This stream auto-updates
  1. Past hour
  2. -Jumper wire to black wire to regulator: Battery light gradually came on at 3K rpm, and got brighter towards 4K. -Jumper to white wire to reg at idle and revved got no battery light.
  3. Ohms were, at various DMM settings. (I am stupid, ignorant, uneducated about which is the appropriate or meaningful setting): 70 @ 200 7 @ 2000 0 @ 20K
  4. If you look at the original Moto Guzzi sales literature you will see that the valve covers on RM, Rosso Corsa, and Nero Corsa are a lighter shade of red (approaching orange) then the most common red on the frame plates. When I got my Nero, they had both been painted to match the Nero Corsa script on the tail. But I replaced them with a candy-apple red powder coat set, which is close to the original metallic red but give it a bit more depth and character. And to my eye, is a nicer fit with the Nero. Also note, the angle/lighting makes the parts look different colors, but they are the same (so is the alternator cover).
  5. That's the best looking Tenni deal I've seen in recent memory. $6k / 11k mi. and looks well kept. The clutch swap shouldn't matter. If the owner isn't sure then it likely has not been addressed. Buy it - fix it.
  6. Today
  7. Tired of frequently having to tighten the kickstand bolt, I decided to replace it. To do this, I had to remove the left-hand exhaust to make enough space to take out the Allen bolt and replace it with a hex head. It was also the perfect opportunity to remove VroomHilda's skirts, which I had been wanting to do for a while. Not only does this allow me to showcase the engine, but it also gives me easier access to the oil dipstick and several other components, all while streamlining her appearance. I love the new look and have been building up the courage to make this change for years. Remember: measure fifty-seven times and cut once!
  8. 2001 Rossa Mandello for sale. 4k miles. $6000. Long Island, NY. https://www.facebook.com/share/p/1LH7VCqzmS/
  9. The pipes look like Mistral reverse cone mufflers. I had them on a 02 Lemans..They have a kind of raspy sound. first question I’d be asking is “has the potentially exploding clutch been replaced?”
  10. Kapiti kiwi, Have a look at what Penrite has to offer. 100% shear free and full 100% PAO and Ester in 10W-40, 15W-50 and 20W-50. You can't go wrong here. Rob
  11. Tenni #108 for sale in Tucson, AZ. 11k miles. i'm unfamiliar with the pipes, but looks pretty clean with the exception of the terrible hack job on the rear tail light and fender. seems like an easy fix to get it back looking respectable. https://www.facebook.com/marketplace/item/758961083627712 for those who don't have FB, let me know if you want to get in touch and i will message the guy for you...
  12. i do believe you are right sir. i have not checked with Moto Guzzi to see if i can still order these parts, i am assuming no. but i shall check one of these days. i figured i would ask the question here first... i'll send you a PM @Scud. thanks for the offer, it is very much appreciated. and thanks again to all for the tips...
  13. I've been on glucosamine for about 20 years and Know it's kept a lot of my joint pain settled down. Age is catching up with me so I'm starting to feel some stiffness etc in my fingers but nothing serious as of yet.
  14. Different brands of paint matures differently. Same as w/hair on people's head.
  15. docc , off the top of my head , these switches : oil press. neut. , etc. are n.c. (normally closed) switches. Wiring diagrams should display n.c. or n.o. next to the switch for clarity and understanding of the circuit. MG does things "their way".
  16. last August actually. but i did just take that photo a few days ago...
  17. Closure? In that case, congratulations, @fastaussie!
  18. @Goofman speaks about this stickering business as if there is plausible deniability . . . Happily, the matter met the approval of the cheerful Sp'Honda-Raider . . .
  19. @Sam P, let's try to take the oil pressure light out of the equation. You reported the oil light illuminates when the connector to the switch is grounded. Connect your Ohm meter and measure resistance from the switch post to ground, key off. The switch should be closed/grounded with no oil pressure, resistance: near 0 [oil light on will come on KOEO]. If the switch is open with no oil pressure (engine off)/ resistance = > 1 < [no oil light KOEO], then the oil pressure switch has failed and has nothing to do with the odd behavior of the "battery/charging" light . . .
  20. I reckon the first assumtion was good. Battery cooked = regulator is not doing it's stuff, too many Volts into the battery = dead battery. Been there, done that (more than once... ). In those cases, the battery light didn't come on. I don't know for sure that the battery light never shows overcharging, but I understand it to be that the light generally only comes on when the system is undercharging. In that context, I would question the second assumption. Given that I don't expect the warning light to show overcharging, I wouldn't expect it to come on if the stator is delivering too many volts. Apart from the warning light, the regulator should take care of too many volts. That is, after all, what it is there for. The alternator delivers a voltage that increases with revs. The regulator is supposed to keep that under control and make sure that never more than about 14V gets through to the charging system. Regarding the third point, I've already written that I suspect that there are two problems. From the information that you have provided, it seems that your charging system is currently not working, despite the new regulator and stator. Therefore the charge warning light should be lit up all the time. It isn't, so it is fair to assume that there is also a problem somewhere in the circuit that the warning lamp is in. I'd still like to know what the resistance (Ohm) measurement is between the connector for the warning lamp to the regulator (where the blue wire is connected) to ground. If the regulator is behaving correctly, that should be close to zero with the key on, engine off, "infinite" with the engine running and the charging system working properly, and close to zero if the charging system is not working properly. If that is not the case, the regulator might have a problem, or there might be bad connections somewhere else. If it is the case, the warning light circuit would seem to have a problem that is confusing the issue.
  21. "Weird bollocks ", indeed! I have put mySport on the lift, removed the seat, pulled the regulator connector apart, probing with the DVOM, trying to fathom why @Sam P's Sport won't charge and how the strange warning light behavior might inform a solution . . .
  22. A few words on this... Basically, I'm of the same opinion as @docc here. Regarding batteries: modern Lithium-ion batteries are much better at not getting a "memory", living with lower charge states and what-have-you. As a sound engineer, I've spent the last 40-odd years dealing with things that run on batteries. Experience shows that it is better to regularly make sure they get charged properly, then let them cycle for a while as the manufacurer intended, then make sure they get a good charge, then let them cycle, and so on. The lead-acid variants that we find in our motorcycles belong to the category that this applies to. Cheap trickle chargers don't do the business. Docc has the right approach: proper charger, let it cycle, proper charger. And now, back to the topic in question: why is your charging system doing weird bollocks?
  23. My memory is unfortunately foggy one the chain of events, but I will try to reconstruct them here. After the first Odyssey showed signs of bubbling and bloating - with no alert from the charging lamp - I assumed to regulator was bad, and that the reg was overcharging the battery, hence the bloating. So I replaced the reg, along with my current "new" Odyssey battery. Next, I took the bike for a ride and the battery light lit up again, so I suspected the stator - sending too many AC volts to the regulator - which I then replaced. Installed the new stator, rode for 100 miles and the charging light never lit up. Like an idiot, I thought all my problems were solved, lol. The next ride, the lamp started to activate at 3-4K rpm, which is where we are now. (This was the title of this post, remember? Is the stator defective?' My memory is foggy on this, but I never recall the battery light OR the oil light EVER activating with key on, engine off.
  24. The derived protocol takes more attention and involvement, but improves the outcome. Is it worth it? I can say, with certainty, mySport's performance (and reliability) is significantly better with optimal charging and battery strength. YMMV
  25. Good news. Just got an email from batterystuff.com with a UPS tracking # and the charger is scheduled for delivery this Friday. Not to derail my own thread on my charging issue, but it sounds like going forward I should stop using the Battery Tender and use your protocol quoted here, amirite?
  1. Load more activity
