Rolf Halvorsen
Everything posted by Rolf Halvorsen
Any shop can deliver theese. The part number 90401526 means: Inner diameter 15 - outer diameter 26. Rolf
I suspect that the ignition sensor in front left og the engine is bad. Have seen similar behavior before. Article number is 01721600. The distance between the sensor head and the entrance should be aroung 0,5 - 0,7mm. Thin alunimum sheets help to get this correct. You also need a new O-ring to seal it against moist. Chime in if you need more details.
Fuel petcock flange o-ring specifications and recommendations
Rolf Halvorsen replied to antmanbee's topic in Technical Topics
I think the 16x1,78 means Ø16mm inside diameter with thickness 1,78mm. Rolf -
GU90706116 Stein Dinse in Germany reports: Moto Guzzi O-Ring 16x1,78 Rolf -
This is standard on all 5th gears. It is not dangerous - just put something in your ears. But the fix is to renew both 5th gears to get rid of the "high" noice. Rolf
Thank you for telling us. The only way to increase learning - is to know how things can go wrong. Rolf
Air in the system makes the slave cylinder not move enough.
What if you have got air in the hydraulick system? Bleed the system.
Interested in the TITANIUM racing ECU. Send me a PM. Rolf
Maybe some misunderstanding. I was mainly interested in the damaged kit seen on the top of this site.It was adverticed in 2008 - and I would be interested if the price was much lower. Rolf
What is your price + try to find a cheap way of shipping. I am in no hurry. Rolf Halvorsen, Dalborgvegen 288, 2817 Gjøvik, Norway rolf.halvorsenATmail.com
Do you still have these for sale? Rolf
The basis is the SKF pipes for the KLM's (nuts) No. 3, 4 and 5. But they do not fit very well and are costly when you buy only 1. I have redesigned these + added the No: 2 which is maybe the most important together with No. 1. My special peg nuts pipe tools comes in 4 variations: 1 - (KM5) - For the crank peg nut on the 5-speed models + gearbox drive hub nut on the late 6-speed gearboxes from around 2006. 2 - For the 5-speed gearbox drive hub nut + the same nut on the first edition 6-speed gearboxes from around 1999-2005 3 - (KM3) - For one peg nut inside the first edition 6-speed gearboxes around 1999-2005. 4 - (KM4) - For another peg nut inside the first edition 6-speed gearboxes around 1999-2005. I have bought from the factory batches of 30-50 units, to get the unit price down. And I have 120 customers all over the world. (Yes I have still their names) But all things must end - so also for me. That is why I have decided to stop buying/selling these tools. I would be happy if someone would consider to take this further. I have no knowledge of similar tools from other producers. Rolf (In Norway with a special interest for V7 Sport)
Just a small correction: I mean NUTS(PEG NUTS) and not SCREWS. I do not why I wrote screw. Rolf
The screws we are talking about are: KM3, KM4 and KM5. All from the SKF factory. They are all used on the first edition of the 6-speed boxes for the V11 Sport. SKF also have the tools for these screws. But in my opinion they do not fit very well. My tools are made in the same Swedish company (Momento) - but according to my own drawings. The HUB screw for the 5-speed boxes are not a SKF standard. I have stopped selling these tools because of my age. If anybody would like to take over - give me a hoy (PM). Rolf
A tip is to grease the bottom of the screw before entering, this way the high friction that kills the tab washer will diminish. Rolf
The locking tabs are standard belonging to KLM 3, KLM 4 and KLM 5. KLM stans for "Kule Lager Mutter" (swedish company SKF). They should be available "everywhere". Lucky Phil: Buy the tools or lend from Pete? Rolf
Where is the locking tabs? Rolf
Typical mechanical behavior list for 02 V11
Rolf Halvorsen replied to Gmc28's topic in Technical Topics
Remove the cable connector from the right cylinder temperature gauge - and put it back again. (No I am not joking.) The reason is that the resistance in the gauge is about 3KOhm when cold - reduced till about 0,3KOhm when warm. Corrosion in a bad contact surface (more resistance) can fool the ECU to think that the engine is colder that it really is - leading to feed more petrol than needed. Rolf -
RAM aftermarket single plate clutch.
Rolf Halvorsen replied to pete roper's topic in Technical Topics
Phil (and Pete) Even better than a loan. I have still some of my tools for sale. Special pipe for the peg nut 93601020 Special pipe for the peg nut 04055100 And also the special pipe for the front peg nut 93601026 Would you like to have an offer including shipping? Send me a PM. Rolf -
No answer for your question - but may be of interest for some. I have a few ROSSO MANDELLO labels - for sale. 50USD / pair. Anyone interested? Can be posted a letter. Posting is included. Rolf
The gearbox house is still available. It has been casted later than 2005 - so it is not amongst the lot that did have a tendency to crack where it is positioned to the frame. Color smooth black. 400Euros INCLUDING shipment to anywhere in the world. Rolf
Ref. Service Announcement No. 14-2003 Affected VIN: ZGUKR0000YM112131 - ZGUKR00001M114639 ZGUKR00001M111111 - ZGUKR00001M111147 ZGUKR0000YM211111 - ZGUKR00001M211162 Bikes from 1999 until 2002 Kit code no. 973260900016 Flexible coupling hose - 04211201 - 1ea. Spacer - 04212401 - 1ea. Movable hose - 04214901 - 2ea. Rolf
