box behind my Daytona engine with a RAM clutch. whatever, it's not a big deal to sort out. ciao 1 Link to comment Share on other sites More sharing options...
sp838 Posted April 25, 2019 Author Share Posted April 25, 2019 So from a Scura for example? Link to comment Share on other sites More sharing options...
swooshdave Posted April 25, 2019 Share Posted April 25, 2019 18 hours ago, Lucky Phil said: From my dodgy memory the clutch pushrod needs to be machined down slightly on the OD at the pressure plate end to fit the ram pressure plate actuating button unless you can source a std single disk pushrod. Ill find out soon as I'll be fitting a 6 speed box behind my Daytona engine with a RAM clutch. whatever, it's not a big deal to sort out. ciao Most clutch pushrods have hardened ends so when shortening it's prudent to re-harden the end. Link to comment Share on other sites More sharing options...
sp838 Posted April 25, 2019 Author Share Posted April 25, 2019 23 hours ago, Lucky Phil said: unless you can source a std single disk pushrod Looking at part numbers, it appears that the clutch pushrod for single disc and double disc bikes is the same: GU01085730 I'm looking at the parts fiches for my bike (2001 V11 Sport Naked - double disc) and comparing to the MGS-01 Corsa which is single disc. They both use the same pushrod... V11 Sport Naked parts: https://www.af1racing.com/store/ProdImages/st3/GU013.pdf MGS-01 parts: https://www.af1racing.com/store/ProdImages/st3/GU076.pdf The 2002 Scura and Tenni, both single disc clutch, also appear to use the same pushrod Link to comment Share on other sites More sharing options...
docc Posted April 25, 2019 Share Posted April 25, 2019 There are a couple pages of discussion on this, with images as I recall, in my Sticking Clutch thread. I’ll try and track it down this evening. Link to comment Share on other sites More sharing options...
docc Posted April 25, 2019 Share Posted April 25, 2019 Alright, here we go. Check out this thread by craigsinclair. That is linked in the RAM conversion discussion in the thread "Sticking Clutch." The discussion is on pages 2-4 and the link is to a post by footgoose with some actual dimensions. Link to comment Share on other sites More sharing options...
