@swooshdave, what is the length of your tang (relative to the wire "lever")?
Isn’t that a personal question? :blush:
  • Haha 4
24.302mm
I don't have a tang so you'll need to find one and measure it. They are pretty long so it's not much of a comparision.
18 minutes ago, swooshdave said:
24.302mm
Looks like the factory wire "lever" is ~110mm, offset about 64mm for its curve around the exhaust.
Obviously too long to prevent the leverage from breaking the mounting points, eventually.
It's that long length plus questionable wire material that is the downfall of the stock piece. But I don't see the mounting points breaking. Isn't the side stand made from forged steel?
Aluminum, me thinks. Looks like a casting to me. :huh2:
14 minutes ago, docc said:
Aluminum, me thinks. ...
Holding a magnet against it might give a clue. :huh2:
I did. Nonmagnetic.
The forming lines look like a casting to me, but I know forging can makes lines (seams) like that, as well.
18 minutes ago, docc said:
The forming lines look like a casting to me, ...
Yeah, I would have guessed a casting, too.
I know there are castings that are non-magnetic and not aluminium, but my impression is that that is usually some sort of muck metal that doesn't hold up to much. The side-stand is a highly stressed part, ergo probably aluminium as you wrote. :)
I drilled into the bottom of the foot on my '97 to add some material (a bolt head) and discovered that the leg is actually steel cast inside the aluminum body. I'm far more worried about bending/breaking the mount than the leg itself.
34 minutes ago, Pressureangle said:
... the leg is actually steel cast inside the aluminum body.
That's interesting. Thanks for the info. :)
Very interesting, and seemingly a more complex part than you would think.
Mine never had one. It was a Friday afternoon special built from the reject parts bin I think. I never replaced the tang and don't miss it. I'm not too fussed about keeping it original which is lucky.
Every V11 made is a prototype so don't think you are exclusive !
  • Haha 3
