Tinus89
    7
Everything posted by Tinus89
  1. Hey all, I need some help. After the total rebuild of my engine, I drove the Sport for about 500km, no issues. Checked valve clearance again, oil level etc. Yesterday I went on a rather spirited ride with some of my co-workers. Weather: half sunny, 21deg C. The following sequence of events happened: - After a sporty drive, stop and (by accident) kill the bike using the side stand in gear. I want to relocate the bike and try to start it again (in neutral). The starter just turns the engine through one compression cycle slowly and stops, just like with an empty battery. I leave the bike for 5 min and decide to try again, and she starts up like nothing happened. - After the second sporty drive, idling trough a city for a bit, some traffic lights, the pace pics up again (~60km/h). A roundabout without stopping, acceleration and then at around 70km/h, she just dies. Nothing. Try starting: she wants to fire up, idles roughly and then (or when I open the throttle) dies with a bang in either of the exhaust. - I wait for help (40min) and when help arrives, I start and she fires up like nothing happened. After a 10km tail, the help says goodby and I drive on (20km), until I have to wait for a traffic light (2min). Accelleration again and again at around 70km/h, she starts sputtering and dies. I decide it may be a heat issue and let her cool down (20min). - Start, rev a little, OK again. Start driving, about 10min, doing a steady 80km/h for about 2min and again: sputtering and surging. I had to keep her going because I couldn't stop, and eventually blew off the right intake boot. Brought her home on a trailer. What I did: Move all relays one position, no succes. Check tank vacuum: OK. Check ground lead to gearbox, secure. What I will do: - ECU Error readout - Visually inspect full wire harness - Check connections under fuse box and relay box What else can I do? - Can the no hot start have damaged anything or be related? - Only thing I changed since last drive and before this one, was replace the starter switch (which I damaged in my fall) and tidy up wiring. - It does not seem to be vapor lock, as she also died at speed and it was not too hot outside. Sorry for the extensive story, but I really need help where to look and want to paint a proper picture of the issue...
  2. That sucks! The damage could have been far worse... So.... Exactly two days before you fell down, I fell down as well! Busy with the Decent Tune Up (as the bike stalled every shift after the rebuild), I wanted to heat up the bike. I was distracted and while shifting 2nd to 3rd, suddenly there was a huge truck from the right. In shock, I applied the brakes way too fiercely (they are potent hey!) and put her down around 30kmh. The aftermath (aside from a still very painful knee): Left exhaust pushed in Exhaust damage Sprark plug guard, spark plug and cable damage Indicator gone and some scratches on the windshield. All in all, it could have been far worse!
  3. I installed my pump dry (oil film on the inside, that's it) and installed my filter (UFI) dry as well. Then, I rebuilt the entire engine, except for the valve covers and cam chain. I took out the front main bearing and filled the crankshaft and oil supply line with a lot of oil (took some time), until I was under the impression nothing was going in anymore. Then I reinstalled the front main bearing, filled the sump with oil and put my battery drill with a flat screw bit to the flat line in the oil pump. After turning anti-clockwise at around 400rpm for somewhat like 1-2mins, I had oil at the rockers! One tip: as soon as the drill slows down just a bit because of pressure-buildup, slow down! Otherwise you may have to clean the workshop and go for a shower straight after (how do I know? something with bubbles of air in the oil line and stored energy )
  4. Interesting reads about squish band! So, I'm going to steal my topic back: she is running! But.... It seems like the rattle is still somewhat there, but less. I will need to re-adjust the valves after a short run and then probably after some 1000km again. Should I also replace the oil after a bit? She does need a full tune-up though... The idle before the little drive around the block was steady as a rock, but as soon as I went driving, the idle was too low and rough, stalling each time I came off the trottle. After the drive she was sneezing and backfireing sometimes... Also, she has developed a fuel leak at the T-junction on the back of the injector... Not sure how I should deal with that. Are there seals in the plastic parts that are kept together with circlips?
  5. That's interesting.... The only lower gasket (cylinder bottom) I could get here in the NL was a paper one... The one that came off it was indeed laminated with steel.,,
  6. Try the connection to your oil pressure sensor.. When that one fails (or you disconnect the wire), the light will not come on.
  7. And it's ready to go into the bike! Question: do I need to re-torque the cilinder-head studs after a while? I now torqued them all to 42Nm as prescribed by the manual.
  8. Update time! - Exit shaft seal replaced. Screwdriver method was peanuts, was out in under a minute. - Roper plate received and installed. Thanks mr. Roper! - Gearbox oil replaced. - Rebuild in progress! Pics below. One tip: when you have installed a Roper plate and you are going to place the circlips retaining the piston pins, cover the hole underneath the piston. It might just drop in the engine (how do I know?).
  9. Thanks! That's the exact comment I was hoping for:)
  10. I already have the rear seal:). I will consider the throwout bearing and speed bleeder, that seems very interesting!
  11. Thanks for your extensive response! Things to consider: 1. Done that already. 2. How do I know when a bearing should be replaced? Sound? Parts are relatively expensive here and unavailable locally, so shipping costs go per part... 3. What's a speed-bleeder?
  12. I had read all those topics, but it is not really clear to me whether I do or do not require special tools to remove that rear cover? Did use the search engine, but mainly for "output shaft seal" or similars, not for "gearbox leak"
  13. I had not seen that posting, thanks! Mine has done 34k km in 16yrs, so I am not surprised it leaks. Seals harden over the years as well and it is exposed to the elements. I already have the (original) replacement seal at home. I'm considering removing the rear cover altogether, which should make replacing the seal far more easy... How how is that? Anything I should pay close attention to?
  14. Update on the tranny: I ended up using a metal glue from the brand Bison, which should do the trick! Seems to be very strong, see if that holds:) Another thing I discovered while the tranny was "parked": A leaking exit shaft seal... Can I replace that with the shaft in place? How hard is that, any tricks?
  15. Correct, I had set the valve clearance to "World" settings for this beauty, which is 0.15mm and 0.20mm. Tighter settings do not take away the sound. She has done 34.000km It does not wobble about and it was shifting well. Had already tried using liquid gasket to seal it: worked for about a month, and then it was forced loose again by rotation of the pin, causing it to leak again.
  16. In the mean time (while waiting for the crankshaft polishing etc), I decided to have a look at my gearbox leak... The leak originates from one of the two centre shafts for the shift clocks (or how do you call them). That pin just drops out, the other one is nice and stuck in the housing. I'm guessing the housing got some wear, causing the pin to be loose. But how would you solve this? Would it be possible to cut an o-ring groove in the pin? Or would that weaken it too much? Any other suggestions? Images are clickable for large.
  17. Interestingly, my 2001 V11 Rosso Mandello doés have a check valve in the crank breather... But it's not on the parts drawing. So maybe the P.O. put it in, or maybe it was there from the factory.
  18. Mine is 1.471mm
  19. Hey all, After reading this topic, I had a little check of my '00 frame. My black frame does not have the mounting points for that additional support bracket, nor do I have the extra supports hugging the transmission/bell housing on the bottom... In other words: my engine/tranny is only mounted on 3 points: timing cover, upper bolt on the back and lower bolt all the way though at the bottom of the gearbox...
  20. Thanks! That is comforting:). I did decide to change-out the rod bolts anyway.
  21. Feeling really stupid... I could have known this! Finally found time to go and check on the bike (it's not at my house). Even though it's an '01, the headstock plate states 0007/00, so I'm presuming that indicates July '00?
  22. Should I, living in Europe, better get it through you or straight from Mr. Roper himself?
  23. Awesome, thanks! That's exactly the answer I was looking for! I will mark things next time BEFORE I take them apart
  24. Anyone?
