Chuck
Fuse 4 on Scura
What causes fuse 4 to blow over time? Looking back through my records, I see that it failed when I was out in SoCal several years ago. It just failed again while cranking. Out in SoCal, it failed when coasting to a stop.. <scratching head>
Share this post
Link to post
Fuse 4 is the Ignition Switch. They deserve a good inspection, cleaning, and lubrication.
Share this post
Link to post
Here is a short (no pun intended) thread on my fuse 4 issue. Mine was an easy fix.
Share this post
Link to post
This one won't be so easy, I'm thinkin.. from maintenance log:
Quote
4-1-15 30560 Suddenly quit out in the mountains. Replaced a 15 amp fuse.
This is the fuse that blew Thursday. Maybe I'll just buy a couple more? At 4 years per fuse, that might just do it.. :oldgit:;)
Share this post
Link to post
That seems rather un-pilot-like . . . :huh:
When was the last time the ignition switch was inspected for broken wires, cleaned and restored?
  • Haha 1
Share this post
Link to post
    Yeah, you're right, Docc. I'll overhaul the ignition switch. :D  It's an easy job. It's no guarantee that it will fix it, though. I still think I'll buy a couple of spare fuses..:rasta:
Share this post
Link to post
All of the above? :sun:
Share this post
Link to post
Pretty much. Fuse 4 feeds the ignition switch, then about everything else on the motorcycle. Maybe I'll just put a penny in it..:o
Oh, and while I have it on the lift, is there any reason I can't piggy back a lead from Fuse 3 to the 30 pin on the start relay? That looks like an easy way to get some serious power to the starter..
Share this post
Link to post
On 8/4/2019 at 7:07 PM, Chuck said:
  •  I still think I'll buy a couple of spare fuses..:rasta:
I preemptively installed circuit breakers just in case I have an issue.
05E8E8B4-0585-4429-87FF-0A82E325EFA1_zps
I cleaned the contacts with Caig detox and just this weekend I pulled them all out and the relays and sprayed everything down with ACF-50 (I use that stuff on my semi truck and it works...rare in this day of BS Snake Oil)
ACF-50 Underwater Test
along with most of the connections..
Share this post
Link to post
With your new direct feed removing its largest load it shouldn't blow any more.
With the old wiring as the switch got dirty the current dropped down to a point where it was taking too long to pull the solenoid in although I have no idea why it blew while running.
If you look at the blown fuse it gives a clue, just a tiny gap indicates it was only mildly overloaded, a large gap indicates a short circuit.
Fuse 4 also feeds Fuse 6 and 7 through the ignition switch.
Share this post
Link to post
It's a sign of low voltage. Mine blows if the battery is low and keep trying to start it. It's somewhat rare but it happens.
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
